W710i (A600i) prototype On back of the phone write: P2-Prototype Phone is not locked and work. Some way for convert like normal W710i ? Software Info: R4AA032 prgCXC1250430_GENERIC_CH Attached like W710i. [ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x9900 Protocol version: 3.1 Baudrate = 460800Bd Trying CID49 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 060712 1258 ALU4_CXC1329130_DB2020_... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 0 (Developer) OTP CID: 36 Phone CID: 49 Phone color: Brown Sending applet... Applet ID: 060919 0941 HANCXC1329134_DB2020_PR... Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 29 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Phone hardware initialized OK Best Regards PS |
DB2020 prototypes are not supported yet |
OK.. Thanks for answer.I will wait for solution :) Best Regards PS |
as a matter of fact i've seen them done before... just : 1. recovery boot cid49 2. attach like normal w710i 3. flash erom 4. turn off phone 5. attach phone 6. flash main FW 7. flash raw FS 8. customise & turn off phone note: just make sure it has otp cid and otp imei locked or else if you try to flash completely empty phone you'll get 5 locks closed. it says cruiser support db2020 empty but i just don't know how to lock the otp cid & imei... hope anybody with ideas around? |
