05-10-2011, 04:30 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: philippines
Member: 49854 Status: Offline Sonork: 100.1652592 Thanks Meter: 38 | mxbox what cable to use??? |
05-10-2011, 07:43 | #3 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Guangzhou, China
Member: 659181 Status: Offline Thanks Meter: 7,652 | Quote:
check ur cable from computer to mx box | |
05-10-2011, 11:54 | #4 (permalink) | |
Freak Poster Join Date: Jul 2006 Location: MARS
Member: 311990 Status: Offline Thanks Meter: 146 | mxbox with ufc4. Quote:
u can use atf main cable or jaf main cable. Code: MXKEY Serial: xxxxxxxx Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1FE0000ACDA94F5010C61420FD2709CA45A80189 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: A69838E8C5F20150E64E2E6E06DE6E50B26B593F TransmissionMode: DDR&TX2 Original Imei: 35483702189947 Original Product code: 0560812 Bluetooth ID: 0021AA79EABB Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 10.00 06-03-09 RM-240 (c) Nokia Imei plain: 35483702189947-8 Product Code: 0560812 Battery voltage: 4653 mV, current: 124 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354837021899478 Version: SIMLOCK SERVER Provider: Orange , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=23433F [United Kingdom-Orange ] BLOCK 2: 1=OPEN, DATA=23486F | |
The Following User Says Thank You to SMDSAFE For This Useful Post: |
05-11-2011, 01:50 | #6 (permalink) | |
Member: 49854 Status: Offline Sonork: 100.1652592 Thanks Meter: 38 | Quote:
yes for me i can also bus check any unit but when i try flashing the it always give error.... | |
05-11-2011, 04:37 | #7 (permalink) | |
Member: 311990 Status: Offline Thanks Meter: 146 | ufc4 with mxbox ...flashing report[6500s RM-240,Bsi7.5k,BB5-B Jig] Quote:
Code: Version from phone: 10.00 Version from file: 10.30 MXKEY Serial: xxxxxxxx Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) Reading Important data ... Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35483702189947_BACK.rpl). CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1FE0000ACDA94F5010C61420FD2709CA45A80189 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 10.42.0 revision: 0.0 size: 0x3C40 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.40.0 revision: 0.0 size: 0x23550 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: A69838E8C5F20150E64E2E6E06DE6E50B26B593F TransmissionMode: DDR&TX2 Processing MCU file: rm240__10.30.mcusw [BB5,BB5 ALGORITHM] size: 20.39 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 CMT NOR area [00000000-0001FFFF] CMT NOR area [00040000-000BFFFF] CMT NOR area [000C0000-0013FFFF] CMT NOR area [01480000-015FFFFF] CMT NOR area [00140000-0147FFFF] Erase size: 21.87 MB CMT section, erased in 1 min 32.638 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: A69838E8C5F20150E64E2E6E06DE6E50B26B593F (RAP Certificate 84 v1) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 2 min 52.876 s Processing PPM file: rm240__10.30.ppm_c [BB5,BB5 ALGORITHM] size: 6.42 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 CMT NOR area [01600000-01CBFFFF] Erase size: 6.75 MB CMT section, erased in 27.681 s Flash programming ... Programming completed in 1 min 0.575 s Processing CNT file: rm240__10.30_ISM_001.image_c_tr_ctv_tr [BB5,BB5 ALGORITHM] page size: 128 K size: 11.51 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 CMT NOR area [01FC0000-03F9FFFF] CMT NOR area [01CC0000-01FBFFFF] Erase size: 34.87 MB CMT section, erased in 3 min 3.019 s Flash programming ... Programming completed in 1 min 37.915 s Total time for flashing process(boot+erase+write) was 10 min 47.638 s Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 10.30 23-04-09 RM-240 (c) Nokia Imei plain: 35483702189947-8 Product Code: 0560812 Battery voltage: 4638 mV, current: 0 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354837021899478 Version: SIMLOCK SERVER Provider: Orange , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=23433F [United Kingdom-Orange ] BLOCK 2: 1=OPEN, DATA=23486F | |
09-20-2011, 17:02 | #9 (permalink) | |
Crazy Poster Join Date: May 2011
Member: 1579575 Status: Offline Sonork: tata5 Thanks Meter: 2 | Quote:
how to connect Mxbox and UFC4? about the battery on Nokia. they are two ways. how to choose right one ? I have Nokia 6085 I have first choose : 1.- PWR 2.- GND 3.- BSI second choose : 1.- PWR 2.- BSI 3.- GND You will see that in the UFC4 Manual also how to setup resistance ? thanks for your help | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
