Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 11-23-2006, 13:24   #1 (permalink)
intouchce's Avatar
Member: 105154
Thanks Meter: 2
W810 configuration error after unlock
hi,
I am trying to unlock a w810, I have unlocked rsa, restored fw and direct unlocked the phone, however the handset keeps saying "Confiruration error, please contact your network or service provider.
It does not let me do anything else.
Please can someone help.
Thank you
intouchce
Old 11-23-2006, 14:11   #2 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
flash phone following cruiser's manual (filename Cruiser.chm)
Old 11-23-2006, 14:42   #3 (permalink)
david laborator's Avatar
Member: 228601
Thanks Meter: 56
customize fs after flash !
Old 11-23-2006, 14:49   #4 (permalink)
Member: 228601
Thanks Meter: 56
Old 11-23-2006, 14:57   #5 (permalink)
intouchce's Avatar
Member: 105154
Thanks Meter: 2
HI,
thank you for your reply, however I have flashed the fone with the cw81sw and cw81fs fil. howeever I can not find the .chm files. please can you explaion in more detail.
Thank you
intouchce
Old 11-23-2006, 15:34   #6 (permalink)
Member: 122085
load cruiser click on help then introdution, it should load otherwise can try other way
just goto start> run> and type in without quotes
"C:\program files\cruiser\cruiser.chm"
if it doesnt load then you havent installed cruiser correctly
Old 11-23-2006, 17:47   #7 (permalink)
intouchce's Avatar
Member: 105154
Thanks Meter: 2
Thanks,
However it keeps failing customize FS. I have selected the correct lanuage file and typed in the correct FV. Please can you advise.
Thank you
Old 11-23-2006, 18:08   #8 (permalink)
Cryspim's Avatar
Member: 62561
Thanks Meter: 706
Please post here the log file about what you are trying to do. Copy and paste here what appears when you try to customize FS.
b.r.
cryspim
Old 11-23-2006, 18:43   #9 (permalink)
Member: 383021
Thanks Meter: 5
//attach the phone in recovery mode CID49
//change certificate colour to red
//attach phone in normal boot
//unlock RSA
//Main SW
//Raw FS
//customise FS
//shutdown FS
//do a direct unlock
//restore firmware
W810 Configuration error 100% solved by HWK alamgir80 HWK 1 12-03-2008 13:45
w810 Configuration error .??? gsm-iran Universalbox 11 01-20-2007 18:25
w810 configuration error after unlock intouchce Cruiser Suite 5 11-23-2006 19:28
w900i configuration error after unlock... .:GSM International:. Universalbox 3 10-04-2006 19:02
W810 - Configuration error - cruiser taking the piss mobilextreme Cruiser Suite 6 05-11-2006 18:53
Page generated in 0.15310 seconds with 9 queries
