Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 10-10-2008, 14:23   #1 (permalink)
IkaMazini's Avatar
Member: 162473
Sonork: Not have
Thanks Meter: 592
Exclamation how tu repair K770 with cruiser if with setool identifyed as K700
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:51 PAF:1 IMEI:************ CERT:N/A
FLASH CID:52 COLOR:RED
Model:K700
MAPP CXC article: R8BA024 prg1201-7587_GENERIC_VI
MAPP CXC version: R8BA024
Language Package:BALTIC
CDA article: CDA102568/1
CDA version: R7A
Default article: 1201-7603
Default version: R8BA024
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
Elapsed: 8 secs.
Step by step. Please help me
Old 10-10-2008, 14:34   #2 (permalink)
IkaMazini's Avatar
Member: 162473
Sonork: Not have
Thanks Meter: 592
here log with SE Ultimate Unlocker
  17:28:56  SE Ultimate Unlocker v2.01 by Cruiser Team
  17:28:56  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  17:28:56  Initializing...
! 17:28:56  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 17:28:56  2. Choose the phone model
! 17:28:56  3. Select the desired options
! 17:28:56  4. Please connect the phone either via USB while holding 2-5…
! 17:28:56  - or via a serial cable and double-click on it in the device list
  17:30:00  Selected phone: K770
  17:30:00  Connecting via SEMC USB Flash Device (USB1)…
  17:30:00  Device driver version: 2.0.0.4
  17:30:00  Device driver date: 9-12-2007
  17:30:01  Connecting to the baseband CPU...
  17:30:01  Entering baseband CPU service mode...
  17:30:02  Detected chipset: DB2020
  17:30:02  Boot mode: EROM
E 17:30:32  Error: 0x9D2F2420
E 17:30:32  Error: 0xAE24C00E
E 17:30:32  Error: 0xEB80927F
E 17:30:32  Error: 0xEB4BD9D2
E 17:30:32  Error: 0x889C690F
E 17:30:32  Failed!
! 17:30:32  Please disconnect battery and cable from the phone!
! 17:30:32  To report errors right-click this window
Old 10-10-2008, 19:37   #3 (permalink)
Afzaal's Avatar
Member: 128918
Thanks Meter: 282
E 17:30:32  Failed!
use 2+5 to connect not C
Old 10-11-2008, 06:32   #4 (permalink)
IkaMazini's Avatar
Member: 162473
Sonork: Not have
Thanks Meter: 592
connected with 2+5
Old 10-11-2008, 06:46   #5 (permalink)
ticksjarub's Avatar
Member: 534932
Thanks Meter: 49
in cruiser,
1. select correct phone type.
2. then go to boot type select identify.
3. cllick attached phone.
4. power on unit.
wait until unit attached.
Old 10-11-2008, 07:06   #6 (permalink)
IkaMazini's Avatar
Member: 162473
Sonork: Not have
Thanks Meter: 592
[ --- Attach to Phone --- ]
Connecting via Fighter USB Cable...
Powering on the phone...
Baseband chip ID: 0x9900
Protocol version: 3.1
Baudrate = 460800Bd
Booting via ROM...
Trying SEMC ID applet...
Sending applet prologue...
Sending applet body...
Time spent entering bootstrap: 1s
Initializing phone hardware...
Applet ID: 070129 0950 NGUCXC1250330_DB2020_PR...
Flash manufacturer: Intel
Flash ID: 0x897E
OTP Security Level: 1 (Retail)
OTP CID: 51
Phone CID: 52
Phone color: Red
Phone type (from GDFS): K700
Language package: BALTIC
Turning off phone...
Terminating threads...
All threads terminated.
Old 10-11-2008, 08:48   #7 (permalink)
Gr8SightMan's Avatar
Member: 163076
Thanks Meter: 97
ok do it now.
select correct gdfs in bin format in misc
mark format gdfs in settings
click write gdfs
flash main+fs
post identify log afterwards.
do all operation with tool u messed it ;P
Old 10-11-2008, 08:51   #8 (permalink)
IkaMazini's Avatar
Member: 162473
Sonork: Not have
Thanks Meter: 592
where gdfs?
Old 10-11-2008, 09:03   #9 (permalink)
alexmkdMAFIA's Avatar
Member: 212574
Sonork: 100.1580063
Thanks Meter: 63
you will only have the gdfs backed up on the tool that you broke the phone
Old 10-11-2008, 09:07   #10 (permalink)
Member: 483440
Thanks Meter: 191
I think only way to repair your GDFS is to use TP method
Regards
Old 10-11-2008, 15:02   #11 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,784
Look,, Flash correct GDFS with CRUISER, Via main.. useing cruiser 13.20..
Then attach with ULTIMATE UNLOCKER, and Make sure Security Rebuild Box is Checked.
