w300i not detect cruiser ??? usbsmart unlock dead w300i ,not detect cruiser ????? Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35998800902625 Flash ID: 897E Operation succesfull Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35998800902625 Flash ID: 897E Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Reading flash CXC version Version: R9A036_CXC1123265_ORANGE_JE Send FLASH application Write GDFS Flashloader Switch phone ON Start GDFS Flashloader Recover first flash part ERROR: CXC version not supported for recovery! Please flash MAIN, FS, Complete with any files from Support Area then make Unlock again to solve this error! ------------------------------------ System diagnostics passed. Version 10.36 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2010_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Terminating threads... All threads terminated. Error retrieving more info i am wating for your reply cruiser team........... |
try with newest Version cruiser 10.39 when this not help try with 10.08 baterry mus be fully charged + 3volts for cable manually chose w300i attach phone put cable in phone |
i use 10.39 ,same System diagnostics passed. Version 10.39 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2010_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Error retrieving more info |
i think thats hw problem whan u try to flash with usb smart take error whan loading files and same with crusier if u have se tool try with it....... br raja:cool: |
attach phone with recovery boot cid49 .......... |
Rabiosteam is right, try to attach it in recovery mode, rewrite certificate and reflash the phone. Br |
System diagnostics passed. Version 10.39 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Trying CID49 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 051005 1353 NPA4_CXC1326739_SEMC_CO... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 49 RSA protection is normal. Phone hardware initialized OK |
I had this problem with a w810. Every version above v10 would not connect it. Try v9.68 (you will need to change the date on your computer back a couple of months) It should connect straight away then unlock RSA, flash full gdfs as ARM, and then flash as normal cid49. worked for me many times, but have to use old version of cruiser before v10. regards, mrmcox |
Br |
FLASH WITH "W300_R9A031_MAIN_GENERIC_JE_RED49.mbn and W300_R9A031_FS_AMERICA_2_RED49.fbn.AND "COMPLETE PHONE" USING SEMC 8.7...:) |
1 Attachment(s) he man 1- if you won to solve problem with usbsmart here is the solution worked 100 % for me http:///vbb/showth...ht=flash+w300i :D :D 2- if you won to solve this with cruiser do this unchek "analyse configuration" uncheck "displau more info" like picture attached make battery full and reattch again and flash it as normally ....:D :D :D dont do ATTACH PHONE with recovery ... BE CAREFULL if you have not good experience with cruiser ... and you do mistake ... you will have DAMAGED EROM :mad: |
thanks matrix.real ,my problem solved . @Bypx Phone hardware initialized OK but other options not detect ,only detect (primary or security rsa). |
with usbsmart or cruiser ? and HOW ? do this for all member :D :D :D |
cruiserrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr |
