Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 11-01-2004, 19:56   #1 (permalink)
Member: 85164
Question T610 ident change
Hi
Can anybody give me advice, please, how to change Identifier on T610? I do manage to change GDFS one, but it doesn't match OTP and when I try to change OTP, Fighter says that it had been programmed already.
And I have a customer with this phone (cover and body changed to the T630's) and he asks if I can change something, so it will appear on the screen when you check firmware that it is "T630" not "T610". Screen is old T610's. Is it posiible? Any ideas?
Thanks
Old 11-01-2004, 22:50   #2 (permalink)
sven.soltermann's Avatar
Member: 44110
Hi,
You must to GDFS --> Phone Ident change --> [enter phone ident] --> Click on "Modify GDFS" --> Click on "Finalize GDFS"
Sorry, I know that my english is very bad!
I hope I could help
Sven
Old 11-01-2004, 23:05   #3 (permalink)
arash111
Guest
Posts: n/a
Member:
Wrong wrong wrong,
You have to make following,
1. Flash AVR ''Tick the Disable OTP IMEI Check''
2. Flash ARM with same version as ''AVR''
3. Upload a new gdfs value, (not necessary but it may help)
4. Enter the digits you want to edit, tick the ''Auto Incementing'' option and then click, ''Create Security Zone''
May G*o*d be with you !
Old 11-01-2004, 23:16   #4 (permalink)
Member: 85164
Thanks mate
Do you know anything about the second problem I have (T610 appearing like T630)??
Old 11-01-2004, 23:23   #5 (permalink)
evan_silbert's Avatar
Member: 21920
Thanks Meter: 10
You need to go to the GDFS tab, then go to the dropdown menu on the lower part of the left pane. You should see an option there like Phone Type Descriptor or something. Click it, then the box shows T610. Backspace it and write T630 then write it to the phone. PRESTO!
Old 11-02-2004, 00:53   #6 (permalink)
Member: 85164
Thank you very much
Old 11-02-2004, 00:59   #7 (permalink)
Member: 21920
Thanks Meter: 10
Hope it worked out for you!
If you replace the screen and flash it you can make it INTO a t630
Old 11-02-2004, 02:05   #8 (permalink)
arash111
Guest
Posts: n/a
Member:
also cover & housing ... he he he but the phone is very cheap at this moment in sweden you can get it for 150euro locked with Vodafone why spend so much to build an T610 to a T630
Old 11-02-2004, 02:09   #9 (permalink)
Member: 21920
Thanks Meter: 10
He already has the housing and keys on it... just add the screen and flash!
Old 11-02-2004, 02:42   #10 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Sounds to me like they're trying to disguise a stolen phone (changing IMEI and the physical cover)!
Old 11-02-2004, 03:10   #11 (permalink)
Member: 21920
Thanks Meter: 10
I don't think so. I don't think he ever wanted to change the IMEI. I think he meant identity as the phone's model number.
The customer wanted to make his phone into a t630 I think....
Correct me if I'm wrong
Old 11-02-2004, 03:21   #12 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Oh right, yes, rereading the thread it appears that's the case. My bad!
Old 11-02-2004, 06:41   #13 (permalink)
Member: 88515
My first impression: he wants to sell t610 for the price of t630. He didn't mention about t630 features, ONLY firmware identity In this case I suggest add_my_friends gdfs without changing the display.
Don't take me seriously, I'm just fooling around..
Old 11-02-2004, 14:10   #14 (permalink)
arash111
Guest
Posts: n/a
Member:
aha .. hehe i thought that he means Identity Change but he ment Phone Type Descriptor ..
Old 11-02-2004, 19:22   #15 (permalink)
Member: 85164
That's right.
I don't think hi is going to sell it as T630, because he would need the box and serial number plastic plate under the battery. Also the price isn't much different.
Anyway, its not my business.
About the IMEI change - it is currently illegal in the UK, so I never get involded.
Identity Change soch Cruiser Suite 3 03-27-2008 17:44
Does not show "IMEI" section even with identity change install preshaust Cruiser Suite 2 02-15-2006 01:22
t610 imie change billyuk009 Sony Ericsson 1 12-03-2003 00:06
T610 imei change. rob.paterson Sony Ericsson 3 11-24-2003 21:44
Page generated in 0.22670 seconds with 9 queries
