10-29-2008, 14:33 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Wien,Austria
Member: 45985 Status: Offline Thanks Meter: 96 | Problem with w880 cid The phone came to me dead. I really have no idea what to try or what can be wrong. Any hint is welcome ! BR Code: System diagnostics passed. Version 13.20 ready! [ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x9900 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Trying CID53 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 070703 1229 NPA4_CXC1329130_DB2020_... Flash manufacturer: ST Microelectronics Flash ID: 0x2019 OTP Security Level: 1 (Retail) OTP CID: 51 Phone CID: 49 Phone color: Brown Sending applet... Applet ID: 060919 0941 HANCXC1329134_DB2020_PR... Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 29 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Phone hardware initialized OK Code: 14:22:20 SE Ultimate Unlocker v3.02 by Cruiser Team 14:22:20 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 14:22:20 Initializing... ! 14:22:20 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 14:22:20 2. Choose the phone model ! 14:22:20 3. Select the desired options ! 14:22:20 4. Please connect the phone either via USB while holding 2-5… ! 14:22:20 - or via a serial cable and double-click on it in the device list 14:22:44 Selected phone: W880/W888 14:22:44 Connecting via Cruiser UC-10 Cable (COM3)… 14:22:44 Device driver version: 1.0.2154.0 14:22:44 Device driver date: 4-16-2004 14:22:44 Connecting to the baseband CPU... 14:22:45 Entering baseband CPU service mode... 14:22:45 Detected chipset: DB2020 14:22:45 Boot mode: ROM 14:22:45 Sending loader... 14:22:46 IMEI: 35464901046121 14:22:46 OTP CID: 51 14:22:46 Effective CID: 49 14:22:46 Restarting phone … 14:22:48 Sending loader... E 14:22:53 Error: 0x916000B5 E 14:22:53 Error: 0x10BE36DC E 14:22:53 Error: 0x59AF7680 E 14:22:53 Failed! ! 14:22:53 To report errors right-click this window |
10-29-2008, 15:46 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | I´ve said many times what to do. write this using Cruiser 13.20: http://ultimate.philipfotos.com/DB20..._to_Red53.a1sw then repeat unlocking process using Ultimate Unlocker 3.02 |
10-29-2008, 16:32 | #3 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | SE A1 Fast Java Unlocker-100000000% unlock Supported interfaces: DCU-60 and DCU-65. Unlocking procedure (manual mode) Case 1 (appropriate rest-file is available) 1. Choose the phone model. 2. Connect the phone while holding its 'C' button. 3. Wait until the program finishes and asks you to continue the following steps: 4. Disconnect the cable from the phone. 5. Insert either a test-card or SIM-card which the phone accepts to the phone. - we recommend to use test-card, if you want to use a common SIM-card, make sure that: - the phone accepts the SIM-card - you know the PIN of the SIM-card 6. Power on the phone by pressing the power on/off button. 7. Go to the menu 'Entertainment' -> 'Games' and select/run the application 'executor' 8. Wait few seconds until the phone restarts by itself 9. Then the phone is unlocked, you may delete the 'executor' application from the phone Case 2 (rest-file not available) 1. Choose the phone model. 2. Connect the phone while holding its 'C' button. 3. Wait until the program performs operations. Then it asks you to continue the following steps: 4. Disconnect the cable from the phone. 5. Power on the phone by pressing the power on/off button. - this is required, because the rest-file is created during 6. Find the created rest-file in your phone file folders, with the following name: filename should look like: R1A001_CXC1250000_GENERIC_XX.rest 7. Download the rest-file into the following folder (see documentation): - you can download the rest-file by attaching the phone in mass-storage mode and just copying it, by attaching powered-on phone using PC-Suite application, via bluetooth file transfer, etc. - file is located in folder "Phone Memory \ Other" and "Card \ Other", if data-card is present The destination folder should look like: C:\Documents and Settings\<USER>\Application Data\Cruiser Suite\SE A1 Fast Java Unlocker After you copy the file, application informs: "Rest-file found" 8. Now the rest file is available, continue with Case 1 - rest-file available procedure Unlocking procedure (automatic mode) ... coming soon ... |
