TEST K750 Trident Combo Cable http://ditsonline.com/poster/050110_...Combo-Blog.jpg OUTPUT POWER FROM : SETOOL =2 V UFS=1.7V SO I CANT BOOT PHONE USING THIS POWER. USING BATTERY AND EXT POWER SUPPLY (3.6 V) NO PROBLEM Quote:
ur 100% coorect u need to attach battery for operation this cable not providing adiquet power supply to +ve |
Save money with this cable ????? I buy this cable coz have power supply, so no need battery or ext power supply. Verry disappointed. How about about se trident supreme cable? Any one tested ? http://www.ponselmart.net/273-628-la...eme-cable-.jpg |
K750 trident combo cable test report Quote:
HERE IS THE TEST REPORT FROM SETOOL USING DITS K750 TRIDENT COMBO CABLE. v0.915040/UNI CARD SERIAL: 00014193 Loaded 51 flash descriptors CFG:00000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35683401969492 CERT:N/A FLASH CID:53 COLOR:RED Model (from GDFS):W580c Brand:CMCC MAPP CXC article: R6BD001 prgCXC1123479_CMCC_LA MAPP CXC version: R6BD001 Language Package: CMCC CDA article: CDA102774/303 CDA version: R10A Default article: cxc1123364 Default version: R6BD001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R6BD001_CXC1123479_CMCC_LA" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE NOT PRESENT "R6BD001_CXC1123479_CMCC_LA.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" Elapsed: 6 secs. IT IS TEST REPORT FROM UFS/HWK USING DITS K750 TRIDENT COMBO CABLE. UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: 73343 HID: E2764BE041600051 HWK: A1.04-PRO1 Licence: True, 00:09 MCU_ID : 99000301FFFFFFFF S_BAUD : 921600 P_LOAD : 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLSH_ID: 897E [Intel SIBLEY] M_CERT : 53 RED IMEI : 356834-01-969492-0 CD_PAF : 1 0 1 OTPCID : 51 RED CID_UP : 5153 CXC_NR : cxc1123364 R6BD001 CDA_NR : CDA102774/303 R10A |
unfortunately mine not work, test using k330 and w395. PC PHENOM II X2 550 3.10 GHZ 2 GB RAM DDR3 BIOSTART TA790GX A3+ PSU SAGA II 500W using usb port direct from mobo on back. |
