Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
12-05-2007, 08:03 | #16 (permalink) |
No Life Poster Join Date: Nov 2007 Location: mobile solution
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | How to repair "reboot/restart/frees with SIM card" step-by-step instruction Infinity-Box "ChineseMiracle": How to repair "reboot/restart/freez with SIM card" 1. make full flash backup for emergency case (use 921000 speed for fast operation). It's very important step ! 2. select "safe" format method 3. make "format ffs" 4. remove/install battery 5. press and hold phone "Power" button during 30-40 sec to make phone Powered-On if phone Ok go to step-6 if phone still in reboot/restart/freez state: select "complete" format method and go to step 3 if phone still in reboot/restart/freez state: try to use other SIM card, some phones works not good with some SIM cards if phone can't Power-On: restore original flash backup if you don't have original backup: write different firmware files with firmware version similar to original 6. restore original imei 7. if phone has touchscreen LCD make calibration: click to LCD corners one by one if still no luck: check phone hardware regared .::kabir::. |
The Following 4 Users Say Thank You to .::kabir::. For This Useful Post: |
12-05-2007, 08:56 | #19 (permalink) |
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | All Chiniss Mobile Hardware Share, chiniss cord & pin out .::kabir::. some chinese Mobile Code And Pinouts ::::::::::::>>>>>>>>>> Service codes BenQ: software version: *#300# test mode: *#302*20040615# Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default): *01763*737381# Service codes 3xx, 5xx: software version: *#79# software version: *#837# Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) reset defaults (phone/user code reset to default): *#9998*7328# (hold #) Service codes LG: software version: 2945#*# Service codes Sony-Ericsson: J100 software version: #82# Service codes Fly: 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007# Service codes Konka: C926 software version: *320# Send C926 set default language: *#0000# Send C926 set English language: *#0044# Send Service codes GStar: GM208 (Chinese Nokea 6230+) engineering menu: *#66*# Set language to English: *#0044# Set language to Russian: *#0007# Service codes Motorola: Motofone F3 software version: **9999* Send C113, C114, C115, C115i, C116, C117, C118 software version: #02#* C138, C139, C140 software version: #02#* C155, C156, C157 software version: #02#* C257, C261 software version: #02#* V171, V172, V173 software version: #02#* V175, V176, V176 software version: #02#* C168, W220 software version: *#**837# W208, W375 software version: #02#* ZTE Mobile:>1- *938*737381# 2- PHONE WILL DIPLAYED DONE 3- POWER OFF YOUR PHONE AND POWER ON AGAIN alcatel:>E205 unlocking phone code,only press***847# without simcard E900 software version: *#5002*8376263# E900 full reset: *2767*3855# Service codes Spice: S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200 S410 engineer mode: *#3646633# S900 software version: *#8375# S900 serial no: *#33778# Service codes Philips: S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200 Service codes "Chinese" models: default user code: 1122, 3344, 1234, 5678 Engineer mode: *#110*01# Factory mode: *#987# Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200 Restore factory settings: *#987*99# LCD contrast: *#369# software version: *#800# software version: *#900# Service codes BenQ: software version: *#300# test mode: *#302*20040615# Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default): *01763*737381# Service codes VK-Mobile 3xx, 5xx: software version: *#79# software version: *#837# service menu: *#85*364# (hold #) Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) reset defaults (phone/user code reset to default): *#9998*7328# (hold #) Service codes LG: software version: 2945#*# KG300 NVRAM format: 2945#*# -> menu 15 Service codes Sony-Ericsson: J100 software version: #82# Service codes Fly: M100 software version: ####0000# 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007# Service codes Konka: C926 software version: *320# Send C926 set default language: *#0000# Send C926 set English language: *#0044# Send Service codes GStar: GM208 (Chinese Nokea 6230+) engineering menu: *#66*# Set language to English: *#0044# Set language to Russian: *#0007# Service codes Motofone-F3: Motofone F3 software version: **9999* Send ***300* Set SIM Pin ***310* / ***311* SIM Pin ON | OFF ***000* Reset Factory settings ***644* Set Voicemail number ***260* / ***261* Auto keypad lock ON | OFF ***510* / ***511* Voice Prompts ON | OFF ***160* / ***161* Restricted Calling (Phonebook only) ON | OFF ***200608* Send: software version ***200606* Send: software version ***200806* Send: flex version ***250* / ***251* Keypad tones ON | OFF ***470* Select time format ***500* /***501* Prepaid Balance Display ON | OFF ***520* Change language Service codes Motorola: C113, C114, C115, C115i, C116, C117, C118 software version: #02#* C138, C139, C140 software version: #02#* C155, C156, C157 software version: #02#* C257, C261 software version: #02#* V171, V172, V173 software version: #02#* V175, V176, V176 software version: #02#* C168, W220 software version: *#**837# W208, W375 software version: #02#* and "yes"'' .................................................. ............................... N95Pda and N95S Pinout 2x5 4:Rx 5:TX 6:GND .................................................. ............................... K1 Moto Pinout 4:Rx 5:Tx 6:Gnd .................................................. ............................... PDA ZT6618 1........8 pin mini Conector 3:Rx 4:TX 5:Gnd .................................................. ............................... Cect 8380 1..........8 pin mini Conector 1:Gnd 2:Rx 3:Tx .................................................. ............................... KG-200 4:Gnd 3:Tx 2:Rx .................................................. ............................... N91I 1..............12 pin Connector . 