Unlock W960i - problem Code: 12:47:04 SE Full Unlocker v2.13 by Cruiser Team |
12:48:04 Choose phone-mode (on the phone) ! 12:48:39 Phone detected in mass-storage mode it's just your mistake. you have to connect the phone turned on without any sim card and while connecting the cable choose Phone mode. |
i did put it in phone mode but still the same.. any help. |
Use Ultimate Unlocker and unlock it by flash method |
FullUnlocker, D-Unlocker Quote:
I've write hits several times here on the forum. 1. Make sure the phone has a correct firmware (if not sure, just flash it) 2. Then, the most important thing - DO NOT CONNECT the phone in the FLASH MODE (powered off, holding 'C' or '2'+'5'), EXCEPT OF cases: - when the phone is impossible to power-on because of corrupted security zone - when there is a problem to boot/detect the phone in the flash-mode 3. Make sure, that phone MODEM drivers are installed and connect the powered-on phone (not required to run the unlocker application, this can be done just using the windows device manager), so it is correctly detected in WMC (MODEM) MODE. Being able to use the modem-mode is ESSENTIAL, otherwise you won't be able to finish the unlock 4. Run the unlocker application and connect the phone in modem-mode, the unlock procedure is then straightforward and does not require any user interaction GLaDOS |
thank you...problem solve |
Please correct if I am wrong. W960i is supported by the SE Ultimate Unlocker Supreme account is needed but no credits are required. No Flashing is required Just connect and read codes. Is there a way to remove the personal passwords from this phone? Thanks, |
Credits are required for this phone to be unlocked (and you should buy some). |
phone is already unlocked but has personal passwords. any easy way to get rrid of that. Like Factory Reset/Master Reset but how? Thanks, |
is it incorrect simcard problem? |
no personal paswords. |
P990/M600/W950/P1/W960 Info Reader v1.05 by Cruiser Team Initializing... Please connect the phone while holding its C button... Starting communication... Bypassing to the baseband CPU... Connecting to the baseband CPU... Entering baseband CPU service mode... Sending loader... Initializing loader... Flash chip ID: 0x2010 IMEI: 123456789123456 OTP CID: 52 Effective CID: 53 Effective color: Red Initializing GDFS access... Reading from GDFS... Phone type: W960i Phonelock code: 1980 Reading SW Info... Phone software: CXC162037 R9J005 Bluetooth software: CXC162175 R4A03 PDA software: CXC162168 R6F41 CDA info: CDA162032/8 R6F41 SW Info checksum OK Turning off the phone... Done. ---------------------- Many thanks cruiser team! |
