09-26-2008, 16:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | Ultimate Unlocker - solution for server connection problem in Tunisia, Algeria etc. you need to install proxy cap: http://ultimate.philipfotos.com/pcap315_x86.msi run it and put there these informations: and: after that, run your Ultimate Unlocker: be sure that you have entered in the settings right IP: 60.54.216.58 and port: 9001 also be sure that your login details for Supreme log are right. click on Save changes Try to unlock/repair your SE. PS: special thx to Mainboard for this idea. (I was getting for much more difficult solution) |
The Following 14 Users Say Thank You to FilipLudvik For This Useful Post: |
09-26-2008, 16:42 | #3 (permalink) |
No Life Poster Join Date: Aug 2005 Location: 突尼斯 Age: 38
Member: 172136 Status: Offline Sonork: 100.1574973 Thanks Meter: 777 | Thanks a lot for your interest in our probleme in tunisia I will test this solution and post result so soon cause after that I fail in connecting to server yesterday I return the phones to *******rs I will take them again and post result bro BR! Last edited by Mainboard; 09-26-2008 at 17:28. Reason: disturbing font style |
09-26-2008, 17:26 | #4 (permalink) |
Banned Join Date: Sep 2004 Location: msaken Age: 43
Member: 82201 Status: Offline Sonork: 1576982 Thanks Meter: 32 | solution worked 100% BIG THWX FILIPLUDVIK Code: 17:01:24 Ultimate Unlocker v1.01 by Cruiser Team 17:01:24 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 17:01:24 Initializing... ! 17:01:24 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 17:01:24 2. Choose the phone model ! 17:01:24 3. Select the desired options ! 17:01:24 4. Please connect the phone either via USB while holding 2-5… ! 17:01:24 - or via a serial cable and double-click on it in the device list 17:01:56 Connecting via Generic EMP USB Flash Device (USB1)… 17:01:56 Device driver version: 1.1.0.12 17:01:56 Device driver date: 9-25-2006 17:01:56 Connecting to the baseband CPU... 17:01:56 Entering baseband CPU service mode... 17:01:57 Detected chipset: DB3150 17:01:57 Boot mode: ROM 17:01:57 Sending loader... 17:01:59 IMEI: 35155802434759 17:01:59 OTP CID: 52 17:01:59 Product type: Retail 17:01:59 Effective color: Red 17:02:01 Sending loader... 17:02:02 Communicating with server… 17:02:11 Remainig credit (supreme): 1.00 17:02:14 Remainig credit (supreme): 1.00 17:02:14 Converting phone to blue… 17:02:14 Please reconnect the phone (disconnect, connect while holding 2-5) 17:02:37 Sending loader... 17:02:39 IMEI: 35155802434759 17:02:39 OTP CID: 52 17:02:39 Product type: Retail 17:02:39 Effective color: Blue 17:02:40 Sending loader... 17:02:45 Code NCK for relock: 7581243037016516 17:02:45 Code NSCK for relock: 9580673276364291 17:02:45 Code SPCK for relock: 5938723131180742 17:02:45 Code CCK for relock: 4211209254034008 17:02:45 Code PCK for relock: 3838137379143751 17:02:45 Code ESLCK for relock: 2768704149027719 17:02:45 Code NCK for unlock: 5734845917427858 17:02:45 Code NSCK for unlock: 0626890450737640 17:02:45 Code SPCK for unlock: 7973085135238542 17:02:45 Code CCK for unlock: 8481764932362360 17:02:45 Code PCK for unlock: 3111079432369410 17:02:45 Code ESLCK for unlock: 7548477526042969 17:02:45 To enter a code, type < * * < on the phone with SIM-card inserted 17:02:45 Turning off the phone... 17:02:47 Done. ! 17:02:47 Please disconnect battery and cable from the phone! |
09-28-2008, 23:37 | #7 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | Guys, proxy server for ProxyCap has been changed. right now you can use this one: IP: 58.227.194.87 port: 8080 confirmation log that it works: Code: 00:33:59 Ultimate Unlocker v1.02 by Cruiser Team 00:33:59 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 00:33:59 Initializing... ! 00:33:59 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 00:33:59 2. Choose the phone model ! 00:33:59 3. Select the desired options ! 00:33:59 4. Please connect the phone either via USB while holding 2-5… ! 00:33:59 - or via a serial cable and double-click on it in the device list 00:34:40 Connecting via Generic EMP USB Flash Device (USB1)… 00:34:40 Device driver version: 2.1.0.0 00:34:40 Device driver date: 3-20-2008 00:34:40 Connecting to the baseband CPU... 00:34:40 Entering baseband CPU service mode... 00:34:40 Detected chipset: DB2020 00:34:40 Boot mode: ROM 00:34:40 Sending loader... 00:34:41 IMEI: xxx 00:34:41 Please reconnect the phone (disconnect, connect while holding 2-5) 00:34:45 Sending loader... 