thanks for share this solution. i need just 2 things: -how can i convert the phone to red CID36 using the special red CID36 EROM file. (step 10) the only way that i know how to convert is the change color buttom but dont give you any option to upload a file -can anyone send me the signed archive for w800 ( step 15) thanks a lot |
while all the other steps i can do it normally. What do you think is the problem here. Thank you. |
I also have question about step Number 10 Converting to red, is it the same way that we do it normally from the SECURITY tap and choosing red Cid 36.... Please it's a serious matter. I already have 3 phones now with me the same problem. Any dead K750 i flash it's becoming please wait and after no network. The only original tool i have is cruiser. |
flash with the Eerom file just follow the instruction |
Can i know what is Eerom file and where can i get it for K750i to use with cruiser. Also the GDFS file in the support area K750i_FullGDFS_Brown36.ck75sw i don't know if it's the correct one. while if i want to flash GDFS file it's asking for .mdc file. |
The link for step 10 is not working. can someone help me with the link so i can know how to flash Eron please and where to get the file from? |
After a long search into the forum i foung my answers and files needed under this link: http:///vbb/attach...4&d=1119228389 I will try it and post result. hopefully i can fixe those 3 phones. Regards, |
you can download it at their support area for the files |
gdfs hi all, I have K750i that came in with problem : when allumination phone there was white screen for one second en then went dead. I flashed the phone with cruiser and then i got the problem of freezing on screen please wait. So then i did recalculate codes and write. Then phone booted normal without finding network. When i trie steps to repair this as explained here i have a problem with writing GDFS. This is what comes on the screen : RSA protection weakness type: PERMANENT Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Sending applet... Sending applet... Defeated! Sending CS applet... Initializing CS applet... Baudrate = 921600Bd Starting up GDFS service... Backing up GDFS security zone... Started writing to GDFS... Failed! Gdfs was downloaded from cruiser support, i allready tried to change baudrate or converting to red too. Nothing helped. Also can not download special erom file, it is in the help file yes, but when i click it nothing happens and i can not find the file on support from cruiser:mad: Please advice Thanks Daffy |
Here you go the eerom Quote:
You do not need this special erom files, all is in cruiser.exe (repaire erom, convering red/brown). First, it is time to start use cruiser v7.12 Foony |
Looking forward to revision history for that version :) |
Version 7.12 (22nd December 2005, beta version): Fixed EROM repair issue for brown CID49 K608. Updated W900i langpack info. Some changes to applet upload strategies. Added support for flashing CID54 phones (LG U8550) without using testpoint. RSA configuration analysis code slightly updated to reflect CID54-related changes. Increased robustness of RSA configuration analysis code to prevent potential crashes on invalid flash content. Added alternate method of replacing RSA certificates. Fixed one bug in low-level communication code. Fixed small bug in Repair certificate function. Fixed one previously introduced bug in GDFS access for P910. Updated K750i built-in customizations. Updated W800i built-in customizations. Updated TAC list for K300i, K700i, T290i, LG U8330 and Sharp V903SH. |
To microstar Thanks for the file but i allready repaired my K750i with gdfs and sonics cracked and my ufs box. After writing gdfs and unlock full network :) Thanks anyway Daffy |
I was trying with sonic cracked and my ufsx box but i could not connect the phone. Can you tell me how you did it please? |
