Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 01-16-2009, 12:28   #16 (permalink)
Member: 60039
Thanks Meter: 14
  13:27:28  SE S1 Flasher & Unlocker v1.00 by Cruiser Team
  13:27:28  Initializing...
! 13:27:28  1. Choose the phone model
! 13:27:28  2. For flashing, select flash files and additional options
! 13:27:28  3. Double-click on the appropriate device (serial cable)
  13:27:38  Connecting via Generic FTDI Cable (COM3)…
  13:27:38  Device driver version: 1.0.2154.0
  13:27:38  Device driver date: 4-16-2004
! 13:27:38  Connect the phone now
E 13:27:38  Error: 0x5E2C7C55
E 13:27:38  Error: 0xC3DD1DE5
E 13:27:38  Error: 0xFBBEF882
E 13:27:38  Error: 0x1DDC1593
E 13:27:38  Failed to start communication
Old 01-16-2009, 13:06   #17 (permalink)
FilipLudvik's Avatar
Member: 135110
Thanks Meter: 302
Originally Posted by wikad1 View Post
This platform have a new chipset not supported with any tool? But just with log in setool
you are right. Cruiser team is preparing it without credits, I guess.
Old 01-17-2009, 04:33   #18 (permalink)
Member: 200475
Thanks Meter: 37
Hi
Can someone answer the original problem of this thread ? I don't have any error message when unlock T303 but the phone still lock. Any idea ? pls advice.
tks
SS
Old 01-18-2009, 23:54   #19 (permalink)
Member: 200475
Thanks Meter: 37
Any update or adivce ? I have phones waiting. thank you.
SS
Old 01-20-2009, 03:05   #20 (permalink)
Member: 274214
Thanks Meter: 4
Unlock R306?
Originally Posted by GLaDOS View Post
Hi,
To unlock the phone, choose "Unsigned mode" and check the "Unlock" box.
If an error occurs, please post the error log, otherwise we cannot help.
Regards
GLaDOS
Hi,
Do i have to select a flash file for unlock? If so, will it be a FW file or customized file? Thank Bro
Old 01-20-2009, 04:12   #21 (permalink)
Member: 274214
Thanks Meter: 4
R306 unlock
I can flash R306 "signed" with a customization file only, no problem at all.
but, on the same phone and with the same flash file, I couldn't unlock it with "unsigned" - "unlock", here is the log for failed unlock,
  14:05:25  SE S1 Flasher & Unlocker v1.00 by Cruiser Team
  14:05:25  Initializing...
! 14:05:25  1. Choose the phone model
! 14:05:25  2. For flashing, select flash files and additional options
! 14:05:25  3. Double-click on the appropriate device (serial cable)
  14:05:51  Connecting via Generic FTDI Cable (COM14)…
  14:05:51  Device driver version: 1.0.2176.0
  14:05:51  Device driver date: 12-12-2005
! 14:05:51  Connect the phone now
  14:05:51  Connecting to the baseband CPU...
  14:06:07  Reading TA…
  14:06:18  Reading EROM…
E 14:06:48  Error: 0x714C6E71
E 14:06:48  Error: 0x9051B62B
E 14:06:48  Error: 0x747DD20E
E 14:06:48  Error: 0x4AA1308E
E 14:06:48  Error: 0xAEE02F1D
E 14:06:48  Error: 0x59E001A2
E 14:06:48  Failed!
! 14:06:48  Please disconnect battery and cable from the phone!
! 14:06:48  To report errors right-click this window
Old 01-20-2009, 20:11   #22 (permalink)
Member: 670274
Thanks Meter: 165
This is a cable/driver problem
GLaDOS
Old 01-20-2009, 20:19   #23 (permalink)
Member: 670274
Thanks Meter: 165
@steca, R306:
1) in general, there is no need to flash the phone to be unlocked.
2) the error seems to be a backup problem, we need to investigate it
@preshaust:
I have already answered your question - you have not choosed the correct options. If you choose them, you can either get your phone unlocked or get an error meaning the phone cannot be unlocked because of new chipset revision
GLaDOS
The Following User Says Thank You to GLaDOS For This Useful Post:
Old 01-22-2009, 13:14   #24 (permalink)
Member: 200475
Thanks Meter: 37
@steca, R306:
@preshaust:
GLaDOS
a new version 1.01 has released, is related error/problem resoluted already for this model ? pls advise. thank you.
