08-21-2007, 23:29 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Canada
Member: 219362 Status: Offline Thanks Meter: 31 | I have one now (W810i): Quote:
08-22-2007, 06:12 | #5 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Pearl of the Orient
Member: 42539 Status: Offline Thanks Meter: 182 | it can be unlock, they just dont have the restore files & or flash files on support. i've tried that before, unlock rsa & direct unlock with cruiser+, then restore firmware or flash main with other tools, like setool or ub |
08-22-2007, 06:35 | #6 (permalink) | |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | Quote:
flash main with other tool?? u kidding me??!! Cruiser can only unlock CID50 with patch ... if u flash main, locks are closed again ... | |
08-22-2007, 08:29 | #8 (permalink) |
Member: 49581 Status: Offline Thanks Meter: 73 | db2020 and db2012 CID50, all unlock by patch firmware ... and, the patch is applied to the MAIN firmware part .... not the first 128k which is used when restore firmware ... somewhere else in MAIN firmware ... if u do Remove RSA, the first 128k will be erased .... and then u direct unlock, some part of MAIN will be patched ... after that, if u restore the firmware back, the first 128k will be written back ... if u don't hv the restore file, and u chose to flash whole MAIN firmware, DO IT BEFORE DIRECT UNLOCK ... otherwise, the patched part will be over-write .. and it will become useless ... |
08-24-2007, 16:56 | #11 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 239212 Status: Offline Thanks Meter: 12 | finally did it! k310 cid 50 unlock with cruiser. (will also probaly work with w810 cid 50) 1. select k310i in phone model (important) 2. attatch phone using dcu-60 cable 3. unlock RSA 4. Flash main and fs using file from topsony (k310 cid50) (*Restore Firmware will not work - no restore files for cid 50) 5. customize fs 6. direct unlock 7. done * 10 Credits will be deducted - which was equal to 1 credit before. |
08-25-2007, 00:51 | #12 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: Subcarpathia Rzeszów City Age: 47
Member: 289243 Status: Offline Thanks Meter: 20 | Quote:
08-22-2007, 14:52 | #13 (permalink) | |
08-23-2007, 14:02 | #14 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 43
Member: 104924 Status: Offline Thanks Meter: 8 | sounds crazy!!! did you know that u can't use CID49 flash files on CID50 mobiles?do u know what happens when u flash w810 CID50with CID49 files? u'll get a message on startup saying"FATAL ERROR" i advice to not try to unlock or flash that phone since we still don't have firmware restorale or flash files, by the way MT box can do flash downgrade but there's a 4th files specialy used for downgrade |
W810 Cid 50 Unlock Possible....? | shami | FuriousGold | 5 | 07-12-2008 15:07 |
w810 cid 50 unlock by seking.... | smartecs | Seking Server | 11 | 11-25-2007 21:57 |
w810 cid 50 unlock | skkeptik2 | Sony Ericsson | 1 | 09-28-2007 19:27 |