00:34:45 Communicating with server… 00:34:50 Remainig credit (supreme): 100.0 00:34:53 Remainig credit (supreme): 100.0 00:34:54 Please reconnect the phone (disconnect, connect while holding 2-5) 00:34:59 Sending loader... 00:35:02 Code NCK for relock: 5636098138792814 00:35:02 Code NSCK for relock: 0335116830149881 00:35:02 Code SPCK for relock: 9763913318155499 00:35:02 Code CCK for relock: 6618762471507992 00:35:02 Code PCK for relock: 2026206909167182 00:35:02 Code ESLCK for relock: 4356888093620928 00:35:02 Code NCK for unlock: 3263238198732877 00:35:02 Code NSCK for unlock: 9398333421248073 00:35:02 Code SPCK for unlock: 5411390850143734 00:35:02 Code CCK for unlock: 4112932583953758 00:35:02 Code PCK for unlock: 4659877573682184 00:35:02 Code ESLCK for unlock: 2213624404081989 00:35:02 To enter a code, type < * * < on the phone with SIM-card inserted 00:35:02 Writing flash… 00:35:04 Turning off the phone... 00:35:06 Done. ! 00:35:06 Please disconnect battery and cable from the phone! Last edited by FilipLudvik; 09-28-2008 at 23:43. |
The Following User Says Thank You to FilipLudvik For This Useful Post: |
09-29-2008, 00:32 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2002 Location: Tunisia Age: 45
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | i m trying to repair a red blinking t650 but that s what i got even after changing proxy settings with last ones !! Code: 01:29:06 Ultimate Unlocker v1.01 by Cruiser Team 01:29:06 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 01:29:06 Initializing... ! 01:29:06 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 01:29:06 2. Choose the phone model ! 01:29:06 3. Select the desired options ! 01:29:06 4. Please connect the phone either via USB while holding 2-5… ! 01:29:06 - or via a serial cable and double-click on it in the device list 01:29:44 Connecting via Generic EMP USB Flash Device (USB2)… 01:29:45 Device driver version: 2.0.0.4 01:29:45 Device driver date: 9-12-2007 01:29:45 Connecting to the baseband CPU... 01:29:45 Entering baseband CPU service mode... 01:29:45 Detected chipset: DB2020 01:29:45 Boot mode: ROM 01:29:45 Sending loader... 01:29:45 IMEI: 35796601424223 01:29:45 Please reconnect the phone (disconnect, connect while holding 2-5) 01:29:52 Sending loader... E 01:30:59 Error: 0x6C729765 E 01:30:59 Error: 0x8CDFAB78 E 01:30:59 Error: 0xFA7863EC E 01:30:59 Error: 0x780BA8B0 E 01:30:59 Error: 0x4409BADF E 01:30:59 Error: 0x59AF7680 E 01:30:59 Failed! ! 01:30:59 Please disconnect battery and cable from the phone! ! 01:30:59 To report errors right-click this window br |
09-29-2008, 08:08 | #10 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | let me check it again. edit: anyway, your error doesn't mean that you can't connect to the server. it will be like that: Code: 09:12:26 Communicating with server… E 09:12:38 Error: 0x1F41CF97 E 09:12:38 Error: 0x41F19ADB E 09:12:38 Error: 0x51A411A0 E 09:12:38 Error: 0x78E56923 E 09:12:38 Error: 0x5C5AEBE3 E 09:12:38 Error: 0x3D35EAF1 E 09:12:38 Cannot connect to the server E 09:12:38 Failed! ! 09:12:38 Please disconnect battery and cable from the phone! ! 09:12:38 To report errors right-click this window try this one proxy: IP: 218.204.106.148 port: 80 Code: 09:13:59 Ultimate Unlocker v1.02 by Cruiser Team 09:13:59 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 09:13:59 Initializing... ! 09:13:59 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 09:13:59 2. Choose the phone model ! 09:13:59 3. Select the desired options ! 09:13:59 4. Please connect the phone either via USB while holding 2-5… ! 09:13:59 - or via a serial cable and double-click on it in the device list 09:14:06 Connecting via Generic EMP USB Flash Device (USB1)… 09:14:06 Device driver version: 2.1.0.0 09:14:07 Device driver date: 3-20-2008 09:14:07 Connecting to the baseband CPU... 09:14:07 Entering baseband CPU service mode... 09:14:07 Detected chipset: DB2020 09:14:07 Boot mode: ROM 09:14:07 Sending loader... 09:14:07 IMEI: xxx 09:14:07 Please reconnect the phone (disconnect, connect while holding 2-5) 09:14:12 Sending loader... 09:14:12 Communicating with server… 09:14:19 Remainig credit (supreme): 100.00 09:14:22 Remainig credit (supreme): 100.00 09:14:23 Please reconnect the phone (disconnect, connect while holding 2-5) 09:14:27 Sending loader... 09:14:30 Code NCK for relock: 5636098138792814 09:14:30 Code NSCK for relock: 0335116830149881 09:14:30 Code SPCK for relock: 9763913318155499 09:14:30 Code CCK for relock: 6618762471507992 09:14:30 Code PCK for relock: 2026206909167182 09:14:30 Code ESLCK for relock: 4356888093620928 09:14:30 Code NCK for unlock: 3263238198732877 09:14:30 Code NSCK for unlock: 9398333421248073 09:14:30 Code SPCK for unlock: 5411390850143734 09:14:30 Code CCK for unlock: 4112932583953758 09:14:30 Code PCK for unlock: 4659877573682184 09:14:30 Code ESLCK for unlock: 2213624404081989 09:14:30 To enter a code, type < * * < on the phone with SIM-card inserted 09:14:30 Writing flash… 09:14:31 Turning off the phone... 09:14:33 Done. ! 09:14:34 Please disconnect battery and cable from the phone! Last edited by FilipLudvik; 09-29-2008 at 08:16. |