5:Gnd . 12:Tx 6:Tx . 13:Rx 7:Rx . ============================================== All Chinese Mobile Code And Pinouts -------------------------------------------------------------------------------- hi Service codes BenQ: software version: *#300# test mode: *#302*20040615# Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default): *01763*737381# Service codes 3xx, 5xx: software version: *#79# software version: *#837# Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) reset defaults (phone/user code reset to default): *#9998*7328# (hold #) Service codes LG: software version: 2945#*# Service codes Sony-Ericsson: J100 software version: #82# Service codes Fly: 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007# Service codes Konka: C926 software version: *320# Send C926 set default language: *#0000# Send C926 set English language: *#0044# Send Service codes GStar: GM208 (Chinese Nokea 6230+) engineering menu: *#66*# Set language to English: *#0044# Set language to Russian: *#0007# Service codes Motorola: Motofone F3 software version: **9999* Send C113, C114, C115, C115i, C116, C117, C118 software version: #02#* C138, C139, C140 software version: #02#* C155, C156, C157 software version: #02#* C257, C261 software version: #02#* V171, V172, V173 software version: #02#* V175, V176, V176 software version: #02#* C168, W220 software version: *#**837# W208, W375 software version: #02#* ZTE Mobile:>1- *938*737381# 2- PHONE WILL DIPLAYED DONE 3- POWER OFF YOUR PHONE AND POWER ON AGAIN alcatel:>E205 unlocking phone code,only press***847# without simcard E900 software version: *#5002*8376263# E900 full reset: *2767*3855# Service codes Spice: S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200 S410 engineer mode: *#3646633# S900 software version: *#8375# S900 serial no: *#33778# Service codes Philips: S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200 Service codes "Chinese" models: default user code: 1122, 3344, 1234, 5678 Engineer mode: *#110*01# Factory mode: *#987# Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200 Restore factory settings: *#987*99# LCD contrast: *#369# software version: *#800# software version: *#900# Service codes BenQ: software version: *#300# test mode: *#302*20040615# Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default): *01763*737381# Service codes VK-Mobile 3xx, 5xx: software version: *#79# software version: *#837# service menu: *#85*364# (hold #) Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) reset defaults (phone/user code reset to default): *#9998*7328# (hold #) Service codes LG: software version: 2945#*# KG300 NVRAM format: 2945#*# -> menu 15 Service codes Sony-Ericsson: J100 software version: #82# Service codes Fly: M100 software version: ####0000# 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007# Service codes Konka: C926 software version: *320# Send C926 set default language: *#0000# Send C926 set English language: *#0044# Send Service codes GStar: GM208 (Chinese Nokea 6230+) engineering menu: *#66*# Set language to English: *#0044# Set language to Russian: *#0007# Service codes Motofone-F3: Motofone F3 software version: **9999* Send ***300* Set SIM Pin ***310* / ***311* SIM Pin ON | OFF ***000* Reset Factory settings ***644* Set Voicemail number ***260* / ***261* Auto keypad lock ON | OFF ***510* / ***511* Voice Prompts ON | OFF ***160* / ***161* Restricted Calling (Phonebook only) ON | OFF ***200608* Send: software version ***200606* Send: software version ***200806* Send: flex version ***250* / ***251* Keypad tones ON | OFF ***470* Select time format ***500* /***501* Prepaid Balance Display ON | OFF ***520* Change language Service codes Motorola: C113, C114, C115, C115i, C116, C117, C118 software version: #02#* C138, C139, C140 software version: #02#* C155, C156, C157 software version: #02#* C257, C261 software version: #02#* V171, V172, V173 software version: #02#* V175, V176, V176 software version: #02#* C168, W220 software version: *#**837# W208, W375 software version: #02#* and "yes"'' .................................................. ............................... N95Pda and N95S Pinout 2x5 4:Rx 5:TX 6:GND .................................................. ............................... K1 Moto Pinout 4:Rx 5:Tx 6:Gnd .................................................. ............................... PDA ZT6618 1........8 pin mini Conector 3:Rx 4:TX 5:Gnd .................................................. ............................... Cect 8380 1..........8 pin mini Conector 1:Gnd 2:Rx 3:Tx .................................................. ............................... KG-200 4:Gnd 3:Tx 2:Rx .................................................. ............................... N91I 1..............12 pin Connector . 5:Gnd . 12:Tx 6:Tx . 13:Rx 7:Rx . |
12-05-2007, 09:07 | #21 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Chittagong, Bangladesh.
