Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Repair by brands
Hardware Repair by brands All about hardware problems sorted by brands inside subsections.
Old 03-29-2002, 14:42   #1 (permalink)
mr_x4you's Avatar
Member: 4989
Thanks Meter: 11
Problem with A2618 keyboard
I have this problem with A2618 keyboard: the left key doesn't work ! All others are working. The plastic foil is ok, but no action when I press left key !
Old 03-29-2002, 15:04   #2 (permalink)
Member: 461
Thanks Meter: 2
try change domen . and clean pcb with cleaner.
if domen damaged ,you need cut non worked key and put new. I used for this domen from ericsson T10/T18.
Old 03-29-2002, 16:35   #3 (permalink)
Member: 7767
Thanks Meter: 3
Better to use Motorola's (T,V,M series) keyboard
Old 03-29-2002, 19:17   #4 (permalink)
mr_x4you's Avatar
Member: 4989
Thanks Meter: 11
Ok, I'll try
Old 03-29-2002, 20:31   #5 (permalink)
Member: 7062
Thanks Meter: 121
old trick i got it from old man ...... u know the alkain battrey aadestory it the black powder is the matrial which use in these press ....enjoy my friend
Old 03-30-2002, 07:55   #6 (permalink)
Member: 6460
The keyboard of 2618 is easily damage
because the carbon contact type is easily pulvurize.
For longterm solution, u can use the keypad dome of
Nokia 3310. Tested by me.
Old 03-30-2002, 09:18   #7 (permalink)
Member: 7062
Thanks Meter: 121
please ever never use nokia press key pad may b make a short or hang ...
Old 03-30-2002, 16:56   #8 (permalink)
Member: 4873
Thanks Meter: 5
@raheeb
how do we apply this "black powder" in the keys? do we need some adhesives? please elaborate cuz i certainly haven't tried this solution yet..
best regards!
Old 04-02-2002, 09:02   #9 (permalink)
Member: 6460
Just replace two units with 3310 keypad dome a month
ago without any problem
Old 04-03-2002, 03:55   #10 (permalink)
Member: 7843
Interrested by the "black powder" solution. How can aply it. I've ten of unit this keyb problem ( exactly 22 units) , and can't get enough 3310 domes.
Please explain more ( if it's not a joke !) this old trick.
Thanks
Strange problem on X600 with freezing keyboard afshar SYSOL Platform 4 01-07-2006 10:23
Problem with 7650 keyboard AlphaGSM Nokia Hardware & Hardware Repair 3 02-28-2004 06:01
Still problems with a2618 cable Unlockie Old Ericsson Phones & Sony Phones 2 10-16-2002 17:42
Problem with Siemens C35, not response to keyboard pressing. Gargules x1x to x45/x50 3 12-30-2001 20:05
Page generated in 0.34602 seconds with 8 queries
