06-13-2008, 01:10 | #4 (permalink) |
Crazy Poster Join Date: Jun 2006 Location: brasil Age: 43
Member: 288247 Status: Offline Thanks Meter: 5 | this happens in the end w380i pnx5230 last cid53 in connection with the pc's time to end that sends the loader the ap league restarts the phone i activating the failure Code: 20:23:47 SE A1 Java Unlocker v1.02 by Cruiser Team 20:23:47 Initializing... ! 20:23:47 1. Choose the phone model ! 20:23:47 2. Select main firmware flash file (*.a1sw) ! 20:23:47 3. Select raw FS flash file (*.a1fs) ! 20:23:47 4. Please connect the phone while holding its C button… 20:24:04 Connecting via Generic EMP USB Flash Device (USB1)… 20:24:04 Device driver version: 2.1.0.0 20:24:04 Device driver date: 3-20-2008 20:24:04 Connecting to the baseband CPU... 20:24:04 Entering baseband CPU service mode... 20:24:05 Detected chipset: PNX5230 20:24:05 Boot mode: EROM 20:24:05 EROM version: R4A015 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 20:24:05 Initializing flash files... 20:24:11 Sending loader... 20:24:11 Sending loader... 20:24:11 About to flash 40 MB of data… 20:29:21 Sending loader... 20:29:24 System starting up... 20:29:24 GDFS starting up... 20:29:29 FS starting up... 20:29:58 FS data uploading... ! 20:30:10 1. Please disconnect battery and cable from the phone! ! 20:30:10 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 20:30:10 3. Wait to customize finish ! 20:30:10 4. Turn off the phone ! 20:30:10 5. Please connect the phone while holding its C button… 20:59:23 Connecting via Generic EMP USB Flash Device (USB1)… 20:59:23 Device driver version: 2.1.0.0 20:59:23 Device driver date: 3-20-2008 20:59:23 Connecting to the baseband CPU... 20:59:23 Entering baseband CPU service mode... 20:59:23 Detected chipset: PNX5230 20:59:23 Boot mode: EROM 20:59:23 EROM version: R4A015 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 20:59:23 Sending loader... 20:59:24 Sending loader... 20:59:24 Sending loader... 20:59:27 System starting up... 20:59:27 GDFS starting up... 20:59:29 FS starting up... 20:59:30 FS data uploading... ! 20:59:45 1. Please disconnect battery and cable from the phone! ! 20:59:45 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 20:59:45 3. Connect the phone again ! 20:59:45 4. If asked, Install phone drivers ! 20:59:45 5. Choose 'PHONE MODE' in the phone ! 21:01:35 After choosing 'PHONE MODE' press the Ready button 21:01:52 Connecting via SEMC WMC Device (COM30, COM29)… 21:01:52 Device driver version: 4.40.8.1 21:01:52 Device driver date: 9-5-2007 ! 21:02:19 1. Please disconnect battery and cable from the phone! ! 21:02:19 2. Please connect the phone while holding its C button… 21:03:21 Connecting via Generic EMP USB Flash Device (USB1)… 21:03:21 Device driver version: 2.1.0.0 21:03:21 Device driver date: 3-20-2008 21:03:21 Connecting to the baseband CPU... 21:03:21 Entering baseband CPU service mode... 21:03:22 Detected chipset: PNX5230 21:03:22 Boot mode: EROM 21:03:22 EROM version: R4A015 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 21:03:22 Sending loader... E 21:03:33 Error: 0xA8A269DB E 21:03:33 Error: 0xA8A269DB E 21:03:33 Error: 0x53E0AA3B E 21:03:33 Error: 0xB3721AB7 E 21:03:33 Error: 0xFD9ABCA6 E 21:03:33 Error: 0x0370C306 E 21:03:33 Error: 0xF8146F89 E 21:03:33 Error: 0x05190628 E 21:03:33 Error: 0xA8A269DB E 21:03:33 Error: 0x6C729765 E 21:03:33 Error: 0x8CDFAB78 E 21:03:33 Error: 0xC8AE715C E 21:03:33 Error: 0x72356A18 E 21:03:33 Error: 0x3869464D E 21:03:33 Cable disconnect detected E 21:03:33 Cable disconnect detected E 21:03:33 Cable disconnect detected E 21:03:33 Failed! ! 21:03:33 Please disconnect battery and cable from the phone! ! 21:03:33 To report errors right-click this window |
06-13-2008, 12:49 | #5 (permalink) | |
Freak Poster Join Date: Sep 2003
Member: 39216 Status: Offline Thanks Meter: 23 | Quote:
