06-01-2005, 13:50 | #1 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Russia Age: 52
Member: 5238 Status: Offline Thanks Meter: 2 | Z800 cid36 dead with 3.91 EMMA smartcard detected at startup. Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 36 Phone color: Red Trying CID29 recovery applet... Sending applet prologue... No suitable applet found. Phone not power Hamltd |
06-01-2005, 13:59 | #2 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 42
Member: 104924 Status: Offline Thanks Meter: 8 | mm i'm not sure but try http://www.microengineers.cc/cruiser...ery_GSM_Series and after flask with convertion file from V800 to z800 good luck |
06-01-2005, 15:03 | #8 (permalink) | |
Member: 5238 Status: Offline Thanks Meter: 2 | Quote:
..... and EMMA III Hamltd | |
06-01-2005, 15:32 | #10 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Heaven of course! Age: 44
Member: 93497 Status: Offline Thanks Meter: 2 | Version 2.00 (12th January 2005, beta version): Boot process optimized. Fixed a minor bug when booting S7xx phones with phone type autodetection turned off. RSA unlocking routine optimized. It works also for Z1010 and V800 of any color. Added languagepack change for Z1010 and V800 phones. so now v800 z800 cid36 is ok? supported? thanks |
06-01-2005, 18:53 | #11 (permalink) |
Member: 5238 Status: Offline Thanks Meter: 2 | Thx Lead! Z800 cid 36 alive. But I can ulock this phone. eady! EMMA smartcard detected at startup. Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 36 Phone color: Red Trying Red CID36 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Flash ID: 890D OTP CID: 36 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 36 Primary certificate color: Red Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown OSE configuration found. Analysing GDFS... Done. Sending CS applet... Initializing CS applet... Checking EMMA smartcard presence... Card serial number: xxxxxxxxx Entering PIN: xxxx Selecting key... Checking key status... Remaining number of uses: 190 Starting up GDFS service... Reading security zone... Done. Turning off phone... Phone turned off. Phone automatically detached. Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 36 Phone color: Red Trying Red CID36 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Flash ID: 890D OTP CID: 36 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 36 Primary certificate color: Red Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown OSE configuration found. Analysing GDFS... Done. Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Connect the testpoint! Disconnect the testpoint! Defeating RSA protection... need test point??? Hamltd |
06-01-2005, 19:26 | #12 (permalink) |
Member: 5238 Status: Offline Thanks Meter: 2 | Z800i Analyzing configuration... Reading primary certificate... Primary certificate CID: 36 Primary certificate color: Red Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown OSE configuration found. Analysing GDFS... Done. Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800 Bd Connect the testpoint! Disconnect the testpoint! Defeating RSA protection... need test point for Z800 Thx! Hamltd |
06-02-2005, 00:14 | #13 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | Quote:
I don't understand totaly, why phones have two certificate and in this case also with diferent colours. Which certificate is important when we flash phone to flash with same colour? wbr. | |
06-02-2005, 00:42 | #14 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
Read the full release notes (specifially for Cruiser 3.90-3.92), CID36 is supported for brown phones, Red is only supported via TestPoint. It would seem that it's possible to convert Red to Brown (again, using TP) | |
06-02-2005, 01:23 | #15 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Boston
Member: 21920 Status: Offline Thanks Meter: 10 | Yes, it seems like the most graceful way to do what is needed with CID36 phones will be to connect TP once and convert them to brown, then work with them. Hopefully a non-TP solution will eventually come, but that seems workable for now We just need to know where the TPs are for Z800, K750, etc... |
Can I flash N-91 RM 43_8GB V.3.00.060 with N-91-5 RM 158 V.3.00.060 ? | phitsawarn | MT-BOX | 4 | 04-14-2007 14:59 |
k750i cid36 dead | infogsm | Sony Ericsson | 0 | 12-28-2006 02:40 |
V800 cid36 recovery? z800 cid36 ---> v800 | Lucky7Napoleon | Cruiser Suite | 5 | 07-09-2005 03:32 |
Z800 CID36 unlock problem | Virginia | Cruiser Suite | 16 | 05-30-2005 04:44 |
