problem RSA unlock k700i Hellw, i try to unlock the RSA of k700i but it doestn unlock. i git the this log. can somebody help me please. Version 7.10 beta ready! Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 29 Phone color: Brown Flash certificate: A1_SEMC Trying Brown CID29 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 29 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 29 Primary certificate color: Brown Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is normal. Use the Unlock RSA function first! Restarting phone... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Defeated! Sending CS applet... Done. Phone automatically detached. and i git this error message. No response from applet Error: Could not initialize GDFS access. |
hellwwwwwwwwwwwwwwwwwwwwwww Hellw, is there nobody to help me all this time. i am waiting for you cruiser teame. the phone is now doesnt work now. Iam sill waiting for you. |
Try using Cruiser v6.10 Phone should work fine if you just pull the battery and place it back on. |
:D yes with 7.10 i receive white screen phone...need to reflash it..bug inside 7.1...very interesting that 3 min. before have unlocked k700i same version same cid without problem...phone work ok 100%...next one white screen...and today is not witches night...:D |
Hallo thanks for your help but i hove still the same probleem also with the ver.6,10. i git this probleem and sorry for my bad english laguage. Version 6.10 ready! Charging ON... Charging OFF... Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 29 Phone color: Red Flash certificate: A1_SEMC Trying Red CID29 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 29 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 29 Primary certificate color: Red Secondary certificate not found. OSE configuration not found. Done. The phone contains recovery certificate! You MUST reflash the main firmware part! Analyzing RSA protection... RSA protection is normal. Use the Unlock RSA function first! Restarting phone... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... i am still waiting for your help please. thaks |
You have to reflash the firmware See the note in the log, telling you to reflash the firmware? That means you have to reflash the firmware. |
thanks m8 i already have done it...but question was why same phone/same soft version/same cid/ one unlocked without flashing other need to flash...Need to know... |
maybe it was not a new phone or somebody tried to unlock with free-other softwear |
yes..that is something reasonable...even if phone have plastic envelope on screen..i use setool/usbsmart/cruiser/gti...so noone of them untill now have damaged phone...Cruiser is very trustfull tool...you can not make mistake couse Lead have programmed working steps before, that is not case in other 3 tools... |
I had something similiar with a red cid 29 k700i. As this is the first time I've used my cruiser I panicked and tried allsorts I kept reflashing it and got allsorts of problems.I then removed my (CHEAP ) usb hub and then flashed the phone and it worked . Check your connections ! and don't use cheap or cloned equipment. Steve |
lower the baud rate. that helps me when i do k750 or w800 |
Hello hi i tried it with the absolut new battery and full charged. now i can flash the ARM and write raw FS, but i get in the log that i must to reflash the firmware and now i dont fine enywere flash firmwhere. can somebody please tell me how i must reflash the firmware. thanks Again. Version 6.10 ready! Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 29 Phone color: Red Flash certificate: A1_SEMC Trying Red CID29 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 29 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 29 Primary certificate color: Red Secondary certificate not found. OSE configuration not found. Done. The phone contains recovery certificate! You MUST reflash the main firmware part! Analyzing RSA protection... RSA protection is weak. RSA protection weakness type: PERMANENT |
