ufc4 with mxbox ...flashing report[6500s RM-240,Bsi7.5k,BB5-B Jig] Quote:
Originally Posted by romar
(Post 7297297)
how to use dits4 cable with mxbox can you provide procedure for this which main cable should i use jaf, cyclone, atf or mt cable they all have error in flashing i tried every main cable every bsi nothing works.... | Code:
Version from phone: 10.00
Version from file: 10.30
MXKEY Serial: xxxxxxxx
Using device: HTI BOX, FW ver: 00.07
Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011)
Reading Important data ...
Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35483702189947_BACK.rpl).
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1FE0000ACDA94F5010C61420FD2709CA45A80189
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 10.42.0 revision: 0.0 size: 0x3C40
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.40.0 revision: 0.0 size: 0x23550
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: A69838E8C5F20150E64E2E6E06DE6E50B26B593F
TransmissionMode: DDR&TX2
Processing MCU file: rm240__10.30.mcusw
[BB5,BB5 ALGORITHM] size: 20.39 MB
Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
CMT NOR area [00000000-0001FFFF]
CMT NOR area [00040000-000BFFFF]
CMT NOR area [000C0000-0013FFFF]
CMT NOR area [01480000-015FFFFF]
CMT NOR area [00140000-0147FFFF]
Erase size: 21.87 MB
CMT section, erased in 1 min 32.638 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: A69838E8C5F20150E64E2E6E06DE6E50B26B593F (RAP Certificate 84 v1) sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 2 min 52.876 s
Processing PPM file: rm240__10.30.ppm_c
[BB5,BB5 ALGORITHM] size: 6.42 MB
CMT NOR area [01600000-01CBFFFF]
Erase size: 6.75 MB
CMT section, erased in 27.681 s
Programming completed in 1 min 0.575 s
Processing CNT file: rm240__10.30_ISM_001.image_c_tr_ctv_tr
[BB5,BB5 ALGORITHM] page size: 128 K size: 11.51 MB
CMT NOR area [01FC0000-03F9FFFF]
CMT NOR area [01CC0000-01FBFFFF]
Erase size: 34.87 MB
CMT section, erased in 3 min 3.019 s
Programming completed in 1 min 37.915 s
Total time for flashing process(boot+erase+write) was 10 min 47.638 s
Phone Type: RM-240 (Nokia 6500s-1)
SW Version: V 10.30 23-04-09 RM-240 (c) Nokia
Imei plain: 35483702189947-8
Product Code: 0560812
Battery voltage: 4638 mV, current: 0 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354837021899478
Version: SIMLOCK SERVER
Provider: Orange , Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2343300000000000
PROFILE_BITS: 8000000000000000
BLOCK 1: 1=OPEN, DATA=23433F [United Kingdom-Orange ]
BLOCK 2: 1=OPEN, DATA=23486F |
