07-15-2008, 12:37 | #1 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Middle East Age: 45
Member: 6572 Status: Offline Thanks Meter: 26 | Unlock error with D-unlocker trying to unlock W910 with D-unlocker credit deduced and give error unlocking,i tried manytimes in normal and boot mode, still same problem used ver 2.11 and 2.12 now the phone is 5lock closed Code: 12:55:03 D-Unlocker v2.11 by Cruiser Team 12:55:03 Initializing... ! 12:55:03 1. Please see the documentation first (a PDF installed with the application) ! 12:55:03 2. Make sure the appropriate phone modem drivers are installed ! 12:55:03 3. Fill in the connection settings under settings tab ! 12:55:03 4. Turn the phone ON ! 12:55:03 5. Connect the phone… 12:55:26 Connecting via SEMC WMC Device (COM9, COM6)… 12:55:26 Starting communication... 12:55:26 Communicating with server… 12:55:33 Remainig credit (supreme): 1.00 12:55:33 Restarting phone … 12:55:53 Connecting via SEMC USB Flash Device (USB1)… 12:55:53 Device driver version: 2.1.0.0 12:55:53 Device driver date: 3-20-2008 12:55:53 Starting communication... 12:55:53 Connecting to the baseband CPU... 12:55:53 Entering baseband CPU service mode... 12:55:54 Detected chipset: DB3150 12:55:54 Boot mode: EROM 12:55:54 Sending loader... 12:55:55 IMEI: 12:55:55 OTP CID: 52 12:55:55 OTP area status: Locked 12:55:55 Product type: Retail 12:55:55 Effective color: Red 12:55:55 Sending loader... 12:55:59 Communicating with server… ! 12:56:08 Operation has been scheduled, please wait 0h 7m 22s 13:03:34 Connecting to the baseband CPU... 13:03:34 Restarting phone … 13:03:53 Starting communication... 13:03:54 Communicating with server… E 13:05:00 Error: 0x05190628 E 13:05:00 Error: 0xA8A269DB E 13:05:00 Error: 0xA8A269DB E 13:05:00 Cable disconnect detected E 13:05:00 Cable disconnect detected E 13:05:00 Unknown server problem [256] E 13:05:00 Error: 0x411ADDD1 E 13:05:00 Failed! ! 13:05:00 Please disconnect battery and cable from the phone! ! 13:05:00 To report errors right-click this window Code: 14:02:55 D-Unlocker v2.11 by Cruiser Team 14:02:55 Initializing... ! 14:02:55 1. Please see the documentation first (a PDF installed with the application) ! 14:02:55 2. Make sure the appropriate phone modem drivers are installed ! 14:02:55 3. Fill in the connection settings under settings tab ! 14:02:55 4. Turn the phone ON ! 14:02:55 5. Connect the phone… 14:04:50 Connecting via SEMC WMC Device (COM143, COM142)… 14:04:50 Starting communication... 14:04:50 Communicating with server… 14:04:56 Remainig credit (supreme): 0.00 14:04:56 Restarting phone … 14:05:07 Connecting via SEMC USB Flash Device (USB1)… 14:05:07 Device driver version: 1.1.0.12 14:05:07 Device driver date: 9-25-2006 14:05:07 Starting communication... 14:05:07 Connecting to the baseband CPU... 14:05:07 Entering baseband CPU service mode... 14:05:08 Detected chipset: DB3150 14:05:08 Boot mode: EROM 14:05:08 Sending loader... 14:05:09 IMEI: 14:05:09 OTP CID: 52 14:05:09 OTP area status: Locked 14:05:09 Product type: Retail 14:05:09 Effective color: Red 14:05:09 Sending loader... 14:05:13 Communicating with server… 14:05:22 Connecting to the baseband CPU... 14:05:22 Restarting phone … 14:05:33 Starting communication... 14:05:39 Communicating with server… ! 