10-25-2004, 19:46 | #1 (permalink) |
Freak Poster Join Date: Dec 2003
Member: 47438 Status: Offline Thanks Meter: 0 | Fighter switches phone on instead of booting it... I have a little problem: my Fighter only turns the phones on when pressing "Attach to phone" instead of booting the phone... What could be the problem? And no, the "charging button" of Fighter is not active... The problem occurs with any phone (tested 4 different mobiles!) Anyone experienced the same problem? I'm happy for any hint! Cheerio, IL |
10-25-2004, 20:09 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Sounds like you either have four faulty phones (not very likely) or you have a cable probem of some sort. First of all, make sure the contacts on the bottom of the phone are nice and clean, plus also check inside for corrosion/bad contacts. You could also try using a T28 cable with Fighter, see if that works ok. Has this problem just started happening? |
10-25-2004, 20:17 | #3 (permalink) |
Member: 47438 Status: Offline Thanks Meter: 0 | Thanks for your answer! Yes, the problem started suddenly. Until yesterday, there was no problem at all... I haven't installed anything additionally, I first thought it could be a communication problem with COM-ports. But Fighter "sees" the cable, and just a few minutes ago, Fighter could also boot the phone. But suddenly after booting (status "initializing phone hardware"), Fighter detached the phone automatically, and it was "dead" again (meaning it started switching on again just after pressing "attach phone")... I just flashed the same phone with Terminator, and that went fine, so it's definitely not a problem with the phone. Contacts seem to be OK, I have the Fighter cable for about 4 weeks now, so it's quite new, I'd say. Very strange, the whole thing... Unfortunately, I don't have any T28 cable. Cheerio, IL |
10-25-2004, 20:36 | #4 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | It sounds like a problem with your cable then. Talk to your reseller and explain the problem to them, see if they'll replace the cable for you. |
10-26-2004, 08:51 | #5 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Russia Age: 52
Member: 5238 Status: Offline Thanks Meter: 2 | @IndianL I have same problem after instaling original PCSuite software for P900. USB port busy. 1. I uninstall PCSuite 2. I uninstall SEFighter. 3. Reboot computer 4. Instal again SEFighter with cable drivers. Hamltd |
10-26-2004, 17:57 | #6 (permalink) |
Member: 47438 Status: Offline Thanks Meter: 0 | @hamltd: That did the trick! Thanks a lot! Although I have installed the PC Suite a few weeks ago already, and Fighter used to work without any problems during that time... Thanks again! Cheerio, IL |
11-20-2004, 22:36 | #8 (permalink) |
No Life Poster Join Date: Dec 2000 Location: uk
Member: 2899 Status: Offline Thanks Meter: 6 | guys hi no need to do anything drastic!!,these sort of thing has happened 2me b4,my trick is partialy take the bat. out and when u hit the attach boton quickly put the bat in!!,it has always worked for me!! br farry |
11-21-2004, 01:14 | #9 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Belgium - SYRIA
Member: 39014 Status: Offline Thanks Meter: 7 | Another trick Ho Friends You can try this procedure .. I tried it before. After you install the PC connect software for P800 or P900 it uses the USB protocls and keeps it for itself. You can see a little ICOn near the clock ( Bottom right corner of windows ) Right click on it and from the setting stop it , and then you can use the fighter . Hope this will be usefull to you. Best regards Raffi |
11-21-2004, 01:45 | #10 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 51
Member: 58552 Status: Offline Thanks Meter: 24 | I have same same problem after instaling Pc suite for Nokia 9500, each time i use fighter i have to uninstall the pc suite. I am geting mad even i have unselect usb cable & serial cable option from connection manager. |
11-21-2004, 15:33 | #11 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Earth
Member: 38573 Status: Offline Thanks Meter: 0 | ummm.. It still does the same thing on my computer.. What I did is connect the phone without battery to the fighter cable, then choose attach phone, when fighter is trying to activate the phone, put the battery in, then everything works.... Don't know why, but it works on me.. Cheers flin898 |
09-06-2006, 05:03 | #12 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | it doesnt work for me ... am using FIGHTER CABLE!! Please help!! Am trying to unlock a V600i.. what should i do?? let it power the phone by itself or manuel ignition??? as i connect the cable it start charging..... |
09-06-2006, 08:46 | #13 (permalink) | |
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
If that doesn't work, examine the phone's contacts. | |
WHY MICROBOX removing this model instead of RESOLVING it? // mistake, they work on it | xannix_7575 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 05-12-2009 12:40 |
Cannot unlcok W800 -Phone turns ON instead of booting. | crossings | SonyEricsson (USB-Smart) | 5 | 12-27-2005 13:11 |
why is it that sometimes t616s turn on instead of unlock? | aarons6 | SonyEricsson (USB-Smart) | 3 | 12-26-2005 06:44 |
C55: instead of charging it discharges battery | robbie | Siemens Hardware Repair Area | 7 | 03-04-2005 23:12 |
Support required - LGC1200 - phone tunrs on instead of unlocking | Jon Parker | FuriouS II | 5 | 11-11-2004 23:11 |
