Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 05-09-2006, 17:23   #1 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
"fw_restore_files_red49"
HI masters
Real good news from CRUISER team.Thanks 4 your great updates.I have a question.What are the files in support area called "FW_RESTORE_FILES_RED49"?What's their function please?
Old 05-09-2006, 17:32   #2 (permalink)
fonecellar's Avatar
Member: 545165
Thanks Meter: 578
Originally Posted by meisam
HI masters
Please read leads support threads on the update issue
Old 05-09-2006, 17:35   #3 (permalink)
mobilextreme's Avatar
Member: 91298
Thanks Meter: 6
Basically...
If you want to unlock a new CID_49 via NONE TP then you have to do the following.
Connect phone as normal.
Change certificate to brown 49, BUT if you cannot change certificate you have to remove RSA instead, now the phones that cant change certificate will give an error on erasing_flashblock at 99% or 100% when changing certificate.
So if this happens and you cannot change the colour of certificate, then click REMOVE RSA, once removed, reconnect the phone, do your direct unlock and whilst your doing it - it will display your FW (firmware) Type and revision in the Log window.
Make a quick note of this becuase removing RSA actually kill's the phone so it can bypass protection and unlock it, now to revive it - reconnect after unlocking, and unzip FW Restore files, click flash ARM (MAIN SW) and select appropriate FW Restore file.
If it fails when sending applet - then best thing to do is change baudrate speed to 115200bps - this is what I did and it went through like a breeze...
If not then upgrade to 9.54 - this bug was fixed in this, but i cannot confirm yet.
FINALLY - IF THE PHONE COLOUR CAN BE CHANGED WITHOUT ERROR, THEN NO NEED TO REMOVE RSA, JUST UNLOCK AND PUT BACK CERTIFICATE VIA FOTA FILE OR CERTIFICATE OPTION.
Hope this help's.
LEAD: any change of making this a sticky - valuble information to new and old users.
br,
Danny.
Old 05-09-2006, 17:37   #4 (permalink)
freewaycomms's Avatar
Member: 88410
This would be so much easier if it was a one-button operation without user interference - it might stop some of the questions people have if it were automated fw_restore on cert change when required
Lead: how about it? make this tool even better!
FWC
Old 05-09-2006, 18:02   #5 (permalink)
fonecellar's Avatar
Member: 545165
Thanks Meter: 578
HEY @freewaycomms twice you posted about this one button, or making tool even better,
lead say impossibilities executed at once, miracle's take a little longer
so please think and wait
Old 05-10-2006, 01:20   #6 (permalink)
Member: 88410
sorry for being silly, but isn't usb-smart doing it one-button op?
I appreciate that cruiser might run a totally different routine, but surely there must be some way of auto-attach/ident/flash
Oh well, just a thought - cheers
FWC
Old 05-10-2006, 04:38   #7 (permalink)
Member: 53556
are thses restore files universal to all firmware of said model if not might end up to some difficulty.....
Old 05-10-2006, 05:08   #8 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
No, they're not. If required though you can just do a full reflash of ARM and RawFS.
Old 05-10-2006, 06:52   #9 (permalink)
airy's Avatar
Member: 94720
Thanks Meter: 6
mods please delete my post if you want. I found it.
Page generated in 0.19711 seconds with 8 queries