i got same error on a w710 but when testing the phone it was unlocked :P | |
06-19-2008, 16:23 | #6 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 263709 Status: Offline Thanks Meter: 327 | W880i CID53 unlock failed Code: 18:59:48 SE A1 Java Unlocker v1.02 by Cruiser Team 18:59:48 Initializing... ! 18:59:48 1. Choose the phone model ! 18:59:48 2. Select main firmware flash file (*.a1sw) ! 18:59:48 3. Select raw FS flash file (*.a1fs) ! 18:59:48 4. Please connect the phone while holding its C button… 19:00:24 Connecting via SEMC USB Flash Device (USB1)… 19:00:24 Device driver version: 2.1.0.0 19:00:24 Device driver date: 3-20-2008 19:00:24 Connecting to the baseband CPU... 19:00:24 Entering baseband CPU service mode... 19:00:24 Detected chipset: DB2020 19:00:24 Boot mode: EROM 19:00:24 EROM version: R3A016 prgCXC1250614_EROM_DB2020_AI_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 19:00:24 Initializing flash files... 19:00:30 Sending loader... 19:00:30 Sending loader... 19:00:30 About to flash 39 MB of data… 19:05:23 Sending loader... 19:05:25 System starting up... 19:05:25 GDFS starting up... 19:05:44 FS starting up... 19:05:59 FS data uploading... ! 19:06:09 1. Please disconnect battery and cable from the phone! ! 19:06:09 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 19:06:09 3. Wait to customize finish ! 19:06:09 4. Turn off the phone ! 19:06:09 5. Please connect the phone while holding its C button… 19:08:28 Connecting via SEMC USB Flash Device (USB1)… 19:08:28 Device driver version: 2.1.0.0 19:08:28 Device driver date: 3-20-2008 19:08:28 Connecting to the baseband CPU... 19:08:28 Entering baseband CPU service mode... 19:08:29 Detected chipset: DB2020 19:08:29 Boot mode: EROM 19:08:29 EROM version: R3A016 prgCXC1250614_EROM_DB2020_AI_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 19:08:29 Sending loader... 19:08:29 Sending loader... 19:08:29 Sending loader... 19:08:31 System starting up... 19:08:31 GDFS starting up... 19:08:55 FS starting up... 19:08:58 FS data uploading... ! 19:09:12 1. Please disconnect battery and cable from the phone! ! 19:09:12 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 19:09:12 3. Connect the phone again ! 19:09:12 4. If asked, Install phone drivers ! 19:09:12 5. Choose 'PHONE MODE' in the phone ! 19:16:43 After choosing 'PHONE MODE' press the Ready button 19:18:32 Connecting via SEMC WMC Device (COM18, COM17)… 19:18:32 Device driver version: 4.34.0.2705 19:18:32 Device driver date: 7-25-2006 E 19:19:12 Error: 0xA8A269DB E 19:19:12 Error: 0xA8A269DB E 19:19:12 Error: 0x53E0AA3B E 19:19:12 Error: 0xB3721AB7 E 19:19:12 Error: 0xFD9ABCA6 E 19:19:12 Error: 0x0370C306 E 19:19:12 Error: 0xF8146F89 E 19:19:12 Error: 0x1BEB4B4F E 19:19:12 Error: 0x5EE7F36A E 19:19:12 Error: 0x52AB8D61 E 19:19:12 Error: 0x156B39A6 E 19:19:12 Cable disconnect detected E 19:19:12 Cable disconnect detected E 19:19:12 Failed! ! 19:19:12 Please disconnect battery and cable from the phone! ! 19:19:12 To report errors right-click this window |
06-19-2008, 18:14 | #8 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Near the sea... Portugal Age: 48
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | Quote:
Z310i CID 52: SE A1 Java Unlocker v1.10 by Cruiser Team 16:30:51 Initializing... ! 16:30:51 1. Choose the phone model ! 16:30:51 2. Select main firmware flash file (*.a1sw) ! 16:30:51 3. Select raw FS flash file (*.a1fs) ! 16:30:51 4. Please connect the phone while holding its C button… 16:32:05 Connecting via Generic EMP USB Flash Device (USB1)… 16:32:05 Device driver version: 1.1.0.12 16:32:05 Device driver date: 9-25-2006 16:32:05 Connecting to the baseband CPU... 16:32:05 Entering baseband CPU service mode... 16:32:06 Detected chipset: PNX5230 16:32:06 Boot mode: EROM 16:32:06 EROM version: R4A012 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFL A_SIBLEY_SEMCUSB 16:32:06 Initializing flash files... 