02-11-2007, 21:23 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | Which One Is Right Procedure Flasing Procedure In Cid49 its mention as per manual..this is the way... 1 attach phone 2 security rsa tab.. ..replace certificate by same cid but brown(cid49 brown) 3 click on replace certificate 4 attach phone 5 security rsa tab....click on unlock rsa 6 flash arm 7 flash raw fs 8 customize fs 9 file system tab ...disable camera 10 file system tab....shut down fs (Cruiser will automatically detach the phone.) To fully complete the job, you should convert the phone back to Red. This step is necessary if the phone is CID37 or higher (otherwise the phone will not power on) but should be done anyway to complete the job professionally. 11· Reattach to the phone. To go the Security RSA tab and under Replace Certificate find the same CID as the phone is, but Red certificate. Click on Replace Certificate. · The phone is now fully flashed, insert a SIM Card and wait for it to boot up (it will take a few minutes after the Raw File System has been flashed to it OR THIS IS THE RIGHT WAY Attach to phone Unlock Rsa Flash Fs Customize Fs Shut down Fs Attach to Phone Direct Unlock Attach to Phone Flash Main arm Turnoff the Phone KINDLY SUGGEST WHICHONE IS RIGHT WAY regards! |
Which one is the best and NO:1 in the software market? | caremobiles | Chinese Models & Cloned Phones | 2 | 07-31-2009 11:26 |
which one is best box that helps in cdma sets | pavas | Various CDMA/TDMA Cell Phones | 4 | 12-20-2008 05:37 |
auto ini cable, which one is right? | Zaihtam | S-Gold Based Phones | 1 | 07-21-2006 21:22 |
which one is newest? | uni_gsm_tech | Sim Cloning and Scaning | 5 | 04-22-2003 12:57 |
ppm - which one is which | Immortal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-22-2002 02:13 |
