Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 06-15-2006, 04:08   #1 (permalink)
danielkhaw's Avatar
Member: 10977
Thanks Meter: 55
Cruiser 9.74 bug found (All please report here)
found K700 cannot convert from red to brown
Old 06-15-2006, 05:49   #2 (permalink)
Member: 10946
Thanks Meter: 15
When flashing main and raw flash of K750 or W800 and then try to customise the phone it displays error. If i detach the phone and then attach it again and try to customise the phone everything is ok.
Old 06-15-2006, 06:06   #3 (permalink)
sayaicat's Avatar
Member: 160314
Thanks Meter: 50
i hve the same problem with sdimitris, but after that everything is work fine...
Old 06-15-2006, 06:51   #4 (permalink)
Registered User
Member: 166406
Thanks Meter: 3
Cruiser doesn't relock RSA after flashing the T290, now it has to bypass boot each time it's attached. Old phone, I know that.
Old 06-15-2006, 09:03   #5 (permalink)
DeDaMrAz's Avatar
Member: 11604
Thanks Meter: 7
That is not a bug, RSA can`t be locked on that model (it doesn`t have "what it takes" )
Old 06-15-2006, 13:51   #6 (permalink)
Member: 248353
Thanks Meter: 3
signed flash relock rsa
Old 06-15-2006, 17:03   #7 (permalink)
Registered User
Member: 166406
Thanks Meter: 3
I stand corrected. Tested on a T630 and it seems you are right .
Old 06-15-2006, 17:04   #8 (permalink)
Registered User
Member: 166406
Thanks Meter: 3
I just tested on one I have lying around, it is converted without any problems.
Old 06-15-2006, 18:55   #9 (permalink)
JC_BY's Avatar
Member: 59319
Sonork: 100.1606948
Thanks Meter: 82
k750 CID49 doesn't OTP IMEI check off!
It stays only this screen (see attachment) and nothing happend!
IMEI changed ok, but now I have 4 locks closed and after i flashed it with r1bc002 with usbsmart it stays in "Please wait!"
I did on USB-Smart! Remaked CRC and unlocked the phone, now it work!
But probably no solution for IMEI k750 CID49 for now!
Old 06-16-2006, 08:41   #10 (permalink)
andrew14's Avatar
Member: 78367
Thanks Meter: 11
Cool waaaaaaaaaaaaa
804sh can not unlock!!!!!!!!!
Old 06-16-2006, 19:25   #11 (permalink)
gsavv723's Avatar
Member: 7604
Thanks Meter: 10
I have problem with customize FS in W810
gsavv723
Old 06-28-2006, 22:22   #12 (permalink)
Member: 184609
it`s not possible to write back a cfp file back to the phone !! K750i
Old 06-28-2006, 23:28   #13 (permalink)
rjsoo7's Avatar
Member: 39014
Thanks Meter: 7
Failed Customizing W900i
I had problem with 9.74
It always fails to cutomize W900i
Please cruiser team investigate.
THanks
Old 06-28-2006, 23:35   #14 (permalink)
haber's Avatar
Member: 157756
Thanks Meter: 14
Some pice of k700 after direct unlock are blinking ...
Old 06-29-2006, 11:07   #15 (permalink)
Member: 173013
any problem...
my w550 cant conacted with cruiser
i've used power suplay any rsa boot options like TP,recovery cid 49
but its still not conected
Cruiser 9.74 read ARM from Z520i ... error microera Cruiser Suite 0 09-09-2006 13:05
@ LEAD .. 9.74 bugs .. pls reactivate 9.66 rjsoo7 Cruiser Suite 3 08-29-2006 11:44
Cruiser 9.74 expires Oct 7 Zwed888 Cruiser Suite 10 08-16-2006 05:21
Cruiser 9.74 time expired. jjfox04 Cruiser Suite 1 08-12-2006 02:34
Unlocking SE K750i with cruiser-9.74 the following problem: adigem00 Cruiser Suite 1 06-24-2006 13:53
Page generated in 0.23903 seconds with 10 queries