16:32:11 Sending loader... 16:32:11 Sending loader... 16:32:11 About to flash 32 MB of data… 16:34:43 Sending loader... 16:34:45 System starting up... 16:34:45 GDFS starting up... 16:34:49 FS starting up... 16:35:10 FS data uploading... ! 16:35:17 1. Please disconnect battery and cable from the phone! ! 16:35:17 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 16:35:17 3. Wait to customize finish ! 16:35:17 4. Turn off the phone ! 16:35:17 5. Please connect the phone while holding its C button… 16:37:03 Connecting via Generic EMP USB Flash Device (USB1)… 16:37:03 Device driver version: 1.1.0.12 16:37:03 Device driver date: 9-25-2006 16:37:03 Connecting to the baseband CPU... 16:37:03 Entering baseband CPU service mode... 16:37:04 Detected chipset: PNX5230 16:37:04 Boot mode: EROM 16:37:04 EROM version: R4A012 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFL A_SIBLEY_SEMCUSB 16:37:04 Sending loader... 16:37:04 Sending loader... 16:37:05 Sending loader... 16:37:07 System starting up... 16:37:07 GDFS starting up... 16:37:12 FS starting up... 16:37:13 FS data uploading... ! 16:37:22 1. Please disconnect battery and cable from the phone! ! 16:37:22 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 16:37:22 3. Connect the phone again ! 16:37:22 4. If asked, Install phone drivers ! 16:37:22 5. Choose 'PHONE MODE' in the phone ! 16:38:51 After choosing 'PHONE MODE' press the 'Ready' button 16:38:57 Connecting via SEMC WMC Device (COM26, COM25)… 16:38:57 Device driver version: 4.40.2.0 16:38:57 Device driver date: 4-10-2007 ! 16:39:03 1. Please disconnect battery and cable from the phone! ! 16:39:03 2. Please connect the phone while holding its C button… 16:39:20 Connecting via Generic EMP USB Flash Device (USB1)… 16:39:20 Device driver version: 1.1.0.12 16:39:20 Device driver date: 9-25-2006 16:39:20 Connecting to the baseband CPU... 16:39:20 Entering baseband CPU service mode... 16:39:20 Detected chipset: PNX5230 16:39:20 Boot mode: EROM 16:39:20 EROM version: R4A012 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFL A_SIBLEY_SEMCUSB 16:39:20 Sending loader... 16:39:21 Sending loader... 16:39:21 About to flash 1 MB of data… 16:39:30 Done. ! 16:39:30 1. Please disconnect battery and cable from the phone! ! 16:39:30 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 16:39:30 3. Go to Entertainment and select Games. ! 16:39:30 4. Delete executor file. ! 16:39:30 5. Turn off the phone | |
06-20-2008, 11:40 | #10 (permalink) |
Member deceased !! Join Date: May 1999 Location: Austria Age: 53
Member: 14 Status: Offline Thanks Meter: 5 | k770i cid 53 Code: 12:23:44 SE A1 Java Unlocker v1.10 by Cruiser Team 12:23:44 Initializing... ! 12:23:44 1. Choose the phone model ! 12:23:44 2. Select main firmware flash file (*.a1sw) ! 12:23:44 3. Select raw FS flash file (*.a1fs) ! 12:23:44 4. Please connect the phone while holding its C button… 12:24:36 Connecting via SEMC USB Flash Device (USB1)… 12:24:36 Device driver version: 2.0.0.4 12:24:36 Device driver date: 9-12-2007 12:24:36 Connecting to the baseband CPU... 12:24:36 Entering baseband CPU service mode... 12:24:37 Detected chipset: DB2020 12:24:37 Boot mode: EROM 12:24:37 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 12:24:37 Initializing flash files... 12:24:42 Sending loader... 12:24:42 Sending loader... 12:24:42 About to flash 40 MB of data… 12:29:45 Sending loader... 12:29:47 System starting up... 12:29:47 GDFS starting up... 12:30:03 FS starting up... 12:30:21 FS data uploading... ! 12:30:26 1. Please disconnect battery and cable from the phone! ! 12:30:26 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 12:30:26 3. Wait to customize finish ! 12:30:26 4. Turn off the phone ! 