V4.31 unlock problem Have just installed v4.31 but it will not unlock Z600. Had to go back to V2.52. Whats going on new software not working! :confused: |
Can you explain in a little more detail why it doesn't work. A post of "it will not unlock Z600" provides nothing useful for anyone to help you. I've had no problems with 4.31 unlocking phones, but having said that I haven't had a Z600 of late. Are you able to give more details of what the problem was and if possible a screenshot? If it's a bug I'm sure ZenithTeam will try to fix it. |
The phone took an age to connect. When it finaly connected i went to direct unlock,but it was greyed out. Rebuilt security zone still greyed out.Flashes AVR & ARM. Still greyed out. Opened up v2.52 and it connected quickly,then went to direc unlock. Phone now unlocked. But still have a problen with the phone, when selecting the camera from the menu it just goes to a white screen. Cheers Andy |
You can't direct unlock a Z600!! You HAVE to rebuild the Security Zone. Load Fighter 4.31 and untick the "Autodetect phone type", find Z600 on the list and then attach to the phone. If the Camera isn't working it sounds like someone has flashed the AVR and then not bothered to flash the ARM, so you have a AVR/ARM firmware mismatch. Sounds like the only "bug" here is the Fighter might not be autodetecting you have a Z600 correctly. |
I think it is just that Lead disabled the Direct Unlock button in the last 2 versions. He has to use Rebuild Security I anyway, so it makes no difference. Maybe "user error." |
Edit: This reminded me of a true bug that I have discovered. It is posted here: http://forum.gsmhosting.com/vbb/showthread.php?t=172940 |
Not user error. I have had over 200 z600s Have been using Se fighter for over a year. As i said in previous post rebuild security zone was also grey out on v4.31. Was only able to rebuild security zone on v2.25. |
As already recommended; If you dont use autoselect, and select z600 from the drop menu it should work a treat... At least it does for me ;-) |
yeeeaa... 4.31 smoothest then all previous version. work fine for me. @mupet still have to use .mdc hah? grumble grumble ;-))))))) |
