04-24-2009, 15:05 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: suadt.com
Member: 235782 Status: Offline Thanks Meter: 82 | Repair GDFS S500i failed please help me Code: 21:00:46 D-Ultimate Unlocker v3.07 by Cruiser Team 21:00:46 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 21:00:46 Initializing... ! 21:00:46 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 21:00:46 2. Choose the phone model ! 21:00:46 3. Select the desired options ! 21:00:46 4. Please connect the phone either via USB while holding 2-5… ! 21:00:46 - or via a serial cable and double-click on it in the device list 21:00:53 Selected phone: S500 21:00:53 Connecting via SEMC USB Flash Device (USB1)… 21:00:53 Device driver version: 2.0.0.4 21:00:53 Device driver date: 9-12-2007 21:00:53 Connecting to the baseband CPU... 21:00:53 Entering baseband CPU service mode... 21:00:54 Detected chipset: DB2020 21:00:54 Boot mode: EROM 21:00:54 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB E 21:00:54 Error: 0x889C690F E 21:00:54 Unsupported boot mode ! 21:00:54 Please boot via ROM E 21:00:54 Failed! ! 21:00:54 To report errors right-click this window |
04-27-2009, 19:16 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006
Member: 219015 Status: Offline Thanks Meter: 42 | Quote:
Code: 22:16:08 D-Ultimate Unlocker v3.07 by Cruiser Team 22:16:08 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 22:16:08 Initializing... ! 22:16:08 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 22:16:08 2. Choose the phone model ! 22:16:08 3. Select the desired options ! 22:16:08 4. Please connect the phone either via USB while holding 2-5… ! 22:16:08 - or via a serial cable and double-click on it in the device list 22:17:16 Selected phone: S500 22:17:16 Connecting via Generic EMP USB Flash Device (USB1)… 22:17:16 Device driver version: 2.2.0.0 22:17:16 Device driver date: 9-18-2008 22:17:17 Connecting to the baseband CPU... 22:17:17 Entering baseband CPU service mode... 22:17:17 Detected chipset: DB2020 22:17:17 Boot mode: ROM 22:17:17 Sending loader... 22:17:17 IMEI: 35344702251281 22:17:17 OTP CID: 51 22:17:17 Effective CID: 52 22:17:19 Please reconnect the phone (disconnect, connect while holding 2-5) 22:18:02 Sending loader... 22:18:02 Communicating with server… ! 22:18:09 News: Your credit consumption policy: Level 1 (Novice) 22:18:09 Remainig credit (supreme): 1.00 E 22:18:20 Error: 0x4C273EAF E 22:18:20 Error data: 0x4C273EAF - 00000004:8010000B E 22:18:20 Error: 0x08C42858 E 22:18:20 Error: 0xE1E2479D E 22:18:20 Error: 0xA8A269DB E 22:18:20 Error: 0xEC82FA8E E 22:18:20 Error: 0x4B055A8F E 22:18:20 Error: 0x14C1924C E 22:18:20 Error: 0x3F75A28C E 22:18:20 Error: 0xC0342EAC E 22:18:20 Error: 0x5EB43879 E 22:18:20 Error: 0x834ACC0E E 22:18:20 Error: 0x07F5EFDA E 22:18:20 Error: 0x51A411A0 E 22:18:20 Error: 0x78E56923 E 22:18:20 Error: 0x5C5AEBE3 E 22:18:20 Error: 0x3D35EAF1 E 22:18:20 Cable disconnect detected E 22:18:20 Failed! ! 22:18:21 To report errors right-click this window What must I do? | |
04-27-2009, 19:28 | #4 (permalink) |
Member: 219015 Status: Offline Thanks Meter: 42 | I repeat operation Code: 23:24:46 D-Ultimate Unlocker v3.07 by Cruiser Team 23:24:46 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 23:24:46 Initializing... ! 23:24:46 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 23:24:46 2. Choose the phone model ! 23:24:46 3. Select the desired options ! 23:24:46 4. Please connect the phone either via USB while holding 2-5… ! 23:24:46 - or via a serial cable and double-click on it in the device list 23:25:19 Selected phone: S500 23:25:19 Connecting via Generic EMP USB Flash Device (USB1)… 23:25:19 Device driver version: 2.2.0.0 23:25:19 Device driver date: 9-18-2008 23:25:19 Connecting to the baseband CPU... 23:25:19 Entering baseband CPU service mode... 23:25:19 Detected chipset: DB2020 23:25:19 Boot mode: ROM 23:25:19 Sending loader... 23:25:20 IMEI: 35344702251281 23:25:20 OTP CID: 51 23:25:20 Effective CID: 52 23:25:22 Please reconnect the phone (disconnect, connect while holding 2-5) 23:25:32 Sending loader... 23:25:32 Communicating with server… ! 23:25:36 News: Your credit consumption policy: Level 1 (Novice) 23:25:37 Remainig credit (supreme): 0.67 23:25:40 Remainig credit (supreme): 0.67 23:25:43 Please reconnect the phone (disconnect, connect while holding 2-5) 23:25:54 Sending loader... E 23:27:02 Error: 0xE1E2479D E 23:27:02 Error: 0x6C729765 E 23:27:02 Error: 0x8CDFAB78 E 23:27:02 Error: 0xFA7863EC E 23:27:02 Error: 0x780BA8B0 E 23:27:02 Error: 0x599D63C1 E 23:27:02 Error: 0x10BE36DC E 23:27:02 Error: 0x59AF7680 E 23:27:02 GDFS start-up problem E 23:27:02 Failed! ! 23:27:02 To report errors right-click this window |
Cant Repair GDFS for w200i, please help me.. | yeerk05 | Cruiser Suite | 1 | 09-15-2009 11:48 |
repair GDFS PROBLEM K800i please help | zakiyyboss | SETool2 | 8 | 03-26-2009 00:37 |
K530i unlock repair gdfs write failed PLEASE ADVICE ME! | gsm8g | DreamBox | 2 | 05-12-2008 08:19 |
x 100 call failed please help me | naveed malik | Samsung Hardware Repair | 1 | 09-07-2006 13:30 |
