04-24-2010, 08:28 | #1 (permalink) |
Banned Thanks Meter: 346 | server problem Code: 12:57:50 SE Ultimate Unlocker v5.04 by Cruiser Team 12:57:50 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:57:50 Initializing... ! 12:57:50 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:57:50 2. Choose the phone model ! 12:57:50 3. Select the desired options ! 12:57:50 4. Please connect the phone either via USB while holding 2-5… ! 12:57:50 - or via a serial cable and double-click on it in the device list 12:57:52 Communicating with server… E 12:57:55 Error: 0x1F41CF97 E 12:57:55 Error: 0x659FFCB8 E 12:57:55 Error: 0x8F522B71 E 12:57:55 Cannot connect to the server E 12:57:55 Check server host name and port in the settings E 12:57:55 Failed! ! 12:57:55 To report errors right-click this window |
The Following User Says Thank You to cellcarekphb For This Useful Post: |
04-24-2010, 08:41 | #2 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | Same problem here: Quote:
04-24-2010, 08:48 | #3 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 621455 Status: Offline Sonork: key4unlock Thanks Meter: 118 | me tooooooooo Code: 13:17:33 SE Ultimate Unlocker v3.07 by Cruiser Team 13:17:33 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 13:17:33 Initializing... ! 13:17:33 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 13:17:33 2. Choose the phone model ! 13:17:33 3. Select the desired options ! 13:17:33 4. Please connect the phone either via USB while holding 2-5… ! 13:17:33 - or via a serial cable and double-click on it in the device list 13:17:39 Communicating with server… E 13:17:43 Error: 0x1F41CF97 E 13:17:43 Cannot connect to the server E 13:17:43 Failed! ! 13:17:43 To report errors right-click this window |
04-24-2010, 10:01 | #7 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Bali Island - Indonesia
Member: 589534 Status: Offline Thanks Meter: 251 | Code: 16:59:09 SE Ultimate Unlocker v5.04 by Cruiser Team 16:59:09 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 16:59:09 Initializing... ! 16:59:09 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 16:59:09 2. Choose the phone model ! 16:59:09 3. Select the desired options ! 16:59:09 4. Please connect the phone either via USB while holding 2-5… ! 16:59:09 - or via a serial cable and double-click on it in the device list 16:59:47 Communicating with server… E 16:59:54 Error: 0xE1E2479D E 16:59:54 Error: 0x1F41CF97 E 16:59:54 Error: 0x659FFCB8 E 16:59:54 Error: 0x8F522B71 E 16:59:54 Cannot connect to the server E 16:59:54 Check server host name and port in the settings E 16:59:54 Failed! ! 16:59:54 To report errors right-click this window please fix asap......... |
04-24-2010, 11:45 | #10 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 534777 Status: Offline Thanks Meter: 214 | Server problem, please check asap!!!!! cannot connect to server. please have a look at it urgently. thanx Code: 11:42:03 SE Ultimate Unlocker v5.04 by Cruiser Team 11:42:03 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:42:03 Initializing... ! 11:42:03 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:42:03 2. Choose the phone model ! 11:42:04 3. Select the desired options ! 11:42:04 4. Please connect the phone either via USB while holding 2-5… ! 11:42:04 - or via a serial cable and double-click on it in the device list 11:42:29 Selected phone: K800 11:42:29 Connecting via Generic EMP USB Flash Device (USB1)… 11:42:30 Device driver version: 2.2.0.5 11:42:30 Device driver date: 4-1-2009 11:42:31 Connecting to the baseband CPU... 11:42:31 Entering baseband CPU service mode... 11:42:31 Detected chipset: DB2020 11:42:31 Boot mode: ROM 11:42:31 Sending loader... 11:42:32 IMEI: 35342701123075 11:42:32 OTP CID: 49 11:42:32 Effective CID: 49 11:42:34 Please reconnect the phone (disconnect, connect while holding 2-5) E 11:43:04 Error: 0xF984FBBB E 11:43:04 Error data: 0xF984FBBB - 00000004:1F000000 E 11:43:04 Error: 0xF984FBBB E 11:43:05 Error data: 0xF984FBBB - 00000004:E3030000 E 11:43:05 Error: 0xD5D8B92F E 11:43:05 Error: 0x852D9D91 E 11:43:05 Error: 0x4B4AFEF3 E 11:43:05 Error: 0x319AC5CC E 11:43:05 Error: 0x624C554E E 11:43:05 Error: 0x5577997D E 11:43:05 Error: 0x5C5AEBE3 E 11:43:05 Error: 0x3D35EAF1 E 11:43:05 Device initialization failed E 11:43:05 Close all applications that might be interfering E 11:43:05 Failed! ! 11:43:05 To report errors right-click this window |
04-24-2010, 13:32 | #12 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: frp off Age: 41
Member: 183958 Status: Offline Sonork: 719191000d Thanks Meter: 523 | Quote:
04-24-2010, 14:20 | #15 (permalink) |
Member: 183958 Status: Offline Sonork: 719191000d Thanks Meter: 523 | 11:42:03 SE Ultimate Unlocker v5.04 by Cruiser Team 11:42:03 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:42:03 Initializing... ! 11:42:03 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:42:03 2. Choose the phone model ! 11:42:04 3. Select the desired options ! 11:42:04 4. Please connect the phone either via USB while holding 2-5… ! 11:42:04 - or via a serial cable and double-click on it in the device list 11:42:29 Selected phone: K800 11:42:29 Connecting via Generic EMP USB Flash Device (USB1)… 11:42:30 Device driver version: 2.2.0.5 11:42:30 Device driver date: 4-1-2009 11:42:31 Connecting to the baseband CPU... 11:42:31 Entering baseband CPU service mode... 11:42:31 Detected chipset: DB2020 11:42:31 Boot mode: ROM 11:42:31 Sending loader... 11:42:32 IMEI: 35342701123075 11:42:32 OTP CID: 49 11:42:32 Effective CID: 49 11:42:34 Please reconnect the phone (disconnect, connect while holding 2-5) E 11:43:04 Error: 0xF984FBBB E 11:43:04 Error data: 0xF984FBBB - 00000004:1F000000 E 11:43:04 Error: 0xF984FBBB E 11:43:05 Error data: 0xF984FBBB - 00000004:E3030000 E 11:43:05 Error: 0xD5D8B92F E 11:43:05 Error: 0x852D9D91 E 11:43:05 Error: 0x4B4AFEF3 E 11:43:05 Error: 0x319AC5CC E 11:43:05 Error: 0x624C554E E 11:43:05 Error: 0x5577997D E 11:43:05 Error: 0x5C5AEBE3 E 11:43:05 Error: 0x3D35EAF1 E 11:43:05 Device initialization failed E 11:43:05 Close all applications that might be interfering E 11:43:05 Failed! ! 11:43:05 To report errors right-click this window check this logs and after that tel me what is the problem i know server dont work but in this case she has problem to connect phone |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
