05-20-2006, 09:36 | #1 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Europe Age: 46
Member: 10946 Status: Offline Thanks Meter: 15 | w550:Error flashing block at address: 0x50000000 Error flashing block at address: 0x50000000 Script error: Flash error [9.66.75] The log is: Sending applet... Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. RSA protection is normal. Phone hardware initialized OK Flash file: "W550i_CXC1250032_EMEA3_R4CA004_Brown49.cw55fs " Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Baudrate = 921600Bd Analysing flash file... Programming flash... Error flashing block at address: 0x50000000 Script error: Flash error [9.66.75] what is the problem? I can flash main flash ok,i can convert phone to brown but the problem is with the FS file. I use cruiser 9.66 Please help Thanks |
05-20-2006, 10:19 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Brother try to check ur battery voltage and also check the cable..If not work then try older ver of cruiser and also try to change the flashes!!! Br Muneeb Akhtar Raza |
05-20-2006, 10:24 | #3 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: USA
Member: 85637 Status: Offline Sonork: 100.100.529 Thanks Meter: 139 | error Quote:
try with TP it's work | |
Need HELP K790i flashing | Error flashing block at address: 0x44140000 | galerinisan | Cruiser Suite | 4 | 06-03-2008 18:06 |
k501i always Error flashing block at address: 0x44650000 | patric | Cruiser Suite | 17 | 04-14-2007 08:58 |
W810 dead after failed flash (Error flashing block at address: 0x444B0000) | Xflame | Cruiser Suite | 12 | 12-11-2006 04:27 |
k500i Error flashing block at address: 0x450C0000 | ber747 | Sony Ericsson Hardware Repair | 5 | 04-28-2006 13:14 |
J300 DEAD ( Error flashing block at address: 0x0000000 | aang | Cruiser Suite | 3 | 03-04-2006 18:18 |
