05-06-2007, 15:44 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 306903 Status: Offline Thanks Meter: 19 | K800, K610, W850 Starting Problem I've got 3 phones K800,K610,W850 the thing is that as soon as i press power button phones come on with White screen and Vibrate aswell but after tht nothing happens and gets stuck on white screen. Any Good solution ???????? Awaiting for ur Expert Solution ~~~~ Thnx |
05-06-2007, 16:20 | #3 (permalink) |
Freak Poster Join Date: May 2004 Age: 48
Member: 65863 Status: Offline Thanks Meter: 15 | ihad the same brp with K610 cid 51 it shows configration error so i flashed twice cid 51 different flashes from support and finalise it towice lost 2 credits after the first time lcd white vibrating continously the same after the 2 flash IC's glode ????????? |
05-31-2007, 00:09 | #7 (permalink) | |
Freak Poster Join Date: Mar 2004 Location: libya Age: 45
Member: 57196 Status: Offline Thanks Meter: 9 | Quote:
i to same after trying many differnet flashing i upgrade it to cid52 and flashed with cod52 flash and still the same white lcd with vibration any real solution for this | |
07-10-2007, 05:26 | #9 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | i think may people have same problem i have w850 when u turn on vibret n after whie screen comes and go comes n go.no body have solution. i flahe many timebut stil same i even replaced flex cable but no result. |
07-11-2007, 09:18 | #13 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | well try now to follow this as -------------------------------------------------------------------------------- I am flashing/unlocking alot whithout a prob. 1. attach 2. check for repair eerom (even if it is new no prob. just do it as a procedure) 3. attach 4. unlock rsa 5. flash the whole ARM ( forget about restore ) 6. direct unlock 7. flash the FS 8. customize 9. shut down file system |
The Following User Says Thank You to MGT SOFTWARE For This Useful Post: |
Best way for changing k750 / k800 / k610 mic | platinumLA | Sony Ericsson Hardware Repair | 5 | 10-23-2010 00:09 |
K800 & W850 not working on all networks after nulocking | adigem00 | Sony Ericsson | 9 | 05-31-2008 22:11 |
need hebrew lang for new SE K800, K610, K790 | VIZER | Universalbox | 2 | 09-08-2007 09:28 |
K800, K610, W850 Starting Problem | Fones_Clinic_Network | Universalbox | 5 | 07-04-2007 14:07 |
K800/K610 and more new phones flash files in SETOOL SUPPORT | cellularman | Cruiser Suite | 13 | 09-28-2006 09:22 |
