No question about it....it can be repaired 100%! problem is the logs.... |
K810 repair GDFS 100% First conecction Code: 17:06:32 SE Ultimate Unlocker v4.01 by Cruiser Team Code: 17:15:03 SE Ultimate Unlocker v4.01 by Cruiser Team phone alive again good luck users of Cruiser |
Hi,Unloker AL,is this your total procedure,right? Step1: Tick Direct Unlock (+Sec Zone rebuild) Repair Erom/Semc boot Show codes then connect phone. Step 2: Only tick Set Cerificate to 52 or 53 and connect phone.(little confused about this step,only tick this option or other option in setp1 still needed?) Step 3: Full flash the phone |
procedure is the same for Step 1 and step 2 after make full flash but as i test with the first step you can t repair gdfs so it needs also the same procedure 2 times good luck |
select no change in locks, tick semc boot repair and show codes and set cid certificate reset to 52 or 53 |
Repair gdfs W580i Code: 20:31:18 SE Ultimate Unlocker v4.01 by Cruiser Team |
problem Second Step Code: 18:22:41 SE Ultimate Unlocker v4.01 by Cruiser Team |
but after make all steps . it will be need to unlock when enter nck , not allowed by unlock rsa , flash main, direct unlock .... not unlock how to solve this problem |
the phone is automaticlly unlocked man.... |
and after make again the steps to repair and unlock good luck |
hi i did repair w610 but no network and i ask for a gdfs file tested in the forum and nobody answer me can some help me |
