01-10-2009, 08:43 | #1 (permalink) |
Banned Thanks Meter: 346 | cruiser server problem thanku. Code: 13:14:12 SE Ultimate Unlocker v3.07 by Cruiser Team 13:14:12 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 13:14:12 Initializing... ! 13:14:13 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 13:14:13 2. Choose the phone model ! 13:14:13 3. Select the desired options ! 13:14:13 4. Please connect the phone either via USB while holding 2-5… ! 13:14:13 - or via a serial cable and double-click on it in the device list 13:14:38 Communicating with server… E 13:15:40 Error: 0xB3A47971 E 13:15:40 Login to server failed E 13:15:40 Failed! ! 13:15:40 To report errors right-click this window Code: 13:15:02 D-Ultimate Unlocker v3.07 by Cruiser Team 13:15:02 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 13:15:02 Initializing... ! 13:15:02 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 13:15:02 2. Choose the phone model ! 13:15:02 3. Select the desired options ! 13:15:03 4. Please connect the phone either via USB while holding 2-5… ! 13:15:03 - or via a serial cable and double-click on it in the device list 13:15:13 Communicating with server… E 13:16:15 Error: 0xB3A47971 E 13:16:15 Login to server failed E 13:16:15 Failed! ! 13:16:15 To report errors right-click this window |
01-10-2009, 09:37 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | same problem, cruiser team please check server Code: 12:28:58 SE Ultimate Unlocker v3.07 by Cruiser Team 12:28:58 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:28:58 Initializing... ! 12:28:58 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:28:58 2. Choose the phone model ! 12:28:58 3. Select the desired options ! 12:28:58 4. Please connect the phone either via USB while holding 2-5… ! 12:28:58 - or via a serial cable and double-click on it in the device list 12:29:15 Selected phone: K770 12:29:15 Connecting via Generic EMP USB Flash Device (USB1)… 12:29:15 Device driver version: 2.2.0.0 12:29:15 Device driver date: 9-18-2008 12:29:15 Connecting to the baseband CPU... 12:29:15 Entering baseband CPU service mode... 12:29:15 Detected chipset: DB2020 12:29:15 Boot mode: ROM 12:29:15 Sending loader... 12:29:16 IMEI: 352************** 12:29:16 OTP CID: 51 12:29:16 Effective CID: 53 12:29:18 Please reconnect the phone (disconnect, connect while holding 2-5) 12:29:23 Sending loader... 12:29:23 Communicating with server… E 12:30:28 Error: 0x3173E984 E 12:30:28 Error: 0x4B055A8F E 12:30:28 Error: 0x0B22373D E 12:30:28 Error: 0xB3A47971 E 12:30:28 Error: 0x41F19ADB E 12:30:28 Error: 0x51A411A0 E 12:30:28 Error: 0x78E56923 E 12:30:28 Error: 0x5C5AEBE3 E 12:30:28 Error: 0x3D35EAF1 E 12:30:29 Login to server failed E 12:30:29 Failed! ! 12:30:29 To report errors right-click this window |
01-10-2009, 09:53 | #3 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Cruiser as i see don't have support off all i post one or 2 thread 5-7 day's ago no one answer Sad to say but m disappointed after buy Cruiser Dongle Regards |
01-10-2009, 11:28 | #7 (permalink) |
No Life Poster Join Date: Sep 2004 Location: HR Age: 48
