Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 05-23-2006, 15:35   #1 (permalink)
Member: 67956
Thanks Meter: 2
To Lead: Z530i CID49 RED problem.
How to repair Z530i dead by cruiser. When i trying to flash FS it always say error:
"Error flashing block at address: 0x45B10000
Script error: Flash error [9.68.75]"
Adress always not the same...
How to solve this problem?
Old 05-23-2006, 15:53   #2 (permalink)
Akoska's Avatar
Member: 2054
Thanks Meter: 10
Try to set flashing speed lower and better charge battery with a compatible phone or desktop charger...
Old 05-23-2006, 15:59   #3 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
Thanks Meter: 198
try the erom flash file cid49 _ brown in avr & then full flash the phone
Old 05-23-2006, 16:05   #4 (permalink)
Member: 67956
Thanks Meter: 2
Battery full charged. Problem the same on all speeds fron 115200 to 921600.
@frnd_4_gsm
Where can i get this file for cruiser?
Old 06-12-2006, 15:10   #5 (permalink)
EGY2004's Avatar
Member: 123630
Thanks Meter: 12
z530i
1-remove RSA
2-FLASH MAIN
3-FLASH FS
4-CUSTOMIZ FS
THANKS
Old 06-12-2006, 16:45   #6 (permalink)
Member: 126612
Thanks Meter: 8
@frnd_4_gsm
Trust me mate .. the LAST thing you wanna do is **** with the erom of a red49 phone ... thats the best way to make it a very expensive paper weight ...
If your battery is fully charged then simply :
1 - connect it to cruiser
2 - unlock rsa
3- flash main ( this will restore rsa )
4- flash fs
5- unlock rsa again
6 - customise fs
7 - restore firmware
If your phone has a software problem than this will 100% sort it out ...
Old 06-15-2006, 13:14   #7 (permalink)
Member: 19190
Thanks Meter: 28
2 - unlock rsa
4- flash fs
5- unlock rsa again
6 - customise fs
i have did all the step.
1 .unlock RSA
2 .flash main
but everytime when i flash main, it comes..
Error flashing block at address: 0x442F0000
Script error: Flash error [9.74.75]
everytime the same problem, any 1 can help me to solve it?
very urgent....
Old 06-16-2006, 09:28   #8 (permalink)
Member: 16789
Thanks Meter: 3
Try write gdfs file and after flash main/firmware.
Old 06-16-2006, 11:40   #9 (permalink)
Member: 5653
Thanks Meter: 6
I had the same problem with K510i
Solution was to downgrade cruiser to v 9.66 and all worked fine .. hope it helps you too
Old 06-16-2006, 13:29   #10 (permalink)
Member: 16789
Thanks Meter: 3
Hmm..New z530.
Unlock rsa - ok
Flash main - error
Write full gdfs - ok (no reconnect) & flash main/fs - ok
Customize - "Could not start GDFS service"
Battery full,any speed.Phone is dead.
What solution?
Old 06-16-2006, 13:32   #11 (permalink)
Member: 5653
Thanks Meter: 6
did you try with a downgraded version of cruiser?
Old 06-16-2006, 13:54   #12 (permalink)
Member: 16789
Thanks Meter: 3
With version 9.66 same problem - Could not start GDFS service
Old 06-17-2006, 20:49   #13 (permalink)
ricardoz's Avatar
Member: 124842
Thanks Meter: 11
check 3v , or change for adapter 4 - 5v
Old 07-20-2006, 08:22   #14 (permalink)
Minos GSM's Avatar
Member: 153926
Thanks Meter: 23
its a new version for z530i and this problem can't be solved in the moment so we wait
Old 08-01-2006, 20:29   #15 (permalink)
Member: 19190
Thanks Meter: 28
these few days i am trying on another z530i, but every time when i customize FS, it will show (could not start GDFS) as the picture i show below, can anybody here help me...? need help urgent...!
How to Unlock K750i CID49 RED check here pakstar SETool2 16 09-23-2016 11:04
z530i cid49 red imei change error trentini Cruiser Suite 2 06-18-2008 07:29
problem unlocking a K610i CID49 RED! help!! jawad8305 FuriousGold 3 11-17-2007 15:50
how to solve K750i CID49 Red Dead. ales6orah MT-BOX 1 12-25-2006 12:27
When to connect TP V600i CID49 Red davesmobiles Cruiser Suite 3 02-18-2006 10:09
Page generated in 0.24328 seconds with 10 queries
