11-28-2007, 20:12 | #1 (permalink) |
Insane Poster Join Date: Nov 2004 Location: poland
Member: 94660 Status: Offline Thanks Meter: 4 | w200i cid51 can't unlock i have w200i cid51 red and can't unlock it sw + fs + unlock + customize ... and after finish flash two files I get that error error occured during sending loader. (9C498AA1) phone turn on, in service menu all locks are open, but when i turn with simcard i got error "configuration error. contact net provider or service center" i lost 3 logs and phone still have simlock and show error configuration error... tom |
11-28-2007, 23:30 | #3 (permalink) |
Insane Poster Join Date: Feb 2005 Age: 37
Member: 112974 Status: Offline Thanks Meter: 0 | Now i tried select only customize, and not select unlock and it goes till the end and take me 0,5 credits! Why with customize+unlock didnt work? And the 0,5 credit, is possible give it back? Thank you EDIT: Tryed again customize+unlock starting transfer and error!! Now phone dont turn on :| And have dificulty to make the method C + connect cable! It dont boot What i do now? Last edited by morton; 11-28-2007 at 23:39. |
12-03-2007, 10:49 | #6 (permalink) |
Member: 94660 Status: Offline Thanks Meter: 4 | @ar-ras D-Client Version 0.99 (10th October 2007): Implemented unlock functionality for red CID50/51 DB2012 phones. w810 cid51 unlock without problem, w200 cid51 unlock ???? Has anyone succesfully unlocked w200 ???? |
12-04-2007, 09:34 | #7 (permalink) | |
Insane Poster Join Date: Nov 2006
Member: 401743 Status: Offline Thanks Meter: 17 | Quote:
Unlock w200 (if error already occured): 1. Use Expert GUI 2. Check Customize, uncheck unlock, delete all flash files 3. Go Unlock w200: 1. Use Expert GUI 2. Check Unlock and Uncheck Customize 3. Go 4. Connect the phone again 5. Check Customize, uncheck unlock, delete all flash files 6. Go Brusko, Morton send me your usernames. | |
12-04-2007, 11:53 | #8 (permalink) |
Member: 94660 Status: Offline Thanks Meter: 4 | Unlock w200: 1. Use Expert GUI 2. Check Unlock and Uncheck Customize 3. Go that OK 4. Connect the phone again 5. Check Customize, uncheck unlock, delete all flash files 6. Go (5BCE5510) (CE214415) (F72977E0) (E87DCD1B) (F3A1AB5D) Error occured during sending loader. (9C498AA1) |
how to unlock w200i cid51 with cruiser | Haouas | Cruiser Suite | 8 | 04-05-2008 01:21 |
Can MT Box unlock this W200i CID51 ??? | chavrotti | MT-BOX | 5 | 10-24-2007 10:56 |
When Cruiser will support w200i CID51? | KUBAT1 | Cruiser Suite | 0 | 07-30-2007 12:13 |
w200i cid51 no unlock | wuyong | Universalbox | 7 | 07-23-2007 20:26 |
W200i CID51 | insidebga | Universalbox | 1 | 07-12-2007 12:45 |