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | Code: 11:25:45 SE Ultimate Unlocker v3.07 by Cruiser Team 11:25:45 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:25:45 Initializing... ! 11:25:45 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:25:45 2. Choose the phone model ! 11:25:46 3. Select the desired options ! 11:25:46 4. Please connect the phone either via USB while holding 2-5… ! 11:25:46 - or via a serial cable and double-click on it in the device list 11:26:13 Selected phone: V640 11:26:13 Connecting via Generic EMP USB Flash Device (USB5)… 11:26:13 Device driver version: 2.0.0.4 11:26:13 Device driver date: 9-12-2007 11:26:14 Connecting to the baseband CPU... 11:26:14 Entering baseband CPU service mode... 11:26:15 Detected chipset: DB3150 P2B/R2A 11:26:15 Boot mode: ROM 11:26:15 Sending loader... 11:26:18 IMEI: 3588010173XXXX 11:26:18 OTP CID: 52 11:26:18 Product type: Retail 11:26:19 Effective color: Red 11:26:20 Sending loader... 11:26:23 Communicating with server… E 11:27:25 Error: 0xB3A47971 E 11:27:25 Error: 0xB1A5E70E E 11:27:25 Error: 0xCDFE8536 E 11:27:25 Error: 0x3D1C4CBE E 11:27:25 Error: 0x3D35EAF1 E 11:27:25 Login to server failed E 11:27:25 Failed! ! 11:27:25 To report errors right-click this window |
01-10-2009, 13:01 | #10 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | Code: 11:56:37 SE Ultimate Unlocker v3.07 by Cruiser Team 11:56:37 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:56:37 Initializing... ! 11:56:37 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:56:37 2. Choose the phone model ! 11:56:37 3. Select the desired options ! 11:56:37 4. Please connect the phone either via USB while holding 2-5… ! 11:56:37 - or via a serial cable and double-click on it in the device list 11:56:40 Communicating with server… E 11:57:41 Error: 0xB3A47971 E 11:57:41 Login to server failed E 11:57:41 Failed! ! 11:57:41 To report errors right-click this window i am also having same problem /// when will it start? |
01-10-2009, 13:25 | #12 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
i heared this word " MONDAY " | |
01-10-2009, 13:53 | #14 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 182006 Status: Offline Thanks Meter: 41 | same here Code: 11:35:17 SE Ultimate Unlocker v3.06 (Beta) by Cruiser Team 11:35:17 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:35:17 Initializing... ! 11:35:17 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:35:17 2. Choose the phone model ! 11:35:17 3. Select the desired options ! 11:35:17 4. Please connect the phone either via USB while holding 2-5… ! 11:35:17 - or via a serial cable and double-click on it in the device list 11:35:55 Selected phone: C905 11:35:55 Connecting via Generic EMP USB Flash Device (USB4)… 11:35:55 Device driver version: 1.1.0.12 11:35:55 Device driver date: 9-25-2006 11:35:56 Connecting to the baseband CPU... 11:35:56 Entering baseband CPU service mode... 11:35:57 Detected chipset: DB3210 P1A/P1B 11:35:57 Boot mode: ROM 11:35:57 Sending loader... 11:35:59 IMEI: 35760202489226 11:35:59 OTP CID: 52 11:35:59 Product type: Retail 11:35:59 Effective color: Red 11:36:00 Sending loader... 11:36:04 Communicating with server… E 11:37:10 Error: 0xB3A47971 E 11:37:10 Error: 0xB1A5E70E E 11:37:10 Error: 0xCDFE8536 E 11:37:10 Error: 0x3D1C4CBE E 11:37:10 Error: 0x3D35EAF1 E 11:37:10 Login to server failed E 11:37:10 Failed! ! 11:37:10 To report errors right-click this window This seems to happen last two saturdays (my busiest day of the week ) This is the biggest problem with server based unlock solutions . Steve |
SERVER STATUS - USE Panel V 2.3.0.7 - Upgrade/Installation/Support Server Problems | GsmMunna | HWK | 1801 | 05-18-2023 13:08 |
cruiser 13.20 server problem.??? | jayanthabandara | Cruiser Suite | 5 | 12-26-2008 11:34 |
cruiser conecting problem with server | ...:::JamalMustafa:::... | Cruiser Suite | 1 | 04-08-2007 15:06 |
We need cruiser server with emma3 | MOBICOM | Cruiser Suite | 1 | 10-05-2006 21:23 |
cruiser server problem | lwilson | Cruiser Suite | 2 | 05-09-2006 11:35 |
