Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 09-14-2007, 09:07   #91 (permalink)
Crazy Poster
Member: 374164
sir please help me
i can't enter down loding section because i forgot the username and passward
pleasehelp me
normally iused mirrer server but this time i faild download from mirrer server
Old 09-15-2007, 07:26   #92 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
can i flash and custom the K618i from cid 49 to cid 52 with free? i'm using 06 cards.
Old 09-15-2007, 07:45   #93 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Free Flasing is for 07-ID, Even if you have Logs(06-ID), You cant Cross flash Mate.
Old 09-15-2007, 19:22   #94 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
Cruiser tream please update unlocking cid 52 ,new phone all cid 52 end unlcking patch free for cid 49/51 .. for money ammortizzed with D-Client
regards.
Old 09-16-2007, 07:55   #95 (permalink)
FilipLudvik's Avatar
Member: 135110
Thanks Meter: 302
regards.
if was patch unlock cid52 easy, was he yet added..
use correct solution by EMMA
regards,
Filip
Old 09-16-2007, 10:55   #96 (permalink)
quickgsm's Avatar
Member: 414755
Sonork: quickgsm
Thanks Meter: 389
Thanks for this update support team!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 09-22-2007, 08:50   #97 (permalink)
mr.Dubai's Avatar
Member: 450219
Thanks Meter: 120
Thanks for this update Crusier support team.
Old 09-30-2007, 18:39   #98 (permalink)
burger_gsm's Avatar
Member: 240763
Sonork: 100.110277
Thanks Meter: 105
Nice Update But I Hope We All Need Cid 52 Unlock Now
Old 09-30-2007, 19:38   #99 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
year 2008 or 2009? or new card id-08?
Old 10-01-2007, 19:43   #100 (permalink)
..::topnet_gsm:'s Avatar
Member: 565354
Thanks Meter: 28
Originally Posted by gervalz View Post
Flashing procedure:
·Turn the phone on, then by pressing the >*<<*<* "secret" key sequence enter phone service menu. Go to the Service info submenu, then select the Software info item. Write down the first 2 or 3 lines describing the phone firmware version.
·Attach the phone normally, via DCU-60 or DCU-65 cable.
·Go to the Security RSA tab and press the Unlock RSA button. One server credit will be deducted.
·Note: Now the first 768KB of main firmware is overwritten, so it has to be restored or reflashed by a suitable main FW flash file.
·Flash the main firmware and raw filesystem to the phone. CID and certificate color do not matter.
·[Optionally you may perform direct unlock or read codes operation at this step - for free of course].
·Turn the phone off (e.g. by pressing the <Ctrl-O> key combination). Note: This requirement is an implementation flaw and will be sorted out soon.
·Reattach the phone.
·Customize the phone. One server credit will be deducted.
I tried to flash a db2012 CID 50 w810 and deduct 2 credits, also have "please wait" after flash...
how can I correct the flashing procedure?
ONLY tik useOTP IMEI INSTEAD
and write GDFS IMEI befor Customize
B.R,
Amin Soveiti
..::TOPNET_GSM::..
Old 10-02-2007, 11:18   #101 (permalink)
nomangsm's Avatar
Member: 121662
Thanks Meter: 39
Thank you, great update. Cid 50
Old 10-03-2007, 09:36   #102 (permalink)
Imrankhan's Avatar
Member: 573962
Sonork: 100.1603021
Thanks Meter: 480
thank you for updates
Old 10-03-2007, 23:01   #103 (permalink)
Member: 36488
Thanks Meter: 4
whats now with the update? its thursday already?!
Old 10-04-2007, 17:56   #104 (permalink)
sunnyarora's Avatar
Member: 483406
Thanks Meter: 180
sir good update of it can unlock w200 without any problem
Old 10-12-2007, 13:22   #105 (permalink)
Registered User
Member: 212458
Thanks Meter: 3
Thank you................
.:: New Release - Crusier+ 13.00::. xiaoyuz Cruiser Suite 9 11-21-2007 12:33
.:: New Release - Crusier+ 12.00 - Free standalone flashing & customizing DB2020 ::. Mizar Cruiser Suite 195 10-31-2007 20:22
.:: New Release - Crusier+ 12.02 yasin_shafi Cruiser Suite 23 09-10-2007 08:20
.:: New Release - Crusier+ 11.03 - Correct DB2012 unlocking via codes and more ::. Mizar Cruiser Suite 123 08-08-2007 13:29
Page generated in 0.21709 seconds with 9 queries