09-29-2008, 09:47 | #11 (permalink) |
No Life Poster Join Date: Oct 2004 Location: No Location
Member: 87853 Status: Offline Thanks Meter: 1,231 | IP: 218.204.106.148 port: 80 work perfectly 10:38:44 Ultimate Unlocker v1.01 by Cruiser Team 10:38:44 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 10:38:44 Initializing... ! 10:38:44 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 10:38:44 2. Choose the phone model ! 10:38:44 3. Select the desired options ! 10:38:44 4. Please connect the phone either via USB while holding 2-5… ! 10:38:44 - or via a serial cable and double-click on it in the device list 10:38:52 Connecting via Generic EMP USB Flash Device (USB1)… 10:38:52 Device driver version: 2.0.0.4 10:38:52 Device driver date: 9-12-2007 10:38:53 Connecting to the baseband CPU... 10:38:53 Entering baseband CPU service mode... 10:38:53 Detected chipset: DB2020 10:38:53 Boot mode: ROM 10:38:53 Sending loader... 10:38:53 IMEI: 35xxxxx 10:38:53 Please reconnect the phone (disconnect, connect while holding 2-5) 10:38:59 Sending loader... 10:39:00 Communicating with server… E 10:39:04 Error: 0x41F19ADB E 10:39:04 Error: 0x07F5EFDA E 10:39:04 User name not registered on the server E 10:39:04 Login to server failed |
09-29-2008, 09:57 | #12 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | E 10:39:04 User name not registered on the server E 10:39:04 Login to server failed check your log's account with your reseller. |
09-29-2008, 10:16 | #13 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @FILI THIS SERVER I GET WHEN RUN ULTIMATE UNLOCKER [60.54.216.58.80] SHOULD I SET THIS IN PROXY Code: 13:36:01 Ultimate Unlocker v1.01 by Cruiser Team 13:36:02 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 13:36:02 Initializing... ! 13:36:02 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 13:36:02 2. Choose the phone model ! 13:36:02 3. Select the desired options ! 13:36:02 4. Please connect the phone either via USB while holding 2-5… ! 13:36:02 - or via a serial cable and double-click on it in the device list 13:36:46 Connecting via Generic EMP USB Flash Device (USB7)… 13:36:46 Device driver version: 2.0.0.4 13:36:46 Device driver date: 9-12-2007 13:36:48 Connecting to the baseband CPU... 13:36:48 Entering baseband CPU service mode... 13:36:48 Detected chipset: DB2020 13:36:48 Boot mode: ROM 13:36:48 Sending loader... 13:36:48 IMEI: 35243002281002 13:36:48 Please reconnect the phone (disconnect, connect while holding 2-5) 13:37:01 Sending loader... 13:37:01 Communicating with server… E 13:37:03 Error: 0xE1E2479D E 13:37:03 Error: 0x4D5EFC5D E 13:37:03 Error: 0x4D5EFC5D E 13:37:04 Error: 0x1F41CF97 E 13:37:04 Error: 0x41F19ADB E 13:37:04 Error: 0x51A411A0 E 13:37:04 Error: 0x78E56923 E 13:37:04 Error: 0x5C5AEBE3 E 13:37:04 Error: 0x3D35EAF1 E 13:37:04 Cannot connect to the server E 13:37:04 Failed! ! 13:37:04 Please disconnect battery and cable from the phone! ! 13:37:04 To report errors right-click this window |
09-29-2008, 10:18 | #14 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | @chiragp: man, you should check all in this thread. this morning, proxy for ProxyCap was changed. put there new settings: ProxyCap: IP: 218.204.106.148 port: 80 Settings in the Ultimate Unlocker are always the same! News are only for ProxyCap which you are using ONLY when you have blocked port 9001 by your ISP/goverment, atc.. |
solution for Motorola Phone Connectivity Problems in ET-BoX | sneha | ET-BoX | 1 | 10-04-2008 08:26 |
New Samsung 3G unlock now with microbox for the best price in Tunisia | midou01 | Main Sales Section | 0 | 07-11-2008 01:53 |
02-06-2007 NEW Update server. New system. No more problem in Tunisia and other countr | GSMtricks | Multi-Box | 83 | 06-04-2007 19:32 |
Best Solutions And Best Prices Ever In Tunisia | ::.::HITGSM::.:: | Main Sales Section | 0 | 04-15-2005 00:13 |
!!!!! FIRST DIRECT UNLOCK Solution for SonyEric R6D003 RSA in the World !!!!! | Murphy | Main Sales Section | 0 | 08-26-2004 01:38 |
