Post here Successful Unlocked phones With JavaUnlocker Post here Successful Unlocked phones With JavaUnlocker;) K610I Code: 17:34:31 SE A1 Java Unlocker v1.02 by Cruiser Team |
z310a movistar unlock ok;) |
w200i W200i Vivo Brasil, ok. |
Guys, it will help if you can post phone's model and phone's CID instead of name of original network. "OTP CID" is NOT Phone's CID, ignore it. Use Cruiser 13.11. If Cruiser don't show you "Phone CID:", you can see CID of your phone if you'll look at the attaching process. CID52 phone: Booting via EROM... Trying Red CID50 flash applet... Trying Red CID51 flash applet... Trying Red CID52 flash applet... Sending applet prologue... CID51 phone: Booting via EROM... Trying Red CID50 flash applet... Trying Red CID51 flash applet... Sending applet prologue... CID50 phones: Booting via EROM... Trying Red CID50 flash applet... Sending applet prologue... In other words, important is what flash applet is used as the last one. That is CID of your phone. |
w200i CD52_DB2012 ok 100% thank you |
w200 cid51, unlocked ok:) |
w850 success Code: 08:58:26 SE A1 Java Unlocker v1.02 by Cruiser Team |
K610i successfully done :):) Code: 14:51:01 SE A1 Java Unlocker v1.02 by Cruiser Team |
z310i unlocked succefully with SE A1 Java Unlocker z310i unlocked succefully with SE A1 Java Unlocker Code: 13:12:48 SE A1 Java Unlocker v1.02 by Cruiser Team |
Successful Unlock K800i Cid53 with A1JavaUnlocker v1.02 13:22:04 SE A1 Java Unlocker v1.02 by Cruiser Team 13:22:04 Initializing... ! 13:22:04 1. Choose the phone model ! 13:22:04 2. Select main firmware flash file (*.a1sw) ! 13:22:04 3. Select raw FS flash file (*.a1fs) ! 13:22:04 4. Please connect the phone while holding its C button… 13:22:22 Connecting via SEMC USB Flash Device (USB3)… 13:22:22 Device driver version: 1.0.0.8 13:22:22 Device driver date: 3-30-2006 13:22:22 Connecting to the baseband CPU... 13:22:22 Entering baseband CPU service mode... 13:22:23 Detected chipset: DB2020 13:22:23 Boot mode: EROM 13:22:23 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 13:22:23 Initializing flash files... 13:22:30 Sending loader... 13:22:30 Sending loader... 13:22:30 About to flash 45 MB of data… 13:28:34 Sending loader... 13:28:35 System starting up... 13:28:35 GDFS starting up... 13:28:59 FS starting up... 13:29:06 FS data uploading... ! 13:29:16 1. Please disconnect battery and cable from the phone! ! 13:29:16 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 13:29:16 3. Wait to customize finish ! 13:29:16 4. Turn off the phone ! 13:29:16 5. Please connect the phone while holding its C button… 13:33:01 Connecting via SEMC USB Flash Device (USB3)… 13:33:01 Device driver version: 1.0.0.8 13:33:01 Device driver date: 3-30-2006 13:33:01 Connecting to the baseband CPU... 13:33:01 Entering baseband CPU service mode... 13:33:02 Detected chipset: DB2020 13:33:02 Boot mode: EROM 13:33:02 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 13:33:02 Sending loader... 13:33:02 Sending loader... 13:33:02 Sending loader... 13:33:04 System starting up... 13:33:04 GDFS starting up... 13:33:20 FS starting up... 13:33:26 FS data uploading... ! 13:33:41 1. Please disconnect battery and cable from the phone! ! 13:33:41 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 13:33:41 3. Connect the phone again ! 13:33:41 4. If asked, Install phone drivers ! 13:33:41 5. Choose 'PHONE MODE' in the phone ! 13:34:47 After choosing 'PHONE MODE' press the Ready button 13:35:08 Connecting via SEMC WMC Device (COM16, COM15)… 13:35:08 Device driver version: 4.34.0.2705 13:35:08 Device driver date: 4-28-2006 ! 13:35:20 1. Please disconnect battery and cable from the phone! ! 13:35:20 2. Please connect the phone while holding its C button… 13:35:34 Connecting via SEMC USB Flash Device (USB3)… 13:35:34 Device driver version: 1.0.0.8 13:35:34 Device driver date: 3-30-2006 13:35:34 Connecting to the baseband CPU... 13:35:34 Entering baseband CPU service mode... 13:35:35 Detected chipset: DB2020 13:35:35 Boot mode: EROM 13:35:35 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 13:35:35 Sending loader... 13:35:36 Sending loader... 13:35:36 About to flash 1 MB of data… 13:35:54 Done. ! 13:35:54 Please disconnect battery and cable from the phone! |
Succesfully unlock w200 with A1javaUnlocker 22:09:56 SE A1 Java Unlocker v1.02 by Cruiser Team 22:09:56 Initializing... ! 22:09:56 1. Choose the phone model ! 22:09:56 2. Select main firmware flash file (*.a1sw) ! 22:09:56 3. Select raw FS flash file (*.a1fs) ! 22:09:56 4. Please connect the phone while holding its C button… 22:11:30 Connecting via SEMC USB Flash Device (USB3)… 22:11:30 Device driver version: 1.0.0.8 22:11:30 Device driver date: 3-30-2006 22:11:30 Connecting to the baseband CPU... 22:11:30 Entering baseband CPU service mode... 22:11:31 Detected chipset: DB2012 22:11:31 Boot mode: EROM 22:11:31 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB 22:11:31 Initializing flash files... 22:11:34 Sending loader... 22:11:34 Sending loader... 22:11:35 About to flash 29 MB of data… 22:15:39 Sending loader... 22:15:42 System starting up... 22:15:42 GDFS starting up... 22:16:03 FS starting up... 22:16:30 FS data uploading... ! 22:16:41 1. Please disconnect battery and cable from the phone! ! 22:16:41 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 22:16:41 3. Wait to customize finish ! 22:16:41 4. Turn off the phone ! 22:16:41 5. Please connect the phone while holding its C button… 22:19:52 Connecting via SEMC USB Flash Device (USB3)… 22:19:52 Device driver version: 1.0.0.8 22:19:52 Device driver date: 3-30-2006 22:19:52 Connecting to the baseband CPU... 22:19:52 Entering baseband CPU service mode... 22:19:52 Detected chipset: DB2012 22:19:52 Boot mode: EROM 22:19:52 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB 22:19:52 Sending loader... 22:19:52 Sending loader... 22:19:53 Sending loader... 22:19:55 System starting up... 22:19:55 GDFS starting up... 22:20:22 FS starting up... 22:20:35 FS data uploading... ! 22:20:50 1. Please disconnect battery and cable from the phone! ! 22:20:50 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 22:20:50 3. Connect the phone again ! 22:20:50 4. If asked, Install phone drivers ! 22:20:50 5. Choose 'PHONE MODE' in the phone ! 22:21:52 After choosing 'PHONE MODE' press the Ready button 22:25:35 Connecting via SEMC WMC Device (COM7, COM6)… 22:25:35 Device driver version: 4.34.0.2705 22:25:35 Device driver date: 10-24-2006 ! 22:25:47 1. Please disconnect battery and cable from the phone! ! 22:25:47 2. Please connect the phone while holding its C button… 22:25:56 Connecting via SEMC USB Flash Device (USB3)… 22:25:56 Device driver version: 1.0.0.8 22:25:56 Device driver date: 3-30-2006 22:25:56 Connecting to the baseband CPU... 22:25:56 Entering baseband CPU service mode... 22:25:56 Detected chipset: DB2012 22:25:56 Boot mode: EROM 22:25:56 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB 22:25:56 Sending loader... 22:25:57 Sending loader... 22:25:57 About to flash 1 MB of data… 22:26:18 Done. ! 22:26:18 Please disconnect battery and cable from the phone! Thanks to Mainboard for best help |
guys, from now please post logs only from version 1.10, thanks! |
Thank you Mainboard . I have unlock successful 8 w200 from O2. CID52 |
K800i CID53 using version 1.10 without flashing Very fast!! Code: 21:33:18 SE A1 Java Unlocker v1.10 by Cruiser Team |
SUCCESSFUL UNLOCK K320 THX CRUISER TEAM Code: 11:05:51 SE A1 Java Unlocker v1.10 by Cruiser Team |
