A New User Doubt About K800i Gdfs Error During Complete The Phone--help I AM A NEW USER OF CRUISER.PURCHASED LAST WEEK.HAVE NOT DONE SE IN IT BECUASE I HAVE SE TOOL SINCE SIX MONTHS.TO STUDY MORE PURCHASED CRUISER. NOW I HAVE A K800I DEAD.CUSTOMER SAID THAT REMOVED BATTERY WHEN TURN ON(I MEAN WITHOUT TURN OFF).THEN NEVER TURN ON. AS USUAL FIRST TIME I TRIED IN SE TOOL.( I HAVE EXPERIENCE IN IT ONLY BECAUSE I AM NEW CRUISER USER) WHEN CLICKED IN IDENIFY GOT AS BELOW Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601775701 CERT:RED FLASH CID:49 COLOR:RED set_gdfs_props failed, exiting Elapsed:7 secs. THEN I TRIED FLASHING USING CID49 FILES AFTER TICK TWO OPTIONS IN SETTINGS.COMPLETE THE PHONE AND USE SERVER FOR UNLOCK/FLASH AND GOT AS BELOW Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601775701 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 Flash ID check:2019 Flash props sent ok writing E:\may2007\students cd\25.SE TOOL\flash files\k800\FROM SETOOL NET\R1EJ001_1250568_HUTCHISON_WI.ssw.cry CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:9100 Will flash 455 blocks... SSW loading returns:0 writing E:\may2007\students cd\25.SE TOOL\flash files\k800\FROM SETOOL NET\R1EJ001_HUTCH_1_fs.ssw.cry CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:4420 Will flash 221 blocks... SSW loading returns:0 CSloader version: 061027 1723 HANCXC1250562_DB2020_CSLOADER_R3A005 loader startup: executed loader filesystem startup: executed csloader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed:613 secs. FLASHING MAIN AND FS NO PROBLEM.BUT AN ERROR DURING COMPLETE THE PHONE ''''''''''loader filesystem startup: executed csloader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal"""""" I HAVE CRUISER LOGS ALSO. CAN I REPAIR IT IN CRUISER? IF YES-I WANT A DETAIL PROCEDURE TO REPAIR IT OR A LINK TO ABOVE DISCUSSIONS. THANK U |
Upgrade EROM ........ |
I TRIED UPGRADE EROM AND GOT AN ERROR AS BELOW SERVER SUPPORT ENABLED. RECOVERY MODE STARTED DB2020 EROM UPGRADE STARTED OLD EROM, OVERRIDING CID error while reading security units SECURITY UNITS CAN'T BE READ ! PHONE IS EMPTY OR GDFS IS DAMAGED. Elapsed:9 secs. SO I THINK IN MY SET GDFS DAMAGED. CAN I RESTORE USING CRUISER? IF YES HOW? THANK U |
The phone has a GDFS damaged. You must use Se Tool to fix it (Cruiser can't :( ) Regards! |
if not then try if same forget this phone.. as far as ur pm i checked ur log ur gdfs is formated say bye bye to your phone... no tool is able to recover k800i gdfs..or any db2020 gdfs... ps:how can they?no one able to CRACK RSA 1024...****ING *******..HELL WHAT CAN BE DO IN IF RSA SING INCREESS TO 2048 ... |
press erom on cruiser it wil update the erom and hopefully fix yoour fault |
We are now researching the solution to help you. Please be patient. |
Lots of K800 have this problem. It's a GDFS fault. I hope that Cruiser will find a solution asap.. BR |
