06-02-2009, 09:44 | #1 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1044098 Status: Offline Sonork: ajya Thanks Meter: 0 | Pls help me to connect with server........ account detail: Account Type : D-Account (non-card) Total Standard Logs : 0.00 Total Supreme Logs : 1.00 how to check my account is active or not? and server is connected or not? can i use D ultimate unlocker and D unlocker ? i'm tried to get credit info but following error msg received..? Code: 11:02:11 D-Ultimate Unlocker v3.07 by Cruiser Team 11:02:12 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:02:12 Initializing... ! 11:02:12 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:02:12 2. Choose the phone model ! 11:02:12 3. Select the desired options ! 11:02:12 4. Please connect the phone either via USB while holding 2-5… ! 11:02:12 - or via a serial cable and double-click on it in the device list 11:02:28 Communicating with server… E 11:02:29 Error: 0xE1E2479D E 11:02:29 Error: 0x1F41CF97 E 11:02:29 Cannot connect to the server E 11:02:29 Failed! ! 11:02:29 To report errors right-click this window i think it's a server problem? server settings r changed? |
06-02-2009, 12:47 | #3 (permalink) | |
Member: 1044098 Status: Offline Sonork: ajya Thanks Meter: 0 | Quote:
thanks 4 d reply...i'll contact my reseller...can i use this account for both D unlocker/D ultimate unlocker..? I want to repair my GDFS(K790i-cid53) and downgrade d cid into 52..pls give me d procedure..? | |
06-02-2009, 14:19 | #4 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 25671 Status: Offline Thanks Meter: 719 | Normally you can share your account with D-Unlocker and D-Ultimate Unlocker, but maybe you know that D-Unlocker is offline for few months now, so you can use only D-Ultimate Unlocker 3.07 at this time. |
06-04-2009, 11:15 | #5 (permalink) | |
can i check my credit balance & Account Activity via cruiser website..? i'm tried to connect without username,pswd..the same problem(same error log) exist..is that the problem is in d internet connection or with the username,pswd..?actually i'm using my office pc(ethernet LAN)...so connecting via common gateway..is that any problem..? | |
06-05-2009, 12:53 | #7 (permalink) | |
i'm contacted reseller...he contacted cruiser team and told that username,pswd r correct...?then wt could be d problem..?pls help me to connect with server...? | |
pls help me to unlocking KP-500 With furious gold. | morya | FuriousGold | 1 | 04-29-2009 08:43 |
Blackberry Tmobile 7105t, pls. help me to unlock with code reader | mymiela0419 | BlackBerry (RIM) | 0 | 01-16-2009 16:39 |
HELP ME ERROR: Connection with phone was lost! | .:MESSAD_RA:. | BB5BOX | 2 | 02-26-2008 05:02 |
@moderator & supporter pls help me to activate my mt-box with alcatel | asmar | MT-BOX | 2 | 05-23-2007 08:50 |
