Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 09-24-2008, 17:20   #1 (permalink)
Member: 5653
Thanks Meter: 6
W910 dead ?
W910 dead after unlock with ultimate unlocker, any thoughts ?
   16:49:35 Ultimate Unlocker v1.00 by Cruiser Team
    16:49:35 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
    16:49:35 Initializing...
 !  16:49:35 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
 !  16:49:35 2. Choose the phone model
 !  16:49:36 3. Select the desired options
 !  16:49:36 4. Please connect the phone either via USB while holding 2-5…
 !  16:49:36 - or via a serial cable and double-click on it in the device list
    16:49:52 Connecting via Generic EMP USB Flash Device (USB1)…
    16:49:52 Device driver version: 1.1.0.12
    16:49:52 Device driver date: 9-25-2006
    16:49:52 Connecting to the baseband CPU...
    16:49:52 Entering baseband CPU service mode...
    16:49:53 Detected chipset: DB3150
    16:49:53 Boot mode: ROM
    16:49:53 Sending loader...
    16:49:55 IMEI: 35443202******
    16:49:55 OTP CID: 52
    16:49:55 Product type: Retail
    16:49:55 Effective color: Red
    16:49:57 Sending loader...
    16:49:58 Communicating with server…
    16:50:01 Remainig credit (supreme): 1.00
    16:50:18 Remainig credit (supreme): 1.00
    16:50:18 Converting phone to blue…
    16:50:19 Please reconnect the phone (disconnect, connect while holding 2-5)
    16:50:38 Sending loader...
    16:50:40 IMEI: 35443202******
    16:50:40 OTP CID: 52
    16:50:40 Product type: Retail
    16:50:40 Effective color: Blue
    16:50:41 Sending loader...
    16:50:45 Code NCK for relock: 7903439296162824
    16:50:45 Code NSCK for relock: 9015703456083108
    16:50:45 Code SPCK for relock: 6584123532159972
    16:50:46 Code CCK for relock: 1061752777976504
    16:50:46 Code PCK for relock: 6373920985503536
    16:50:46 Code ESLCK for relock: 3217068361723702
    16:50:46 Code NCK for unlock: 0495759975246543
    16:50:46 Code NSCK for unlock: 3049828396150776
    16:50:46 Code SPCK for unlock: 7453758889401203
    16:50:46 Code CCK for unlock: 7860304121425340
    16:50:46 Code PCK for unlock: 7572220518497967
    16:50:46 Code ESLCK for unlock: 7782650944891042
    16:50:46 To enter a code, type < * * <, on the phone with SIM-card inserted
    16:50:46 Turning off the phone...
    16:50:48 Done.
 !  16:50:48 Please disconnect battery and cable from the phone!
Old 09-24-2008, 17:46   #2 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 471
    16:50:48 Done.
need wait to fix problem on server or use SE FULL UNLOCKER that cost 1x A2 credits and your phone will be ok .
Old 09-24-2008, 21:01   #3 (permalink)
Member: 563167
Thanks Meter: 39
so if am very clear do u mean unlimate unlocker is not free
i mean it can,t unlock w910 4 free??????????
i need good explanation.........
freeeeeeeeeeeeee or not.....
Old 09-24-2008, 21:06   #4 (permalink)
FilipLudvik's Avatar
Member: 135110
Thanks Meter: 302
why do you need explain it? everything was said my Mizar in his first post!
Old 09-24-2008, 21:14   #5 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,783
http://forum.gsmhosting.com/vbb/showthread.php?t=586108
looking at this post from Sucessfull unlock w910
i notice your phone has been left in blue state
maybe this is root of your Problem....
Old 09-24-2008, 21:14   #6 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
Guys use latest version 1.01, it should have no more problems with unlocking.
The Following User Says Thank You to Mainboard For This Useful Post:
Old 09-25-2008, 15:27   #7 (permalink)
Member: 277109
Sonork: 100.1590647
Thanks Meter: 83
yes, it does unlock quickly the phone. but after unlocking, phone becomes BLUE, and cannot be updated with SEUS, and warranty may be void also.
can u fix that soon?
br
Old 09-25-2008, 15:37   #8 (permalink)
Lead's Avatar
Member: 1841
Thanks Meter: 469
br
Yes, an update will be released shortly. This is a minor issue.
Btw, when the phone is blue, one can do virtually anything with the phone, even things that are unthinkable for red phones - like recalculating static CRC, all dynamic CRCs, patching anything anywhere, having full access to the file system, and much-much more. When the phone is blue, everything becomes simple. The point lies in conversion from red to blue everything else (including conversion back to red) is quite trivial.
