11-29-2005, 00:23 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Central Florida
Member: 174472 Status: Offline Thanks Meter: 0 | TP Unlock W600i ??? I wondering if anyone had tried to unlock the W600i ??? does it required a TP or Flash the phone before unlock it ?? Thanks |
11-29-2005, 01:18 | #3 (permalink) | |
Member: 174472 Status: Offline Thanks Meter: 0 | Quote:
Where can I find th TP ?? is there a picture I can see on somewhere online ??? cuse there is No tp instruction on support site !! right now , I can able to attach phone on 7.10 .. and there is NO "security Zone" tape , so i can't covert to brown at all ?? all I see after it attach the phone in "Normal Boot type" it shown "Primary>Flash>Locks" usually when it attach a phone , I always see 5 or 6 tapes on the top sections , but not the w600i ?? should I also change the "boot type" to something else instead normal ??? Thanks for the help !! Last edited by Cell_site; 11-29-2005 at 01:39. | |
11-29-2005, 13:52 | #5 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Netherlands
Member: 193781 Status: Offline Thanks Meter: 18 | Quote:
BR | |
11-29-2005, 18:42 | #6 (permalink) |
Member: 174472 Status: Offline Thanks Meter: 0 | Yes, I did look into the Cruiser manual ,in there you'll found TP for K300 ...and even some TP for others phone's .... but not W600i The Support site is Down since yesterday I can't go into search for more TP |
11-29-2005, 22:41 | #7 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 53
Member: 51935 Status: Offline Thanks Meter: 2 | didn't work.. i tried couple times with tp. when I try to replace certificate. It said Replace Failed. Connecting via Fighter USB Cable... Connect the testpoint! Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Trying recovery applet... Sending applet prologue... Disconnect the testpoint! Sending applet body... Time spent entering bootstrap: 6s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK Defeating RSA protection... Defeated! Sending applet... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Red Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Defeating RSA protection... Waiting for the phone to turn off... Connect the testpoint! Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Disconnect the testpoint! Sending applet body... Defeated! Sending applet... Initializing applet... Replacing primary certificate... Phone automatically detached. Replace failed. |
wo TP unlock / no TP unlock | simply-cy | MT-BOX | 0 | 02-08-2010 20:07 |
pls help to unlock w600i with hwk | chiragp | HWK | 3 | 01-22-2006 02:18 |
unlock W600i without tp ? | mashi | Cruiser Suite | 1 | 12-31-2005 08:21 |
can hwk unlock w600i pls | chiragp | HWK | 11 | 12-29-2005 15:25 |
HELP? UNLOCK w600i... | rashidul99 | Cruiser Suite | 1 | 12-24-2005 06:38 |
