Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 04-03-2007, 19:45   #1 (permalink)
Member: 310155
Thanks Meter: 1,313
W810i unlock ?
hi all,
how can i unlock W810i with CRUISER ?
please step by step prossase....................
its need TP or not ??
thanks for help
Old 04-03-2007, 19:47   #2 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
You don't need any TP..
Older phones with unlocked EROM area:
· Connect the phone to the cable and select Normal boot.
· Attach Cruiser to the phone.
· Go to the Security RSA page and replace the certificate by Brown CID49. Remove battery when asked by Cruiser. If this process fails, the phone has a locked-down EROM area and therefore it cannot be converted to Brown CID49.
· Now press the Direct Unlock button.
Newer phones with locked-down EROM area:
· Be sure to have installed the latest Cruiser firmware restoral package from our support area.
· Go to the Security RSA page and press the Unlock RSA button. Remove battery when asked by Cruiser.
 This will overwrite part of main firmware by special code thus causing the phone to appear "dead".
· Reinsert the battery and reattach Cruiser to the phone.
· Go to the Security RSA page and press the Restore firmware button. Cruiser will search for a restore file then. If it cannot be found, you will also have to reflash main FW and raw FS and to customize the phone.
· Now go to the Locks page and press the Direct unlock button. Remember, if you encounter any new firmware it is wise to make a security zone backup too (or a full GDFS backup).
Note: You may use the Ctrl-A key combination to attach the phone and the Ctrl-O key combination to turn the phone off.
Bypx
PS: The user manual is a very good friend.
Old 04-03-2007, 19:50   #3 (permalink)
MATRIX.REAL's Avatar
Member: 202333
Thanks Meter: 178
NO NEED TP FRIEND ...
just do attach phone
unlock rsa
attach phone again
direct unlock
RESTORE FIRM
already posted
PLZ next time use search button or read manual guide ...
Old 04-03-2007, 19:57   #4 (permalink)
Member: 310155
Thanks Meter: 1,313
thanks all ......................... for ur help
Old 04-08-2007, 09:22   #5 (permalink)
hrkgloballinks's Avatar
Member: 129536
Thanks Meter: 9
I have simlar problem but I could not attach the phone.What can I do?
Old 04-11-2007, 04:53   #6 (permalink)
Member: 275590
Thanks Meter: 41
Arrow
how to flash k550i? with crusier or setool
Old 04-27-2007, 22:44   #7 (permalink)
tito millo's Avatar
Member: 390642
Sonork: 100.1573430
Thanks Meter: 2,476
Originally Posted by reaz.com View Post
hi all,
thanks for help
Ok u need to:
1.Attach the phone
2.Go to security tab then unlock rsa
3.Attach again
4.Go to security tabs and restore frimware
5.Then go to lock tabs and press direct unlock
BR,
Tito Millo
Old 04-27-2007, 22:50   #8 (permalink)
tito millo's Avatar
Member: 390642
Sonork: 100.1573430
Thanks Meter: 2,476
For db2020 flashing u need to use logs....only u have to do this:
1.Attach the phone
2.Go to flash tab and write sw and fs
3.Then selec the languaje that u want in the tab down teh custimize option and cuztomize fs
4.Go to file systen tab and shutdown Fs
BR,
Tito Millo
Old 05-30-2007, 17:36   #9 (permalink)
Member: 363420
I realy arreciate your advice
unlock rsa
attach phone again
direct unlock
RESTORE FIRM
already posted
Thank you very much for your help and support.
Your procedure works 100%
Your are good
With regards
Old 06-09-2007, 23:33   #10 (permalink)
unlockcare.us's Avatar
Member: 343670
Sonork: N/A
Thanks Meter: 572
hi all,
thanks for help
Sohel vi And w810i
Old 07-23-2007, 13:26   #11 (permalink)
salama10's Avatar
Member: 341812
Thanks Meter: 7
System diagnostics passed.
Version 10.42 alpha ready!
[ --- Attach to Phone --- ]
Connecting via UC-10 Universal Cable...
Powering on the phone...
always that messege appear
reinsert battery nothing
wat can i do i tried more times
please helping
Old 07-24-2007, 10:54   #12 (permalink)
salama10's Avatar
Member: 341812
Thanks Meter: 7
noone answer
that problem has no solution?
Old 07-24-2007, 14:23   #13 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,785
please helping
******* CLICK Attach again******
w810i unlock wayne_icu SonyEricsson (USB-Smart) 25 07-24-2006 19:20
w810i unlock help smart phones SonyEricsson (USB-Smart) 16 05-07-2006 22:11
so solution for W810i unlock ??? the new SonyEricsson (USB-Smart) 6 04-14-2006 00:45
w810i unlock ????? gadzetxp MT-BOX 0 04-11-2006 21:41
Page generated in 0.28324 seconds with 9 queries