SS
Old 01-27-2009, 02:05   #25 (permalink)
Member: 274214
Thanks Meter: 4
R306 unlock
I have tried V1.01 to unlock R306, Same problem.
Old 01-27-2009, 19:09   #26 (permalink)
Member: 670274
Thanks Meter: 165
@ all
S1 Flasher & unlocker can unlock only the old cihpset hw revision. Such a phone can be unlocked by choosing Unsigned mode and Unlock. If this fails with error 0x7E23C4B3, the only possibility to unlock is to use D-Unlocker / Full Unlocker applications, but it costs some credit portion
(see http://forum.gsmhosting.com/vbb/show...4&postcount=28 for details)
@ Steca, R306:
I have inspected it, there is a problem with backup, and will be fixed in next release.
GLaDOS
Old 01-29-2009, 16:25   #27 (permalink)
ikkks's Avatar
Member: 621455
Sonork: key4unlock
Thanks Meter: 119
  19:06:21  SE S1 Flasher & Unlocker v1.01 by Cruiser Team
  19:06:21  Initializing...
! 19:06:21  1. Choose the phone model
! 19:06:21  2. For flashing, select flash files and additional options
! 19:06:21  3. Double-click on the appropriate device (serial cable)
  19:07:11  Connecting via Generic FTDI Cable (COM6)…
  19:07:11  Device driver version: 2.0.0.0
  19:07:11  Device driver date: 5-19-2006
! 19:07:11  Connect the phone now
  19:07:12  Connecting to the baseband CPU...
E 19:07:56  Error: 0x06EB86E0
E 19:07:56  Error: 0x7E23C4B3
E 19:07:56  Error: 0x275F2EE0
E 19:07:56  Failed!
! 19:07:56  Please disconnect battery and cable from the phone!
! 19:07:56  To report errors right-click this window
Old 01-30-2009, 20:46   #28 (permalink)
Member: 670274
Thanks Meter: 165
@ikkks
see one post above
Old 02-07-2009, 22:20   #29 (permalink)
Black_Daimond's Avatar
Member: 179391
Thanks Meter: 57
  17:17:32  SE Full Unlocker v2.32 by Cruiser Team
  17:17:32  Initializing...
! 17:17:32  1. Please see the documentation first (a PDF installed with the application)
! 17:17:32  2. Make sure the appropriate phone modem drivers are installed (if applicable)
! 17:17:32  3. Fill in the connection settings under settings tab
! 17:17:32  4. Turn the phone ON
! 17:17:32  5. Connect the phone…
  17:17:35  Connecting via Cruiser UC-10 Cable (COM14)…
  17:17:35  Device driver version: 1.0.2176.0
  17:17:35  Device driver date: 12-12-2005
  17:17:35  Starting communication...
  17:17:36  Connecting to the baseband CPU...
E 17:18:41  Error: 0x11990C76
E 17:18:41  Error: 0x03FA0F16
E 17:18:41  Error: 0x28FF3CA4
E 17:18:41  Failed!
! 17:18:41  Please disconnect battery and cable from the phone!
! 17:18:41  To report errors right-click this window
Old 02-07-2009, 22:28   #30 (permalink)
Member: 135110
Thanks Meter: 302
update the driver for serial cable and try again.
.: New release: S1 Flasher & Unlocker v2.05 - Instant S1 unlock in many languages :. Mizar Cruiser Suite 71 09-16-2009 05:59
.: Crusier Suite S1 Flasher & Unlocker: Instant unlock of all S1, no more waiting :. Mizar Main Sales Section 0 05-26-2009 10:33
.: Crusier Suite S1 Flasher & Unlocker: Instant unlock of all S1, no more waiting :. Mizar Main Sales Section 0 03-27-2009 13:28
.: New release: S1 Flasher & Unlocker v2.05 - Instant S1 unlock, GUI in many langs :. Mizar Service Products News & Updates 0 03-25-2009 19:38
.: CruiserSuite S1 Flasher & Unlocker v2.03 released - Instant S1 unlock supported :. Mizar Cruiser Suite 69 03-23-2009 19:35
Page generated in 0.24545 seconds with 9 queries