Member: 152752 Status: Offline Sonork: 100.1581661 Thanks Meter: 182 | Maybe he dosent know that which is chiness phone. westech thread, close it. Last edited by Raheeeeb; 12-06-2007 at 06:12. Reason: EDITED FOR QUOTE LONG POST |
The Following User Says Thank You to tuhingr For This Useful Post: |
12-05-2007, 09:12 | #22 (permalink) |
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | sir,i m use, Super Doctor Box,with infinity,some time some mobile suport infinity,if u have 2 box very good wark for u nice day,, .::kabir::. |
The Following User Says Thank You to .::kabir::. For This Useful Post: |
12-05-2007, 12:30 | #23 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Jr Telecom™
Member: 409725 Status: Offline Sonork: 100.1581478 Thanks Meter: 797 | China mobile repair guide HERE http://www.4shared.com/file/29964503/3ea860b5/China_Mobiles_Guide.html http://www.4shared.com/file/29964503...les_Guide.html |
The Following 2 Users Say Thank You to Jr Telecom For This Useful Post: |
12-05-2007, 12:43 | #24 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: ! Age: 39
Member: 414755 Status: Offline Sonork: quickgsm Thanks Meter: 389 | Quote:
Please password to access this file ???????????????????????????????? | |
The Following User Says Thank You to quickgsm For This Useful Post: |
12-06-2007, 08:42 | #29 (permalink) |
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | Some Service codes "Chinese" models .::KABIR::. -------------------------------------------------------------------------------- Some Service codes "Chinese" models Service codes "Chinese" models: * default user code: 1122, 3344, 1234, 5678 * Engineer mode: *#110*01# * Factory mode: *#987# * Enable test mode COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200 * Restore factory settings: *#987*99# * LCD contrast: *#369# * software version: *#800# * software version: *#900# Service codes BenQ: * software version: *#300# * test mode: *#302*20040615# Service codes Pantech: * software version: *01763*79837# * service menu: *01763*476# * reset defaults (phone/user code reset to default): *01763*737381# Service codes 3xx, 5xx: * software version: *#79# * software version: *#837# Service codes VK200, VK2000, VK2010, VK2020, VK4000: * software version: *#79# * service menu: *#9998*8336# (hold #) * reset defaults (phone/user code reset to default): *#9998*7328# (hold #) Service codes LG: * software version: 2945#*# Service codes Sony-Ericsson: * J100 software version: #82# Service codes Fly: * M100 software version: ####0000# * 2040(i) reset defaults: *#987*99# Send * MX200 reset defaults: *#987*99# Send * MX200 software version: *#900# Send * SL300m reset defaults: *#987*99# Send * SL300m software version: *#900# Send * SL500m reset defaults: *#987*99# Send * SL500m software version: *#900# Send * MP500 reset defaults: *#987*99# Send * MP500 software version: *#900# Send * Set language to English: *#0044# * Set language to Russian: *#0007# Service codes Konka: * C926 software version: *320# Send * C926 set default language: *#0000# Send * C926 set English language: *#0044# Send Service codes GStar: * GM208 (Chinese Nokea 6230+) engineering menu: *#66*# * Set language to English: *#0044# * Set language to Russian: *#0007# Service codes Motorola: * Motofone F3 software version: **9999* Send * C113, C114, C115, C115i, C116, C117, C118 software version: #02#* * C138, C139, C140 software version: #02#* * C155, C156, C157 software version: #02#* * C257, C261 software version: #02#* * V171, V172, V173 software version: #02#* * V175, V176, V176 software version: #02#* * C168, W220 software version: *#**837# * W208, W375 software version: #02#* Edit/Delete Message .::KABIR::. |
All China mobiles hardware guide | majidaziz | Chinese Models & Cloned Phones | 0 | 03-11-2009 18:41 |
All BB5 Mobile Hardware Solutions | khisrow | Nokia Hardware & Hardware Repair | 1 | 11-28-2008 18:52 |
All BB5 Mobile Hardware Solutions(The Usefull | khisrow | Nokia Hardware & Hardware Repair | 1 | 11-28-2008 13:39 |
we solve all china mobile hardware and software problems | mehmoodkishtwar | Chinese Models & Cloned Phones | 0 | 06-11-2008 18:08 |
