06-26-2009, 22:48 | #1 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1062278 Status: Offline Thanks Meter: 0 | Inactive Sim message on w910i after using D-Ultimate Unlocker. Code: 22:14:41 D-Ultimate Unlocker v3.07 by Cruiser Team 22:14:41 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 22:14:41 Initializing... ! 22:14:41 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 22:14:41 2. Choose the phone model ! 22:14:41 3. Select the desired options ! 22:14:41 4. Please connect the phone either via USB while holding 2-5… ! 22:14:41 - or via a serial cable and double-click on it in the device list 22:14:59 Selected phone: W910 22:14:59 Connecting via Generic EMP USB Flash Device (USB1)… 22:14:59 Device driver version: 2.1.0.0 22:14:59 Device driver date: 3-20-2008 22:15:00 Connecting to the baseband CPU... 22:15:00 Entering baseband CPU service mode... 22:15:00 Detected chipset: DB3150 P2B/R2A 22:15:00 Boot mode: ROM 22:15:01 Sending loader... 22:15:03 IMEI: 35443202492831 22:15:03 OTP CID: 52 22:15:03 Product type: Retail 22:15:03 Effective color: Blue 22:15:05 Sending loader... 22:15:08 Writing flash… 22:15:09 Code NCK for relock: 1094244971550812 22:15:09 Code NSCK for relock: 6974315695319792 22:15:09 Code SPCK for relock: 4365135831901076 22:15:09 Code CCK for relock: 5590739086421463 22:15:09 Code PCK for relock: 5003228055926589 22:15:09 Code ESLCK for relock: 4043190931454136 22:15:09 Code NCK for unlock: 7448260102102556 22:15:09 Code NSCK for unlock: 0069136697015491 22:15:09 Code SPCK for unlock: 1887186052587664 22:15:09 Code CCK for unlock: 0833362045230056 22:15:09 Code PCK for unlock: 0040956237549891 22:15:09 Code ESLCK for unlock: 8149499945451150 22:15:09 To enter a code, type < * * < on the phone with SIM-card inserted 22:15:10 Turning off the phone... 22:15:12 Done. This is my first attempt at using your software. Having followed the instructions, when I have inserted three different network sims I have got the "Inactive Sim" message on the phone. I have also tried to enter a code manually by the above instruction. After I press the left arrow for the second time the cursor moves between the two stars. After entering the code, nothing happens. (Am I doing this right?) I look forward to your help. |
06-29-2009, 16:40 | #3 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 25671 Status: Offline Thanks Meter: 719 | Unlocking is done, if not you see "Insert correct SIM" or similar. Inactive SIM is not related with unlock, check with your provider if SIM is ok, if phone is not stolen etc. |
k660i unlock done using Cruiser Ultimate Unlocker v3.05 | wiltelcom | Cruiser Suite | 0 | 11-27-2008 11:24 |
id 06 using se ultimate unlocker?? | tshcom | Cruiser Suite | 0 | 11-14-2008 11:39 |
Cid changed to brown 49 using se ultimate unlocker | nasagih | Cruiser Suite | 16 | 11-06-2008 20:52 |
d-client log can use for ultimate unlocker | gsmsky | D-Unlock Suite | 2 | 10-12-2008 12:15 |
after use se ultimate | awenaw | Cruiser Suite | 6 | 10-10-2008 11:12 |
