07-16-2009, 01:47 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: skyw0rk jombang
Member: 239081 Status: Offline Thanks Meter: 253 | need analizys Code: 17:42:48 D-Ultimate Unlocker v3.11 by Cruiser Team 17:42:48 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 17:42:48 Initializing... ! 17:42:48 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 17:42:48 2. Choose the phone model ! 17:42:48 3. Select the desired options ! 17:42:48 4. Please connect the phone either via USB while holding 2-5… ! 17:42:48 - or via a serial cable and double-click on it in the device list 17:43:06 Selected phone: W850 17:43:06 Connecting via Cruiser UC-20 Cable (COM11)… 17:43:06 Device driver version: 2.4.6.0 17:43:06 Device driver date: 3-13-2008 17:43:08 Connecting to the baseband CPU... 17:43:17 Entering baseband CPU service mode... 17:43:17 Detected chipset: DB2020 17:43:17 Boot mode: ROM 17:43:17 Sending loader... 17:43:18 IMEI: 35240101189401 17:43:18 OTP CID: 49 17:43:18 Effective CID: 49 17:43:18 Restarting phone … 17:43:21 Sending loader... 17:43:22 Communicating with server… ! 17:43:24 News: Your credit consumption policy: Level 1 (Novice) 17:43:24 Remainig credit (supreme): 0.34 17:43:26 Remainig credit (supreme): 0.34 17:43:27 Restarting phone … 17:43:29 Sending loader... E 17:43:33 Error: 0x07F5EFDA E 17:43:33 Error: 0xFE6D44E2 E 17:43:33 Error: 0xE9B26D61 E 17:43:33 Error: 0x8118A648 E 17:43:34 Error: 0x59AF7680 E 17:43:34 Failed! ! 17:43:34 To report errors right-click this window pleas gdfs bekup colections w850 exstension .gdfs |
07-16-2009, 07:33 | #3 (permalink) |
Member: 239081 Status: Offline Thanks Meter: 253 | if use usb [code] 23:23:02 D-Ultimate Unlocker v3.11 by Cruiser Team 23:23:02 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 23:23:02 Initializing... ! 23:23:03 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 23:23:03 2. Choose the phone model ! 23:23:03 3. Select the desired options ! 23:23:03 4. Please connect the phone either via USB while holding 2-5… ! 23:23:03 - or via a serial cable and double-click on it in the device list 23:23:39 Selected phone: W850 23:23:39 Connecting via Generic EMP USB Flash Device (USB1)… 23:23:39 Device driver version: 2.1.0.0 23:23:39 Device driver date: 3-20-2008 23:23:39 Connecting to the baseband CPU... 23:23:39 Entering baseband CPU service mode... 23:23:39 Detected chipset: DB2020 and apps going frezee when i use apps d ulnlocker v 3.07 result is Code: 23:28:59 D-Ultimate Unlocker v3.07 by Cruiser Team 23:28:59 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 23:28:59 Initializing... ! 23:28:59 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 23:28:59 2. Choose the phone model ! 23:28:59 3. Select the desired options ! 23:29:00 4. Please connect the phone either via USB while holding 2-5… ! 23:29:00 - or via a serial cable and double-click on it in the device list 23:29:44 Selected phone: W850 23:29:44 Connecting via Generic EMP USB Flash Device (USB1)… 23:29:44 Device driver version: 2.1.0.0 23:29:44 Device driver date: 3-20-2008 23:29:44 Connecting to the baseband CPU... 23:29:44 Entering baseband CPU service mode... 23:29:44 Detected chipset: DB2020 23:29:44 Boot mode: ROM 23:29:44 Sending loader... 23:29:44 IMEI: 35240101189401 23:29:44 OTP CID: 49 23:29:44 Effective CID: 49 23:29:46 Please reconnect the phone (disconnect, connect while holding 2-5) 23:29:55 Sending loader... 23:29:56 Communicating with server… ! 23:29:58 News: Your credit consumption policy: Level 1 (Novice) 23:29:59 Remainig credit (supreme): 0.34 23:30:00 Remainig credit (supreme): 0.34 23:30:03 Please reconnect the phone (disconnect, connect while holding 2-5) 23:30:12 Sending loader... E 23:30:14 Error: 0x07F5EFDA E 23:30:14 Error: 0xFE6D44E2 E 23:30:15 Error: 0xE9B26D61 E 23:30:15 Error: 0x8118A648 E 23:30:15 Error: 0x59AF7680 E 23:30:15 Failed! ! 23:30:15 To report errors right-click this window but the problem is same..... |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
i need kp135 flash file [USER REQUEST] | sameenshah123 | PolarBox 3 | 5 | 03-29-2010 16:08 |
i need 1650 flash file without games | med26 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 03-29-2010 11:11 |
nokia masters need help.............. | ANILMPLY | Nokia Hardware & Hardware Repair | 0 | 03-29-2010 10:48 |
