Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 06-05-2007, 07:18   #1 (permalink)
Member: 479438
Thumbs up Unlock DB2020 - EROM Downgrade CID52 to CID49 NEED!!!
Hi Cruiser team,
Due to the only solution unlock db2020 available now, we have to unlock the db2020 with CID49/51.
I recommended cruiser should provide help for those who upgrade the EROM by cruiser due to almost flash files are CID52 or must update to CID52 for flashing...
Could you provide the option/procedure to downgrade the phone CID52 RED to CID49 RED with DB2020 with OTP CID49?
Best Regards
lmckdhu
PS: The option EROM upgrade to CID52 should deactivate for all DB2020 phones didn't unlock yet.
Old 06-05-2007, 07:41   #2 (permalink)
cellectro's Avatar
Member: 73310
Thanks Meter: 3
Originally Posted by lmckdhu View Post
Hi Cruiser team,
Best Regards
lmckdhu
maybe they will tell you to buy id08 to do downgrade
Old 06-05-2007, 08:50   #3 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
@lmckdhu
You definitelly have no idea what is EROM and what is CID.
1. You need always upgrade EROM (to version R3A016 or higher).
2. CID is what is 52 version, and CID can be NOT downgraded.
3. CID is upgraded when you use function "Upgrade CID to 52" from GDFS tab or when you use SEUS program.
4. CID is NOT upgraded with function Repair EROM!!!!
Old 07-25-2007, 07:19   #4 (permalink)
Member: 183834
Thanks Meter: 6
I think the CID52 exists in the GDFS area, when can be downgraded?
Old 07-25-2007, 07:58   #5 (permalink)
Arif Jamil's Avatar
Member: 192080
Thanks Meter: 3
this is big issue plz. cruiser team...
give us same way to do that.........
thanks
Old 07-25-2007, 08:10   #6 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Mate it cannot be Downgrade
Old 07-25-2007, 17:22   #7 (permalink)
luzer's Avatar
Member: 44659
Thanks Meter: 363
Forget about CID downgrade, isn't possible ... why do you think unlock by patch was released in the first place?
Old 07-25-2007, 17:39   #8 (permalink)
siang8788's Avatar
Member: 205283
Thanks Meter: 80
only do hardware can downgrade cid!
P990i GDFS Reconstruction and certificate change from CID52 to CID49 successful! rquilatan Cruiser Suite 1 05-14-2009 09:42
k550 cid52 to cid49 after repair GDFS why !!!!!!! seddik-gsm Sony Ericsson 4 01-28-2009 06:59
How To Downgrade CID52 to 49 for DB2010 david_davood DreamBox 2 06-23-2008 20:18
@ LEAD , I need CID52 DB2020 EROM file , PLS REPLY rjsoo7 Cruiser Suite 5 05-21-2007 16:56
I Need Downgrade Cid52 To Cid51 GSM_HACKING2003 MT-BOX 2 05-20-2007 14:49
Page generated in 0.19333 seconds with 9 queries