Regards, Lead
Old 09-25-2008, 17:27   #9 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,783
@ LEAD.
Can i ask will phone switch on in Blue state,??
or like everything else, above cid 36, it has to be Back to red.
thanks.
Old 09-25-2008, 22:29   #10 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 471
Originally Posted by THE CLASH View Post
@ LEAD.
thanks.
Like is write before now with ultimate unlocker 1.01 phone become BLUE and stay in this state untile you not change this. bye
Old 09-25-2008, 22:40   #11 (permalink)
Member: 245173
Is there any major downsides to phone being blue?
Thanks
Dan
Old 09-26-2008, 09:05   #12 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 471
Thanks
Dan
Like was write before can't use SEUS orginal SE software to change firmware in phone only this. bye
Old 09-26-2008, 12:34   #13 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 85
@mainboard
there's a problem with the new version i have 3 phones dead!
1. w610
  15:31:12  SE Ultimate Unlocker v1.01 by Cruiser Team
  15:31:12  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  15:31:12  Initializing...
! 15:31:12  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 15:31:12  2. Choose the phone model
! 15:31:12  3. Select the desired options
! 15:31:12  4. Please connect the phone either via USB while holding 2-5…
! 15:31:12  - or via a serial cable and double-click on it in the device list
  15:31:42  Connecting via Generic EMP USB Flash Device (USB4)…
  15:31:42  Device driver version: 2.1.0.0
  15:31:42  Device driver date: 3-20-2008
  15:31:44  Connecting to the baseband CPU...
  15:31:44  Entering baseband CPU service mode...
  15:31:44  Detected chipset: DB2020
  15:31:44  Boot mode: ROM
  15:31:44  Sending loader...
  15:31:44  IMEI: 35715401891190
  15:31:44  Please reconnect the phone (disconnect, connect while holding 2-5)
  15:31:57  Sending loader...
E 15:31:59  Error: 0x4D5EFC5D
E 15:31:59  Error: 0x10BE36DC
E 15:31:59  Error: 0x59AF7680
E 15:32:00  Failed!
! 15:32:00  Please disconnect battery and cable from the phone!
! 15:32:00  To report errors right-click this window
the phone was working alright! i re-tried the same procedure 3times but still the same ! phoe is DEAD! pls inform what to do!
WBR
ReyTech.
Old 09-26-2008, 12:36   #14 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 85
@Mainboard
This is the second phone W580i which is gone dead! pls see the log below
2. w580i
  15:34:23  SE Ultimate Unlocker v1.01 by Cruiser Team
  15:34:23  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  15:34:23  Initializing...
! 15:34:23  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 15:34:23  2. Choose the phone model
! 15:34:23  3. Select the desired options
! 15:34:23  4. Please connect the phone either via USB while holding 2-5…
! 15:34:23  - or via a serial cable and double-click on it in the device list
  15:35:29  Connecting via Generic EMP USB Flash Device (USB4)…
  15:35:29  Device driver version: 2.1.0.0
  15:35:29  Device driver date: 3-20-2008
  15:35:31  Connecting to the baseband CPU...
  15:35:31  Entering baseband CPU service mode...
  15:35:31  Detected chipset: DB2020
  15:35:31  Boot mode: ROM
  15:35:31  Sending loader...
  15:35:31  IMEI: 35928501840455
  15:35:31  Please reconnect the phone (disconnect, connect while holding 2-5)
  15:35:41  Sending loader...
E 15:35:44  Error: 0x4D5EFC5D
E 15:35:44  Error: 0x10BE36DC
E 15:35:44  Error: 0x59AF7680
E 15:35:44  Failed!
! 15:35:44  Please disconnect battery and cable from the phone!
! 15:35:44  To report errors right-click this window
what is the problem with these unlocker its eating the phones!
WBR
ReTech.
Old 09-26-2008, 14:09   #15 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
@ReyTech
try usual steps, so first of all check if battery is full in both phones. then flash correctly these phone, customize then and then use Ultimate Unlocker. Post results.
Genie dead no power on... [ANSWERED] lchico Genie Universal 1 03-29-2010 07:18
W910 brought dead after flash still dead what next Mansoor SETool2 4 02-27-2010 08:59
W910 dead after bad unlock. manistar SETool2 5 01-06-2009 16:09
w910 i dead inside-d-saul SETool2 10 12-20-2008 03:42
W910 Dead Pleas Help ARS.Rehman SETool2 12 12-08-2008 09:20
Page generated in 0.27962 seconds with 9 queries