10-30-2008, 17:18 | #4 (permalink) |
Member: 45985 Status: Offline Thanks Meter: 96 | No go. CID changed to RED 53 but i can´t boot it via rom,always booting over erom Tryed with 2+* and 2+5 Any other suggestion? thx Code: 17:15:38 SE Ultimate Unlocker v3.02 by Cruiser Team 17:15:39 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 17:15:39 Initializing... ! 17:15:39 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 17:15:39 2. Choose the phone model ! 17:15:39 3. Select the desired options ! 17:15:39 4. Please connect the phone either via USB while holding 2-5… ! 17:15:39 - or via a serial cable and double-click on it in the device list 17:15:53 Selected phone: W880/W888 17:15:53 Connecting via SEMC USB Flash Device (USB1)… 17:15:53 Device driver version: 2.1.0.0 17:15:53 Device driver date: 3-20-2008 17:15:53 Connecting to the baseband CPU... 17:15:53 Entering baseband CPU service mode... 17:15:54 Detected chipset: DB2020 17:15:54 Boot mode: EROM 17:15:54 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_FLAFLA_SIBLEY_SEMCUSB E 17:15:54 Error: 0x889C690F E 17:15:54 Unsupported boot mode ! 17:15:54 Please boot via ROM E 17:15:54 Failed! ! 17:15:54 To report errors right-click this window |
10-30-2008, 18:06 | #6 (permalink) |
Member: 45985 Status: Offline Thanks Meter: 96 | Here´s the log using uc-10 Code: 18:04:04 SE Ultimate Unlocker v3.02 by Cruiser Team 18:04:04 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:04:04 Initializing... ! 18:04:04 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:04:04 2. Choose the phone model ! 18:04:04 3. Select the desired options ! 18:04:04 4. Please connect the phone either via USB while holding 2-5… ! 18:04:04 - or via a serial cable and double-click on it in the device list 18:04:25 Selected phone: W880/W888 18:04:25 Connecting via Cruiser UC-10 Cable (COM3)… 18:04:25 Device driver version: 1.0.2154.0 18:04:25 Device driver date: 4-16-2004 18:04:26 Connecting to the baseband CPU... 18:04:26 Entering baseband CPU service mode... 18:04:26 Detected chipset: DB2020 18:04:26 Boot mode: ROM 18:04:26 Sending loader... 18:04:27 IMEI: 35464901046121 18:04:27 OTP CID: 51 18:04:27 Effective CID: 53 18:04:27 Restarting phone … 18:04:29 Sending loader... 18:04:30 Communicating with server… ! 18:04:34 News: Your credit consumption policy: Level 4 (Senior) 18:04:34 Remainig credit (supreme): 7.85 18:04:37 Remainig credit (supreme): 7.85 18:04:37 Restarting phone … 18:04:40 Sending loader... 18:04:45 Code NCK for relock: 1633037808973319 18:04:45 Code NSCK for relock: 8431821482603422 18:04:45 Code SPCK for relock: 3858776796599009 18:04:45 Code CCK for relock: 4998937012502166 18:04:45 Code PCK for relock: 5913665951715001 18:04:45 Code ESLCK for relock: 5509470862342855 18:04:45 Code NCK for unlock: 9812304049544326 18:04:45 Code NSCK for unlock: 3612999451109550 18:04:45 Code SPCK for unlock: 8600102978847809 18:04:45 Code CCK for unlock: 9297902073292992 18:04:45 Code PCK for unlock: 9004535561427874 18:04:45 Code ESLCK for unlock: 4776767082813525 18:04:45 To enter a code, type < * * < on the phone with SIM-card inserted E 18:04:45 Error: 0xA65A2F15 E 18:04:45 Error: 0xB7CDD438 E 18:04:45 Error: 0x59AF7680 E 18:04:45 Failed! ! 18:04:45 To report errors right-click this window |
Unlock problem with W880 | alain537 | Seking Server | 6 | 04-13-2008 20:32 |
BIG problems with k618 cid 49 | SicilianBoy | FuriousGold | 3 | 01-15-2008 09:59 |
Problem with W810i CID 49 | tito millo | MT-BOX | 2 | 11-27-2007 17:40 |
BIG problem with unlock CID 52 | CangaGsmTeam | SETool2 | 27 | 11-23-2007 20:48 |
problem with k700 CID | dorinheimbach | Sony Ericsson | 2 | 03-16-2006 04:54 |
