Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 05-01-2009, 18:15   #16 (permalink)
freeman2001's Avatar
Member: 206476
Thanks Meter: 459
Error flashing block at address: 0x44140000
check your battery mybe low
wbr
Old 05-02-2009, 01:35   #17 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
Originally Posted by THE CLASH View Post
You may use cruiser 13.20, make sure Free cid 52 box is ticked first in settings.
First Attach mobile.
Go to the Security RSA tab and press the Unlock RSA button.
The procedure takes cca 5 minutes to finish and you will be asked to disconnect the phone and reinsert its battery two times at the end of the operation.
· Note: Now the main firmware is overwritten, so it has to be reflashed by a suitable main FW flash file.
· Flash the main firmware and raw filesystem to the phone. CID and certificate color do not matter at all.
· Now go to the Locks tab and press the Direct Unlock button.
· Customize the phone.
After card registration-I cannot find Direct Unlock button in cruiser 13.20
Old 05-02-2009, 07:04   #18 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
Thanks Meter: 59
Originally Posted by fun View Post
My w580i dead after unsuccessful flash, after I have tried to flash in recovery mode, but unsuccessful again.
Connecting via SEMC DCU-60...
Connect the phone while holding its buttons 2 and 5!
USB connection established.
Baseband chip ID: 0x9900
Protocol version: 3.1
Booting via ROM...
Trying CID52 recovery applet...
Sending applet prologue...
Sending applet body...
Time spent entering bootstrap: 0s
Initializing phone hardware...
Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_...
Flash manufacturer: Intel
Flash ID: 0x897E
OTP Security Level: 1 (Retail)
OTP CID: 51
Phone hardware initialized OK
[ --- Flash Main Firmware --- ]
Flash file: "W580i_CXC1123362_Generic_R8BE001_Red52.a1sw"
Waiting for flash file to load...
Preparing to program flash...
Programming flash...
Script error: Flash error [13.20.78]
find correct cid...it is cid 51 or 52?
the procedure is choose identify boot thick all anylize and display more info.
Old 05-02-2009, 10:59   #19 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
I charged the battery and flashed it again with different file. Success, the phone is alive again. Thanks BR.
Last edited by Mainboard; 05-02-2009 at 11:16. Reason: one thread - one problem only
Old 05-02-2009, 23:37   #20 (permalink)
Member: 231189
I cannot unlock w580i with fast java unlocker, its always freeze up on starting up FS...
  19:09:50  SE A1 Fast Java Unlocker v1.01 by Cruiser Team
  19:09:50  Initializing...
! 19:09:50  1. Please see the documentation first (tab 'Info')
! 19:09:50  2. Choose the phone model
! 19:09:50  3. Please connect the phone while holding its C button…
  19:10:12  Connecting via SEMC USB Flash Device (USB1)…
  19:10:12  Device driver version: 1.1.0.12
  19:10:12  Device driver date: 9-25-2006
  19:10:12  Connecting to the baseband CPU...
  19:10:12  Entering baseband CPU service mode...
  19:10:13  Detected chipset: DB2020
  19:10:13  Boot mode: EROM
  19:10:13  EROM version: R3A022      prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  19:10:13  Sending loader...
  19:10:15  Starting up System...
  19:10:15  Starting up GDFS...
  19:10:31  Starting up FS...
I'm also experiencing some wierd problems with Fast Java Unlocker, too. It was working fine for the past couple of months until today I tried to unlock a W580. It constanly freezes at "Starting up FS..." then right away it'll show some kind of "Runtime Error" and Fast Unlocker will shut down and asking me if I want to report error to Microsoft. At first I thought it was my new installed anti virus program that's causing it. So I completely uninstalled my anti virus but the problem still exists. So I finally decided to uninstall and reinstall Java Unlocker but its now giving me this error:
  14:59:21  SE A1 Fast Java Unlocker v1.01 by Cruiser Team
  14:59:21  Initializing...
! 14:59:21  1. Please see the documentation first (tab 'Info')
! 14:59:21  2. Choose the phone model
! 14:59:21  3. Please connect the phone while holding its C button…
  14:59:34  Connecting via SEMC USB Flash Device (USB2)…
  14:59:34  Device driver version: 2.2.0.2
  14:59:34  Device driver date: 12-5-2008
  14:59:34  Connecting to the baseband CPU...
  14:59:34  Entering baseband CPU service mode...
  14:59:34  Detected chipset: DB2020
  14:59:34  Boot mode: EROM
  14:59:34  EROM version: R3A022      prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_FLAFLA_SIBLEY_SEMCUSB
  14:59:35  Sending loader...
E 14:59:35  Error: 0xEC82FA8E
E 14:59:35  Error: 0x4B055A8F
E 14:59:35  Error: 0xA4CAA1B4
E 14:59:35  Error: 0xF1DA36B0
E 14:59:35  Error: 0xEACC0A85
E 14:59:35  Error: 0xF77BD910
E 14:59:35  Error: 0xA8A269DB
E 14:59:35  Error: 0xB63595F9
E 14:59:35  Cable disconnect detected
E 14:59:35  Failed!
! 14:59:35  Please disconnect battery and cable from the phone!
! 14:59:35  To report errors right-click this window
At the end I unlocked it with Cruiser 13.2 since it's CID 49. But will very much like to find out why all this is happening.
Thanks in advance for any help.
Old 05-04-2009, 06:04   #21 (permalink)
Member: 764493
Thanks Meter: 25
I get stuck at "starting up FS" as well.
just wait like 10 seconds and unplug the phone, the executor file still goes into the phone.
the program crashes, dont worry about it.
The Following User Says Thank You to ricky2k1 For This Useful Post:
Old 05-04-2009, 08:28   #22 (permalink)
Member: 57803
Thanks Meter: 99
I posted the answer to all your problems 2 days ago at the start of this thread, it's just a driver problem.
The best driver to use is 2.1.0 this one works on all Sony Ericssons to unlock or flash with Java or fast Java.
I have had exactly the same problems in the past and 2.1.0 has always cured the fault.
The Following User Says Thank You to paulb For This Useful Post:
.:: 03/07/2008 CruiserSuite A1 Fast Java Unlocker v1.01 released ::. Mizar Cruiser Suite 45 11-09-2009 14:53
z710 unlocked by A1 fast java unlocker 1.01 [email protected] Cruiser Suite 0 09-29-2009 14:14
W200i unlock by SE A1 Fast Java Unlocker [email protected] Cruiser Suite 1 11-15-2008 13:30
C902 Successfull Unlock with SE Ultimate Unlocker v1.01 by Cruiser Team Anees-ur-rehman Cruiser Suite 0 09-29-2008 11:41
CruiserSuite A1 Fast Java Unlocker v1.01 released Leonard_Kyle Cruiser Suite 0 07-03-2008 23:15
Page generated in 0.17884 seconds with 9 queries