14:05:44 Operation has been scheduled, please wait 0h 1m 1s E 14:07:46 Error: 0x05190628 E 14:07:46 Error: 0xA8A269DB E 14:07:46 Error: 0xA8A269DB E 14:07:46 Cable disconnect detected E 14:07:46 Cable disconnect detected E 14:07:46 Unknown server problem [256] E 14:07:46 Error: 0x411ADDD1 E 14:07:46 Failed! ! 14:07:46 Please disconnect battery and cable from the phone! ! 14:07:46 To report errors right-click this window Code: 14:23:48 D-Unlocker v2.12 by Cruiser Team 14:23:48 Initializing... ! 14:23:48 1. Please see the documentation first (a PDF installed with the application) ! 14:23:48 2. Make sure the appropriate phone modem drivers are installed ! 14:23:48 3. Fill in the connection settings under settings tab ! 14:23:48 4. Turn the phone ON ! 14:23:48 5. Connect the phone… 14:24:21 Connecting via SEMC USB Flash Device (USB1)… 14:24:21 Device driver version: 1.1.0.12 14:24:21 Device driver date: 9-25-2006 14:24:21 Starting communication... 14:24:22 Connecting to the baseband CPU... 14:24:22 Entering baseband CPU service mode... 14:24:22 Detected chipset: DB3150 14:24:22 Boot mode: EROM 14:24:22 Sending loader... 14:24:23 IMEI: 14:24:23 OTP CID: 52 14:24:23 OTP area status: Locked 14:24:23 Product type: Retail 14:24:23 Effective color: Red 14:24:23 Sending loader... 14:24:26 Communicating with server… 14:24:31 Remainig credit (supreme): 0.00 14:24:36 Connecting to the baseband CPU... 14:24:36 Restarting phone … 14:24:36 Choose phone-mode (on the phone) 14:24:48 Starting communication... 14:24:54 Communicating with server… ! 14:25:00 Operation has been scheduled, please wait 0h 0m 58s E 14:26:59 Error: 0xA8A269DB E 14:26:59 Error: 0xA8A269DB E 14:26:59 Cable disconnect detected E 14:26:59 Cable disconnect detected E 14:26:59 Unknown server problem [256] E 14:26:59 Error: 0x411ADDD1 E 14:26:59 Failed! ! 14:26:59 Please disconnect battery and cable from the phone! ! 14:26:59 To report errors right-click this window |
01-08-2010, 20:45 | #3 (permalink) |
Insane Poster Join Date: Oct 2005 Location: California, USA
Member: 190261 Status: Offline Thanks Meter: 5 | i've been having this problem for few months already. i tried to connect everyday, still no luck. this is since July 2009. any D-unlocker support on the forum maybe can help us out? |
01-09-2010, 03:52 | #4 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 25671 Status: Offline Thanks Meter: 719 | And you won't have any luck in future because as we wrote many times D-Unlocker is offline. Use D-Ultimate Unlocker or D-Flasher Unlocker for S1. |
The Following User Says Thank You to Mainboard For This Useful Post: |
12-21-2010, 11:20 | #6 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1473548 Status: Offline Thanks Meter: 0 | k510 DB2012 CID50 unlock Sony Ericsson Hello, I have to unlock Sony Ericsson K510 / k510i in DB2012 and CID 50. Two years ago unlock worked with D-Client v1.61 (0021), but now no connection to server is possible :-( I also tried to unlock with D-Ultimate Unlocker (version 5.04) via USB-cabel. -> but didn't worked / no solution :-( Is there any actual version of D-Client or an other Tool which is able to unlock Sony Ericsson K510i DB2012 and CID 50 ? |
unlock error with D ultimate unlocker | marcopolod | D-Unlock Suite | 5 | 12-27-2008 18:22 |
7390/unlock error with thomas unlocker | kaiserstumm | BB5 No TP By Jafsupport | 3 | 11-26-2008 15:30 |
Terminated With Error With Bb5 Unlock | stemo | Universalbox | 1 | 05-24-2007 06:15 |
