Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
07-01-2002, 14:17 | #2 (permalink) |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | For P.A: Set hot air temp to 375C Heat board on keypad side under P.A for 10-15 sec Then set hot air temp to 350C Heat around P.A side solder and slowly lift with tweezer Use same for antenna switch but just quicker.The key to removing P.A is melting solder underneath |
PA & Antenna switch compatibility metrix | chochol | Nokia Hardware & Hardware Repair | 0 | 02-13-2010 13:11 |
White Screen, Antenna Switch, MIC Solutions, & ALLnokia hardware solutions download | tehseen ahmed | Nokia Hardware & Hardware Repair | 8 | 09-12-2009 02:58 |
siemens C55:No signal,Need antenna switch ways & bridge | The Razor | Siemens Hardware Repair Area | 1 | 01-21-2006 05:49 |
3310 signal low after change PA and Antenna switch | Black-Axe | Nokia Hardware & Hardware Repair | 5 | 10-15-2002 14:35 |
