07-08-2005, 10:54 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Heaven of course! Age: 44
Member: 93497 Status: Offline Thanks Meter: 2 | Cruiser SCreader&Dongle&Boot problems STEPbySTEP?!? now from version 4.20 I saw there more problems sometimes to run Cruiser. 1 Sometimes s/n ????????? (sc dongle not working) 2 Sometimes it takes 1 minutes to open the program 3 Sometimes you have to restart before use it Can someone tell me a STEPbySTEP clean install of CRUISER, SC READER SERVICE, DONGLE etc... but erasing and installing very well, because it's really boring expecially: IT's working perfectly, turn off pc, turn on and s/n ???????? problem, why? I didn't move the dongle, I didn't stop any service, I didn't do anything. I did a lot of test, but no way to find a reason why sometimes any pc with cruiser have to have his BAD MOMENT !! eheheh thanks |
07-08-2005, 12:15 | #2 (permalink) |
Member: 93497 Status: Offline Thanks Meter: 2 | Ok I solved something: I delete and copy back from original cd the four SC dll files involved. Now when installing CRUISER the installer uninstall Sc service, and reinstall it without problem and set it to automatic. But 90% of times I start Cruiser always stuck in "phase cronus" for 30 seconds, and after when program run always the same s/n: ????-???? what can I do? |
07-08-2005, 12:36 | #3 (permalink) |
Member: 93497 Status: Offline Thanks Meter: 2 | I'm using the SC/PC diagnostic, and I can see the pc is viewing the dongle immediately when I plug it, under device system of windows control pannel too, immeditely when I plug the dongle SC reader and SC smart card are viewed! what's the problem so? what can I do to make this CRUISER not to say BOX NOT CONNECTED ?????? ????? please help... ?: Under setting there is autorization have I to select something different? thanks |
07-08-2005, 16:19 | #5 (permalink) | |
Member: 93497 Status: Offline Thanks Meter: 2 | Quote:
it's just sometimes, and I notice this thing on all PCs.. sometimes CRUISER start is not working... but perhaps it's now so much because as you ask me I'm using it with setool.... thanks | |
07-08-2005, 16:27 | #6 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: somewhere nice and warm Age: 61
Member: 38800 Status: Offline Thanks Meter: 1 | Quote:
Remove the SEtool dongle and everything is fine! This thing is good for nothing at the moment Or, go to settings tab in cruiser, select authentication and there you will see something like axalto e-gate1 and axalto e-gate2, choose the one for cruiser and everything should be fine! wbr Markus | |
07-08-2005, 16:32 | #7 (permalink) | |
is the best Z1010 unlock with ONLY ONE CLICK and 4 second, so try how many pieces we do in the time you do one with cruiser ! a part this... I already tried it is not that, you can select what you want but when Cruiser doesn't want to read, doeasn't want to READ ! thanks | |
07-08-2005, 17:02 | #8 (permalink) | |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | Quote:
07-08-2005, 22:38 | #9 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | It's possible that sometimes Cruiser gets confused and tries to read SC data from another card. In that case, open your Cruiser, click on Settings. Go to the "Authentication" tab. Pull down the menu there. Instead of having "default" ticked, select one of the other SC options (if you have more than 1 SC card plugged in, there's be at least 2 SC's to pick from) Once you've manually set it, close Cruiser and reopen it. If it doesn't work still, pick the other SC and try again. This should fix the problem. |
07-08-2005, 23:20 | #11 (permalink) | |
is it for the 4 sec of setool?? I didn't say anything, just the true it's a good product for SE and quick in something like unlocing... | |
07-08-2005, 23:47 | #12 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | Lucky7Napoleon: All he's saying is that to remove SIM Locks on new RSA ARM phones, you do not need to click "Unlock RSA" first of all (like you must to do some other operations), you can just click "Direct Unlock" I don't think it's quite 4 seconds, but it's pretty quick. |
Cruiser BIG problem - help me | Spacewalker | Cruiser Suite | 7 | 03-26-2007 14:19 |
To cruiser team problem with my cruiser pro2 | ami236 | Cruiser Suite | 10 | 10-27-2006 20:46 |
Cruiser Installation Problem | tical | Cruiser Suite | 2 | 05-28-2005 21:42 |
Fighter or Cruiser Installation Problem | Cables | Cruiser Suite | 0 | 12-26-2004 21:04 |
Cruiser Installation Problem | livewirecebu | Cruiser Suite | 12 | 12-26-2004 12:19 |
