08-03-2009, 18:20 | #1 (permalink) |
Freak Poster Join Date: Sep 2003
Member: 38138 Status: Offline Thanks Meter: 4 | w810i cid49 will not power on I have been given a w810i cid49 which will not power on at all. It can be flashed ok but then shows no sign of life at all. The owner said it flickered and then gave out a few times and then finally died. I would be grateful for any advice on how to successfully revive it or has it reached the end of its life? Many thanks Soudies |
08-03-2009, 22:37 | #2 (permalink) |
Freak Poster Join Date: Feb 2007 Location: .::Samoa::.
Member: 458576 Status: Offline Thanks Meter: 34 | does the light on top blink red when trying to power it on? im assuming lcd also does not flash white. Could be hardware issue, try opening phone to check for liquid damage if software prob, you have mentioned it flashes ok. try this: Unlock Rsa Flash Fs Customize Fs Shutdown Fs Write Gdfs Unlock It Flash Main Arm sometimes phone ok after flashing and customize fs. Good luck buddy, give it a go |
v980 fone will go into boot but will not power on | coolmax | Motorola P2k | 1 | 03-15-2007 23:50 |
k750 cid49.. still not power on | luigivsf | Cruiser Suite | 4 | 10-11-2006 11:20 |
W810i after flashing not powering on | Nasmi | SonyEricsson (USB-Smart) | 4 | 08-08-2006 08:12 |
W810i after flashing not powering on | Nasmi | Cruiser Suite | 1 | 08-03-2006 03:47 |
6310i Will charge OK but will not power ON ! ! ! ! | Fre3 Crack3r | Nokia Hardware & Hardware Repair | 9 | 09-23-2003 12:05 |