Old 10-11-2008, 17:37   #12 (permalink)
sameenshah123's Avatar
Member: 619308
Sonork: 100.1591829
Thanks Meter: 243
i also have one k850 its vibrate and show light and keep doing like that and secreed dardk noting on it i flashed with setool and then unlock with ultimate unlocker but still same i tick securty zone rebuld option . but i didn write any gdfs on it. coz i hade one k810 phone with gdfs problem and fixed just by unlock with ultimate unlocker no need to write gdfs. but this phone is not ok would any one help me how to fix this problem plz with ultimate unlocker
10/10/2008 2:30:36 PM v0.914040/UNI
10/10/2008 2:30:36 PM CARD SERIAL: 00064467
10/10/2008 2:30:36 PM Loaded 51 flash descriptors
10/10/2008 2:34:21 PM SIGNED MODE (USING SERVER).
10/10/2008 2:34:33 PM ChipID:C802,EMP protocol:0401
10/10/2008 2:34:33 PM PHONE IS RED RETAIL PRODUCT
10/10/2008 2:34:33 PM FLASH CID detected:52
10/10/2008 2:34:34 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35182902952757 CERT:RED
10/10/2008 2:34:35 PM LDR:2008-07-23 12:03 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A065
10/10/2008 2:34:35 PM LDR CAPS:SYSTEM FLASH SIGNATURE AUTH
10/10/2008 2:34:37 PM LDR:2008-07-23 12:03 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A065
10/10/2008 2:34:37 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA
10/10/2008 2:34:37 PM writing C:\Program Files\setool2g\flash file\k850\R1EA037_APP_SW_1200_4394_VODAFONE_SO_RED BROWNBLUE_CID52_49_DB3150.software.cry
10/10/2008 2:34:51 PM ALLOWED DOMAINS:BLUE BROWN RED
10/10/2008 2:34:51 PM MAXIMUM CID:52
10/10/2008 2:34:51 PM Will flash 697 blocks...
10/10/2008 2:42:04 PM ssw file accepted
10/10/2008 2:42:04 PM writing C:\Program Files\setool2g\flash file\k850\R1EA037_FS_APAC_ANZ_SO_REDBROWNBLUE_CID5 2_49.software.cry
10/10/2008 2:42:15 PM ALLOWED DOMAINS:BLUE BROWN RED
10/10/2008 2:42:15 PM MAXIMUM CID:52
10/10/2008 2:42:15 PM Will flash 497 blocks...
10/10/2008 2:47:22 PM ssw file accepted
10/10/2008 2:48:29 PM writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm
10/10/2008 2:48:30 PM writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm
10/10/2008 2:48:30 PM writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
10/10/2008 2:48:30 PM writing tpa/preset/custom/FM_THEMES_HOOK_3.itm
10/10/2008 2:48:30 PM writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
10/10/2008 2:48:30 PM writing tpa/preset/custom/GAMES_HOOK_3.itm
10/10/2008 2:48:30 PM writing tpa/preset/custom/MC_MUSIC_HOOK_3.itm
10/10/2008 2:48:31 PM writing tpa/preset/custom/MC_PHOTO_HOOK_3.itm
10/10/2008 2:48:32 PM writing tpa/preset/custom/MC_VIDEO_HOOK_3.itm
10/10/2008 2:48:32 PM writing tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm
10/10/2008 2:48:32 PM writing tpa/preset/custom/preloaded_config.xml
10/10/2008 2:48:34 PM writing tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm
10/10/2008 2:48:34 PM writing tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm
10/10/2008 2:48:34 PM writing tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm
10/10/2008 2:48:34 PM writing tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm
10/10/2008 2:48:35 PM writing tpa/preset/custom/Customize.xml
10/10/2008 2:48:36 PM Phone detached
10/10/2008 2:48:38 PM Elapsed: 856 secs.
Old 10-11-2008, 19:40   #13 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,784
If it is a GDFS, issue then Write an alien gdfs to it, once this is done phone is Dead, (this is Normal)
Now attach to Ultimate Unlocker and rebuild security zone...
You own Setool, you may find its Easier to Write GDFS with that, (i do)
Old 10-11-2008, 19:53   #14 (permalink)
Member: 619308
Sonork: 100.1591829
Thanks Meter: 243
can u plz upload for me any gdfs coz i didn find any gdfs in cruiser or setool. plz upload for me
Old 10-11-2008, 20:06   #15 (permalink)
Member: 619308
Sonork: 100.1591829
Thanks Meter: 243
need gdfs for setool plz
Sony Ericsson Z750 Identify as K700 help ASHRIFF SETool2 10 02-05-2010 18:39
how to repair gdfs K800i cid 53 with setool ..::proudcracker::.. SETool2 1 10-25-2009 11:48
K610 CID52 RED white blinking - identified as K700 R@jusat SETool2 7 07-14-2009 06:49
k800 identified as k700 garguantan SETool2 6 04-25-2009 07:17
how to repair erom k800i cid 49 with setool. toutou_gsm Sony Ericsson 7 03-02-2008 08:02
Page generated in 0.27064 seconds with 9 queries
