Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 10-08-2008, 13:08   #1 (permalink)
koa
Member: 152974
Unlock W960i - problem
  12:47:04  SE Full Unlocker v2.13 by Cruiser Team
  12:47:04  Initializing...
! 12:47:04  1. Please see the documentation first (a PDF installed with the application)
! 12:47:05  2. Make sure the appropriate phone modem drivers are installed
! 12:47:05  3. Fill in the connection settings under settings tab
! 12:47:05  4. Turn the phone ON
! 12:47:05  5. Connect the phone…
  12:47:39  Connecting via Sony Ericsson Port (COM50, COM51)…
  12:47:39  Device driver version: 4.40.6.0
  12:47:39  Device driver date: 12-26-2007
  12:47:39  Starting communication...
  12:47:40  Connecting to the baseband CPU...
  12:47:42  Entering baseband CPU service mode...
  12:47:42  Detected chipset: DB2001
  12:47:42  Boot mode: ROM
  12:47:53  Initializing loader...
  12:47:53  Initializing GDFS access...
  12:47:54  Communicating with server…
  12:47:57  Remainig credit (supreme): 1.51
  12:48:04  Restarting phone …
  12:48:04  Choose phone-mode (on the phone)
! 12:48:39  Phone detected in mass-storage mode
! 12:48:39  Please reconnect the phone (disconnect, power on, connect)
! 12:49:35  Phone detected in mass-storage mode
! 12:49:35  Please reconnect the phone (disconnect, power on, connect)
! 12:50:03  Phone detected in mass-storage mode
! 12:50:04  Please reconnect the phone (disconnect, power on, connect)
! 12:53:42  Phone detected in mass-storage mode
! 12:53:42  Please reconnect the phone (disconnect, power on, connect)
! 12:54:13  Phone detected in mass-storage mode
! 12:54:14  Please reconnect the phone (disconnect, power on, connect)
always not connector... why...
Old 10-08-2008, 14:39   #2 (permalink)
FilipLudvik's Avatar
Member: 135110
Thanks Meter: 302
it's just your mistake. you have to connect the phone turned on without any sim card and while connecting the cable choose Phone mode.
Old 10-08-2008, 19:15   #3 (permalink)
koa
Member: 152974
i did put it in phone mode but still the same.. any help.
Old 10-08-2008, 19:24   #4 (permalink)
Member: 135110
Thanks Meter: 302
Use Ultimate Unlocker and unlock it by flash method
The Following User Says Thank You to FilipLudvik For This Useful Post:
Old 10-08-2008, 21:57   #5 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 471
Just flash phone and after try unlock again and will unlock correct now can't do nothing without lost credits with ultima unlocker or flash this phone.
The Following User Says Thank You to wgmmmx For This Useful Post:
Old 10-09-2008, 11:48   #6 (permalink)
Member: 670274
Thanks Meter: 165
FullUnlocker, D-Unlocker
Hi,
I've write hits several times here on the forum.
1. Make sure the phone has a correct firmware (if not sure, just flash it)
2. Then, the most important thing - DO NOT CONNECT the phone in the FLASH MODE (powered off, holding 'C' or '2'+'5'), EXCEPT OF cases:
- when the phone is impossible to power-on because of corrupted security zone
- when there is a problem to boot/detect the phone in the flash-mode
3. Make sure, that phone MODEM drivers are installed and connect the powered-on phone (not required to run the unlocker application, this can be done just using the windows device manager), so it is correctly detected in WMC (MODEM) MODE. Being able to use the modem-mode is ESSENTIAL, otherwise you won't be able to finish the unlock
4. Run the unlocker application and connect the phone in modem-mode, the unlock procedure is then straightforward and does not require any user interaction
GLaDOS
The Following User Says Thank You to GLaDOS For This Useful Post:
Old 10-09-2008, 11:49   #7 (permalink)
koa
Member: 152974
thank you...problem solve
Old 11-16-2008, 08:00   #8 (permalink)
Member: 76614
Thanks Meter: 29
Please correct if I am wrong.
W960i is supported by the SE Ultimate Unlocker
Supreme account is needed but no credits are required.
No Flashing is required
Just connect and read codes.
Is there a way to remove the personal passwords from this phone?
Thanks,
Old 11-16-2008, 13:07   #9 (permalink)
ronandaly's Avatar
Member: 234917
Thanks Meter: 160
Credits are required for this phone to be unlocked (and you should buy some).
Old 11-16-2008, 19:22   #10 (permalink)
Member: 76614
Thanks Meter: 29
phone is already unlocked but has personal passwords.
any easy way to get rrid of that.
Like Factory Reset/Master Reset but how?
Thanks,
Old 11-16-2008, 19:29   #11 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
Thanks Meter: 59
is it incorrect simcard problem?
Old 11-17-2008, 09:37   #12 (permalink)
Member: 76614
Thanks Meter: 29
no personal paswords.
Old 11-20-2008, 18:55   #13 (permalink)
Member: 76614
Thanks Meter: 29
P990/M600/W950/P1/W960 Info Reader v1.05 by Cruiser Team
Initializing...
Please connect the phone while holding its C button...
Bypassing to the baseband CPU...
Sending loader...
Flash chip ID: 0x2010
IMEI: 123456789123456
OTP CID: 52
Effective CID: 53
Effective color: Red
Reading from GDFS...
Phone type: W960i
Phonelock code: 1980
Reading SW Info...
Phone software: CXC162037 R9J005
Bluetooth software: CXC162175 R4A03
PDA software: CXC162168 R6F41
CDA info: CDA162032/8 R6F41
SW Info checksum OK
Turning off the phone...
Done.
Many thanks cruiser team!
unlocking 8350i problem [ANSWERED] NeeMan PolarBox 3 5 03-29-2010 19:21
T303 unlock & W302 unlock - whats problem? JezH SETool2 4 05-20-2009 01:54
unlock a1200 problem user unlock taariqmajid Smart-Clip 1 03-27-2008 08:29
Unlock W960i W910i K850i PDA all A2 Remotely total-gsm Main Sales Section 0 01-21-2008 15:55
unlock gx15i PRoblem unlocking ami_nezzar FuriouS II 1 10-26-2004 22:25
Page generated in 0.20002 seconds with 9 queries