12:30:26 5. Please connect the phone while holding its C button… 12:33:18 Connecting via SEMC USB Flash Device (USB1)… 12:33:18 Device driver version: 2.0.0.4 12:33:18 Device driver date: 9-12-2007 12:33:18 Connecting to the baseband CPU... 12:33:18 Entering baseband CPU service mode... 12:33:19 Detected chipset: DB2020 12:33:19 Boot mode: EROM 12:33:19 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 12:33:19 Sending loader... 12:33:19 Sending loader... 12:33:19 Sending loader... 12:33:21 System starting up... 12:33:21 GDFS starting up... 12:33:40 FS starting up... 12:33:44 FS data uploading... ! 12:33:53 1. Please disconnect battery and cable from the phone! ! 12:33:53 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 12:33:53 3. Connect the phone again ! 12:33:53 4. If asked, Install phone drivers ! 12:33:53 5. Choose 'PHONE MODE' in the phone ! 12:35:22 After choosing 'PHONE MODE' press the 'Ready' button 12:35:38 Connecting via SEMC WMC Device (COM66, COM65)… 12:35:38 Device driver version: 4.40.2.0 12:35:38 Device driver date: 6-1-2007 ! 12:35:44 1. Please disconnect battery and cable from the phone! ! 12:35:44 2. Please connect the phone while holding its C button… 12:36:11 Connecting via SEMC USB Flash Device (USB1)… 12:36:11 Device driver version: 2.0.0.4 12:36:11 Device driver date: 9-12-2007 12:36:11 Connecting to the baseband CPU... 12:36:11 Entering baseband CPU service mode... 12:36:12 Detected chipset: DB2020 12:36:12 Boot mode: EROM 12:36:12 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 12:36:12 Sending loader... 12:36:13 Sending loader... 12:36:13 About to flash 1 MB of data… 12:36:26 Done. ! 12:36:26 1. Please disconnect battery and cable from the phone! ! 12:36:26 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 12:36:26 3. Go to Entertainment and select Games. ! 12:36:26 4. Delete executor file. ! 12:36:26 5. Turn off the phone |
06-24-2008, 08:21 | #12 (permalink) |
Freak Poster Join Date: May 2005 Age: 43
Member: 143802 Status: Offline Sonork: 100.1585023 Thanks Meter: 15 | Z310i cid 52 Java unlocking successfully done Code: 12:42:18 SE A1 Java Unlocker v1.10 by Cruiser Team 12:42:18 Initializing... ! 12:42:18 1. Choose the phone model ! 12:42:18 2. Select main firmware flash file (*.a1sw) ! 12:42:18 3. Select raw FS flash file (*.a1fs) ! 12:42:18 4. Please connect the phone while holding its C button… 12:42:46 Connecting via Generic EMP USB Flash Device (USB3)… 12:42:46 Device driver version: 2.0.0.4 12:42:46 Device driver date: 9-12-2007 12:42:46 Connecting to the baseband CPU... 12:42:46 Entering baseband CPU service mode... 12:42:47 Detected chipset: PNX5230 12:42:47 Boot mode: EROM 12:42:47 EROM version: R4A012 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 12:42:47 Initializing flash files... 12:42:50 Sending loader... 12:42:50 Sending loader... 12:42:50 Sending loader... 12:42:53 System starting up... 12:42:53 GDFS starting up... 12:43:00 FS starting up... 12:43:00 FS data uploading... ! 12:43:09 1. Turn on the phone with inserted test card or sim card for which is the phone locked ! 12:43:09 2. Go to Entertainment and select Games. ! 12:43:09 3. Select/Run executor file and java program will run. For a few seconds phone will turn off. ! 12:43:09 4. Wait for about 5 seconds. ! 12:43:09 5. Please disconnect battery and cable from the phone! ! 12:43:09 6. Please connect the phone while holding its C button… 12:45:11 Connecting via Generic EMP USB Flash Device (USB3)… 12:45:11 Device driver version: 2.0.0.4 12:45:11 Device driver date: 9-12-2007 12:45:11 Connecting to the baseband CPU... 12:45:11 Entering baseband CPU service mode... 12:45:11 Detected chipset: PNX5230 12:45:11 Boot mode: EROM 12:45:11 EROM version: R4A012 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 12:45:11 Sending loader... 12:45:11 Sending loader... 12:45:12 About to flash 1 MB of data… 12:45:21 Done. ! 12:45:21 1. Please disconnect battery and cable from the phone! ! 12:45:21 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 12:45:21 3. Go to Entertainment and select Games. ! 12:45:21 4. Delete executor file. ! 12:45:21 5. Turn off the phone |
