Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 11-24-2005, 15:10   #1 (permalink)
Member: 146722
Thanks Meter: 3
U8330 dead.flashing works but still dead.
I flashed with U8330_V10a_Italia_Red42.flp but still dead. unlock. same
Old 11-24-2005, 17:18   #2 (permalink)
MUNEEB_AKHTAR_RAZA's Avatar
Member: 152244
Sonork: 100.1591179
Thanks Meter: 162
Hi Mate,
Try To Write Gdfs To Phone And If It Works So Post Here Or Try Anyother Flash File Or Use Orignal Flash Files.......dont Forget To Post Result.....................good Luck......
Muneeb Akhtar Raza
Old 11-24-2005, 17:53   #3 (permalink)
Member: 22586
Thanks Meter: 36
1. Flash it with this file from support: U8330_V20a_Austria_Red42.flp
2. After flashing swith ON and reset
3. Re-attach and unlock by patching
Mike
Old 11-25-2005, 09:31   #4 (permalink)
crossings's Avatar
Member: 9897
Thanks Meter: 7
GDFS for 8330 is not available on support.
Old 11-25-2005, 09:37   #5 (permalink)
sevgiesenler's Avatar
Member: 60560
Sonork: 100.89085
Thanks Meter: 134
according to me u must write ,Downgrade_U8330_to_U8130_V101_Unlock_by_any_code and than select unlock by patching
Old 11-25-2005, 16:23   #6 (permalink)
crossings's Avatar
Member: 9897
Thanks Meter: 7
sevegiesenler , I did that. phone still dead. only a split of second light.
Old 11-25-2005, 17:35   #7 (permalink)
faysal's Avatar
Member: 89109
Thanks Meter: 8
plz do something for this one .. i have similar problem
Old 11-25-2005, 17:42   #8 (permalink)
Member: 22586
Thanks Meter: 36
The only way to revive the phone is :
If phone switches ON don't do anything else. Just report here and i give you next step.
Mike
Old 11-26-2005, 09:00   #9 (permalink)
crossings's Avatar
Member: 9897
Thanks Meter: 7
Yes, I flashed with U8330_V20a_Austria_Red42.flp =phone still dead. I'am not sure what PCB is inside as the client come with phone like this. maybe it is PCB from 8130 who konws..
Old 11-26-2005, 09:05   #10 (permalink)
Member: 22586
Thanks Meter: 36
While attaching cruiser reads the phone CID.
CID42=U8330, CID17= U8110,U8120,U8130,U8138.
Anyway, paste here the cruiser log in order to see what happens.
Mike
Old 01-04-2006, 10:27   #11 (permalink)
Member: 25930
Thanks Meter: 4
I have same problem with U8330, i flash with 7.15 and flash file 8330_8130...from support and then no network. Then i flash with RED box and 8330_fullflash and now is phone dead. Only with charger charging, but not power on.
have anybody solution?
thanks
hrich
Old 01-04-2006, 10:40   #12 (permalink)
fonecellar's Avatar
Member: 545165
Thanks Meter: 578
thanks
hrich
Hi There have had similar problem try downgrade to cruiser version 6.1
this link to unlock http://forum.gsmhosting.com/vbb/showthread.php?t=257013 have a look at thread i left there maybe this will be of help
rgds
Old 01-04-2006, 11:19   #13 (permalink)
Member: 10730
I also have dead 8330 from redbox which killled it!!
i attach to cruiser(6.10) it does not attach just tries cid 17,18 36 ect then cruiser just detach it self?? Can anyone help?
Old 01-04-2006, 12:19   #14 (permalink)
ashvin's Avatar
Member: 106700
Thanks Meter: 47
had same problem; did do a downgrade and problem was sorted. in ur case, the downgrade also seems not to work. heard that the furuious flash can revive the phone; may be u need to try it and post here to let us know.
Old 01-04-2006, 12:49   #15 (permalink)
Member: 56168
Thanks Meter: 4
Mike
Doesn't work my friend.
N73 dead flashing ok but still phone dead FullFLASHgSMPH Cyclonebox 3 09-27-2009 03:41
1650 dead-flashing ok-but still in dead-help zone3 Nokia Hardware & Hardware Repair 3 06-22-2009 09:49
5200 Dead-flashing Ok-but Still In Dead zone2 HWK 6 06-30-2008 10:31
Dead V177 Flash Ook but Still Dead imran_qasim Infinity-Box 5 02-18-2008 17:30
T100 Dead ,flasher Works But Still Dead crossings Sony Ericsson 1 12-23-2003 22:10
Page generated in 0.26457 seconds with 9 queries
