w550i no signal Hi I had a w550i in with white i succ flashed it & repaired it but now phone shows signal & network but does not allow calls??(phone was not locked by network operator) If iam correct if a phone is barred you usually get"inactive sim" or something like that??? ive done a search on this forum but nothing is clear about this problem but there seems to be problem with this model not getting signal?? after flashing?? Iam pretty much sure i have to flash a gdfs file to repair this prolem?? or iam wrong?? Can any member help? Thanks |
Write full gdfs and then customize fs and then shutdown fs and then direct unlock problem is solved i repared many set through it |
if i write to gdfs it searches for mbc file & cruiser full gdfs fils are ck6sw?? please can you clarify?? Thanks |
You can flash gdfs in flash arm then customize fs then shutdown fs then again attach and unlock |