06-24-2008, 20:38 | #14 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Slovakia
Member: 42020 Status: Offline Thanks Meter: 11 | K530 is unlock ok only W200 error Code: 09:23:48 SE A1 Java Unlocker v1.10 by Cruiser Team 09:23:48 Initializing... ! 09:23:48 1. Choose the phone model ! 09:23:48 2. Select main firmware flash file (*.a1sw) ! 09:23:48 3. Select raw FS flash file (*.a1fs) ! 09:23:48 4. Please connect the phone while holding its C button… 09:24:51 Connecting via SEMC USB Flash Device (USB1)… 09:24:51 Device driver version: 2.1.0.0 09:24:51 Device driver date: 3-20-2008 09:24:51 Connecting to the baseband CPU... 09:24:51 Entering baseband CPU service mode... 09:24:51 Detected chipset: DB2020 09:24:51 Boot mode: EROM 09:24:51 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 09:24:51 Initializing flash files... 09:25:00 Sending loader... 09:25:00 Sending loader... 09:25:00 Sending loader... 09:25:00 About to flash 41 MB of data… 09:30:07 Sending loader... 09:30:09 System starting up... 09:30:09 GDFS starting up... 09:30:24 FS starting up... 09:30:38 FS data uploading... ! 09:30:44 1. Please disconnect battery and cable from the phone! ! 09:30:44 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 09:30:44 3. Wait to customize finish ! 09:30:44 4. Turn off the phone ! 09:30:44 5. Please connect the phone while holding its C button… 09:32:47 Connecting via SEMC USB Flash Device (USB1)… 09:32:47 Device driver version: 2.1.0.0 09:32:47 Device driver date: 3-20-2008 09:32:47 Connecting to the baseband CPU... 09:32:47 Entering baseband CPU service mode... 09:32:47 Detected chipset: DB2020 09:32:47 Boot mode: EROM 09:32:47 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 09:32:47 Sending loader... 09:32:48 Sending loader... 09:32:48 Sending loader... 09:32:48 Sending loader... 09:32:50 System starting up... 09:32:50 GDFS starting up... 09:33:11 FS starting up... 09:33:15 FS data uploading... ! 09:33:24 1. Please disconnect battery and cable from the phone! ! 09:33:24 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 09:33:24 3. Connect the phone again ! 09:33:24 4. If asked, Install phone drivers ! 09:33:24 5. Choose 'PHONE MODE' in the phone ! 09:34:01 After choosing 'PHONE MODE' press the 'Ready' button 09:34:07 Connecting via SEMC WMC Device (COM56, COM55)… 09:34:07 Device driver version: 4.40.2.0 09:34:07 Device driver date: 4-4-2007 ! 09:34:13 1. Please disconnect battery and cable from the phone! ! 09:34:13 2. Please connect the phone while holding its C button… 09:34:27 Connecting via SEMC USB Flash Device (USB1)… 09:34:27 Device driver version: 2.1.0.0 09:34:27 Device driver date: 3-20-2008 09:34:27 Connecting to the baseband CPU... 09:34:27 Entering baseband CPU service mode... 09:34:27 Detected chipset: DB2020 09:34:27 Boot mode: EROM 09:34:27 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 09:34:27 Sending loader... 09:34:28 Sending loader... 09:34:28 About to flash 1 MB of data… 09:34:41 Done. ! 09:34:41 1. Please disconnect battery and cable from the phone! ! 09:34:41 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 09:34:41 3. Go to Entertainment and select Games. ! 09:34:41 4. Delete executor file. ! 09:34:41 5. Turn off the phone |
Post here successfully job with Z3X-BOX Samsung (2010-2018) | mk | Z3X-Team Products | 21273 | 11-19-2018 09:21 |
Post Here Successfully Unlock & Flash With Last Release | denard | HWK | 55 | 02-11-2009 15:53 |
Post Here Successfully unlocked using SE A1 Fast Java unlocker | bhart | Cruiser Suite | 90 | 01-27-2009 22:07 |
Post here Successful Unlocked phones With JavaUnlocker | EMINEMGSM | Cruiser Suite | 32 | 06-30-2008 08:59 |
Post here Successfully unlocked phones by free patches | reactos | Sony Ericsson | 3 | 01-10-2008 22:06 |
